Question about Xerox Office Equipment & Supplies
XEROX pl220 have paper jamed but not paper jam in PRINTER
  • JMJr May 07, 2015
    Hi Abhishek kumar, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Need full Model number.
Cops
  • 64 Answers
SOURCE: paper jam in tray 2
the most common problem for a paper jam in tray 2 is that either the pick up rollers and separation pads are worn or that there is something stuck to the rollers that transfer the paper up through to trat 1.(most commonly from if people have been printing on stickers/labels) just eyeball it to see if anything looks to be stook and try wiping it off. DO NOT SCRATCH IT OFF as this will only make things worse!!!
Posted on Oct 05, 2007
SOURCE: paper jam
I had the same problem kept getting an error something like Jam at Exit Door Open Door A. When I looked at the top of the where paper normally comes from and flipped it open I found a super crinkled piece of paper, which once removed cleared the jam.
Posted on Oct 23, 2008
SOURCE: dell 1600N printer paper jam
More than likely you need a new pick up roller. It is located at the top of the tray area in the printer. You will see a black rubber roller with white nylon clips on both sides. You can confirm if it is the problem by removing and washing it with soap and water, then clipping it back in and running a few copies.
Posted on Jan 14, 2009
SOURCE: paper jam issue
We had the same problem in our office.We tried cleaning it with compressed air but not much was done.Finally be changed the paper we were using with a less glossy and this seems to work.The printer has a roller with some kind of glue on it that pulls in the paper and if the paper is a bit glossy it can't stick on it.However sometimes it jams but once in a while now.
Posted on Feb 16, 2009
SOURCE: xerox phaser 6120 laser printer paper jam fuser
Fix, well i am a dentist in Marysville washington and just got this printer from a family member and same thing was going on.
I looks like paper stuck in the middle roller. I just got a small mirror and pair of dental tweezers and removed a lot of jammed paper. it works fine now but you need do go to the dental section in drug store, so you can see where the jam is at.
Posted on Oct 26, 2009
Xerox phaser 6010, a small piece of paper tore while removing a jame from the rear. It then ate the small corner of paper and is in "jam mode". Where do I look for the piece? Can I open the machine...
I've had problems like this in the past.
if you don't see the piece of paper then you could try pushing a thicker page in the paper path hoping to dislodge it. Alternatly try printing a page and wait for a jam. Open the printer paper path and try not to disturbe it as you open the panel, to look for clues as to where it gets stuck. Hopefully it's somwhere you can get your hands or tweezers on.
Good luck.
Feb 11, 2015 | Xerox PHASER 6010 COLOR LASER PRINTER, UP...
My phaser 3040 xerox printer says there is a paper jam, but there isn't
I suggest You Go to Official Xerox Printer Page For You Xerox Printer Problem On Below Xerox forum URL Link: Clearing Paper Jams In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Xerox Printer Support
Feb 27, 2014 | Xerox Phaser Office Equipment & Supplies
I need need a picture on how to remove a paper jam in xerox 4118 machine right now please
Well open the printer where you can(the closest point to the jammed paper) attempt to remove the jam by attempting to pull the Jamed paper in the direction it would normally exit the machine.thats about as far as I can get you with the information I have--Good Luck.
Feb 01, 2013 | Xerox WorkCentre 4118 Network Kit - 1 x...
Paper james at the fuser, i replaced the fuser but it still jams
Try resetting the nvm settings (Pag 3 of the attach PDF under Support Menu >> Service tool Menu) And the next time you try to print configure correctly the paper settings on the printer and on the print driver. Please make sure your are configuring the paper weight correctly so that the fuser applies the right heat and pressure.
Aug 30, 2010 | Xerox Phaser 7300DN Laser Printer
Paper Jam cleared but?
It sounds like the paper sensor in the paper try is broken or jamed. Remove the paper tray and locate the paper sensor. Check if it is jamed in the up position or if it is broken.
Jan 21, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
I have xerox workcentre xd105f, can't make copies, paper jamed and letter P on display
to remedy the P display error remove the paper tray and take any paper from under the tray and between the rollers, clean the rollers with alcohol or an acetone solution to remove paper dust and paper debris, refit the paper tray with the paper pushed below the tabs on the tray ensuring that the correct paper size is shown, IE: ltr ltr-r etc.
power the unit off and on and you should be back in business.
If this remedies the problem please rate the solution accordingly
thanks
Derek
Jun 19, 2009 | Xerox WorkCentre XD105F Laser Printer
MF5750 All-In-One Laser Printer DOES NOT PRING indicate paper jam I check and there is no paper jamed in the printer. It starts as it will pull the paper to copy document and then indicates in the display...
It starts as it will pull the paper to copy document and then indicates in the display that the paper is jamed.
Can anyone explain what the problem my be?
Please assist me.
Jan 19, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Xerox 7750 - Jaming in fuser
Solution 1: There is probably a very small piece of paper caught in the fuser, remove it from the machine if you can and try manually feeding paper through it.
Solution 2: Try different paper. The paper may be too weak to pass through the hot fuser, and this doesn't matter you are always using the same paper company, sometimes they change their suppliers.
Follow the link below and good luck.
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=299,E=0000000000024640321,K=7426,Sxi=18,Case=obj(20159)
Also check this link if there is a grinding noise as well as the jam.
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=299,E=0000000000024640321,K=7426,Sxi=18,Case=obj(21995)
Dec 04, 2008 | Xerox Phaser 7750DN Laser Printer
Printer problem
Are you getting any fault codes?
There are several things I can think of off hand. But with a fault code I could narrow it down for you.
Thanks
Nov 29, 2007 | Xerox Phaser 8400 Laser Printer
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
