Question about Beats By Dr Dre 9000006701 Beatbox Portable - White
My baby got some soup through the little holes on the front. Is there anyway I can remove the front and clean inside?
Turbochef Tornado EC cooling fan ALWAYS runs at full speed
What jim said is right. plus clean the front vent. take off bottom front panel and clean all the little round holes. also if its dirty inside everything runs hotter(which makes the EC get warm faster) and dirt gets on the little wire(it's about 4" long coming from the main 40 pin connector0 that monitors the EC temp(clean it). sometimes the fan starts to get weak and doesn't cool properly. also, unplug oven, take side panel off and clean it as well. there are vents on it that get clogged. while it's unplugged clean the inside. I use a paint brush and shop van. just be careful not to hit wires or knock wires off. this will all help a bit but that fan will still run a lot anyway.
Apr 21, 2014 | TurboChef TORNADO Electric Oven
I need info on how to build inexspensive rocket stoves for emergencys. Thank you
Here is a great step-by-step process posted recently on Instructables:
http://www.instructables.com/id/How-to-make-a-Rocket-Stove-from-a-10-Can-and-4-So/
Summary:
1. Mark and cut hole in No. 10 can
2. Mark and cut hole in a soup can
3. Cut the bottom off a 2nd soup can and fit in the first as an elbow
4. Cut and fit the chimney from soup can #3
5. Cut a hole in the No 10. can for the Chimney to go through
6. Assemble and fill the space between the 3 soup cans and the No. 10 can with insulation material, like Perlite.
7. Make a fuel shelf with soup can #4 that sits flat inside soupcan #1
8.stuff in some kindling, light and enjoy!
Note: a similar process could be done with bigger cans or other materials.
Dec 23, 2012 | YouTube Videos
How do you remove the filter on the back of a VRT Steam Samsung washer?
Actually there should be a little door you can access at the bottom front to clean out your pump filter, I'm including my washers pictures. 1) You first open the little door at the bottom. You do not need any tools, just something to drain the water in to. 2) Unscrew the hose closure, put your hose down into the drain bucket. Drain all the water out, you may have to empty the bucket so you can get the hose lower next time. 3) Next unscrew the filter itself. Get anything out inside the hole, in my case it was a toothpick, I take a paper towel and dry out any grit or hair. 4) Put your hose closure back on, it is held in a clip, Then screw the filter back in. That's it. I would also recommend cleaning out the drawers that hold soap, bleach and fabric softener. Also clean around the rubber ring, it will help your washer last longer. lanijo58_3.jpglanijo58_2.jpglanijo58_1.jpglanijo58_0.jpg Hope this helps you
Jun 02, 2011 | Samsung WF448AAW 4.5 cu. ft. Front Load...
I have a Kitchenaid superba convection/gas oven model KGR1607hblg (?) I had soup overflow from the top burner and now the burners will not ignite. When turned on they will spark but nothing catches.
Make sure that all the soup was cleaned out of the little holes in the burner that the gas comes out of. You can use a toothpick or some other small object like that to try to clean them out
Mar 23, 2011 | KitchenAid Ovens
Trying to remove the headrests from the front seats of a 1998 Buick Regal LS. Want to remove old sheep seat covers for cleaning. Can't find any release. There is a small hole in the back of each plastic...
THERE MAY BE O LOCKING MECHANISM INSIDE! TRY USING A SMALL HARD WIRE, LIKE A LONG ALLEN WRENCH THAT WILL FIT IN THAT HOLE! IF THERE IS ONE THERE, YOU SHOULD BE ABLE TO RELEASE IT WITH A LITTLE PRESSURE TO UNLOCK THE HEADREST!
Mar 01, 2011 | 1995 Buick Regal
How do you clean the burnt on food inside the base of a crock pot with a removable crock?
I have the exact same problem! I cooked soup that slowly boiled over the edge and burned inside the base. I know you can't soak it and I don't want to ruin it. Help!
Oct 04, 2010 | Nutritionist 10 Cup Rice Cooker RA10NR
The ac is dripping inside the room
Hello.
You need to clean out the drain pan.Also unit shold be tilted back a little so water will run outside.
Remove the front grill and using an old tooth brush clean out the bottom pan where water is laying.Also be sure the drian hole outside the unit is clear.
May 27, 2010 | Panasonic CW-C100AU Air Conditioner
LG LWHD8000RY6 water leak -- gathers inside on the bottom and by the radiator
This may be due to two things, unclean unit, glugged drain holes…an easy way to do this is to pull the front vent off and see inside and see if you can caulk all around the inside and seal up the front by the vent so the water is forced out the front vent [you need to drill a little hole in the lower section of that front vent after you clean the unit and caulk the inside]
Look to see if the drain holes are clear and the water coming out from them either from the back or the bottom…I am not sure how much work you need to do but you may think about installing a hose to it to drain the water out better than the small hole in the back or front…make sure that the unit is little tilted to the side that you have the vent hole at…
This unit discharge lots of water during heat humidity, etc. or dirt built up on the condensing unit on the back, so cleaning may be with vacuum, water pressure, or just by hand, it is up to you… let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Sep 11, 2009 | LG Heating & Cooling
NO WATER OR SHAMPOO
They loose there prime on the pump when not in use. You can call custmer support on how to do it exactually right but here is how I do it. Take off front nose on the unit. Take off the water tank. Turn on and let it run for 1 minute. Turn off and put water tank (with liquid in it) on the front of the unit, under the nose that you removed. Perfect fit but looks odd. Turn on let it run for 30 seconds and test( push Spray button). When it starts working remove and put back tank and nose cover.It should work as the pump is now primed.
I had the same question 4 months ago and called Bissell.
Jun 23, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Delonghi EAM 3400 keeps saying "Empty Grounds Container"
I think the microswitch that sensors the front door is not activated. Try to find it and "give it a massage" The machine resets the counter for the grounds container every time the door switch is activated.
Rgds
Michael
Dec 19, 2008 | DeLonghi Esclusivo Magnifica ESAM3300...
Beats By Dr Dre 9000006701 Beatbox Portable - White Logo
Top Beats By Dr Dre Sport & Outdoor - Others Experts
Bill Eager
Are you a Beats By Dr Dre Sport and Outdoor - Other Expert? Answer questions, earn points and help others
