Question about Roundup Garden
How do I get the lid off round-off sprayer?
Just don't know if I turn lid or pull off?
2 Suggested Answers
Naimad
  • 5 Answers
SOURCE: How do I take the lid off of a round- up professional sprayer
Most of the times you have to "unscrew" the lid. Try grabbing it firmilly on the black part with one hand and with the other on the body "white part" and unscrew
Posted on Jun 06, 2018
Cannot turn key to open bonnet on a 2002 ford focus
Bonnet meaning the trunk? Shoot some white lithium grease into lock. Push down a little on trunk lid while you jiggle key while turning. If doesn't work,let the rear seat down and pull the inside trunk release tab and check it out. don-ohio (:^)
Nov 13, 2016 | Ford Cars & Trucks
How to change the Vss on a 2005 Chevrolet Upander?
To change the license plate light bulb on a 2005 Chevrolet Malibu sedan reach the bulb socket from the inside of the trunk lid. The socket turns a 1/4 turn or so and pulls out. Bulb just pulls straight out of the socket, don't turn it.
if you need a ecu chip tuning tool you can click here: ecu chip tuning tools
hope it can help you and good luck
Nov 08, 2012 | Cars & Trucks
Printhead cartridge jams
Hello, sorry took so long but, seems to be a paper jam or loose ink cartridge, open lid with unit unplugged and try and see any paper jammed in rollers or pieces of paper, then with that done and hopefully fixed but if not, close lid and turn unit on then open lid to access print cartridges make sure they are installed right and the right ones in the right slots if the cartridge unit don't move so as to load cartridges in try to gently pull it to position as a cartridge may have not been locked in or jarred loose.good luck hope this is of some help.
Dec 09, 2011 | Kodak   ESP5250 Es Printer
Washer does not drain or spin. don't know how to release the plastic release latches to access the lid switch.
On that stack washer/dryer the wayto get to lid switch is
remove diagonal panel between washer and control panel
in the back of washer top will either be 2 brass colored clips or in the very back egde of top will be 2 5/16th inch hexhead screws
for clips place a small screwdriver in front of that clip and pop clips off and slide top forward
for the screws remove screws from behind top in the left/right corner..pull top forward a bit and lift up a little the plug for the lid switch will be in front right side..squeeze the release for that plug,unplug swicth plug then remove top
in both cases lid switch asm. will be on right side of top on the underpart of it
Gene
Aug 23, 2011 | Whirlpool LTE5243D Top Load Stacked...
I have the dish drawers which are leaking from a hose behind the system. I need to replace the hose but I dont know how to take the entire unit out and /or take a drawer out to get back there. Thanks, Brad
Are you sure it is a hose?
Remove the bottom drawer and you can see every thing .Here's the procedure. Very simple and clever design.
Pull bottom drawer out part way.
Look for a large slotted plastic "scew"on each side top corner.
Remove both with 1/4 turn.
You can now pull drawer all the way out ,lifting slightly as you go. It will disengage from rails.
Don't go too far as you'll see the "umbillical".
You can now actually see alot inside.
You can actually run the top drawer with bottom drawer out to watch for leaks,check hoses etc
There's a good chance your lids are leaking ,not hoses .To fix, replace lid actuaters while your in there.
Hope this helps
Aug 15, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Kenmore model 70 washer will not empty tub with lid closed.
This is a broken lid switch . You can replace the lid switch or if you need to get it working quickly you can bi pass the switch by unplugging the washer, removing the 2 lid latch screws, pulling out the switch cutting the 2 wires and twist them together with a wire nut.
This is assuming you do not have the self locking lid.But I don't think your model has that function.
May 14, 2011 | Kenmore Washing Machines
My Estate washer will not drain.
Hey Don, If you removed the cabinet to get to your pump, you had to unplug the wire that connects to your lid switch. Did you make sure to plug the lid switch plug back into it's plug-in on top of your cabinet under control panel when you re-installed the cabinet. Your washer won't spin or pump water if this is the case. I'd check that first, then check the lid switch itself for proper operation. Happy to help, Tim. please don't forget to rate my help. Thanks.
Jun 28, 2009 | Estate TAWX700JQ Top Load Washer
1997 Convertible BMW 318i top roof storage wont open
Hi, I don`t know the car but sometimes when you can`t open a boot lid someone need to push the boot lid down ( this relase the pressure of the latch system)and the same time someone pull the handle. Hope that helps.
May 28, 2009 | 1997 BMW 318
Don;t know how to flip the back seat down
Open the trunk, there should be a black button on the driver's sid; pull it out. Don't close the trunk lid as this will push in the button. On the rear sea, drivers side, there should be a leather loop, it might be hidde between the seat and the inside moulding, puul on it and the seat will release.
May 25, 2009 | 1985 Volkswagen Cabriolet
Garden Logo
436 people viewed this question
Top Roundup Garden Experts
Mike
Matt Olenzek
Matt Olenzek
Are you a Roundup Garden Expert? Answer questions, earn points and help others
