Question about Royal EZ-Vue Calculator
How to install ink roll - Royal EZ-Vue Calculator
  • linda starr
    linda starr Apr 27, 2015
    Nevermind. Figured it out myself.
How do i install ink cartridge in royal alpha 1000ml
There is NO ink in your cash register.
Your cash register has a thermal printer that prints receipts for the
customer or a journal tape. Use 2ΒΌ inch (57.5 mm) wide standard thermal register paper. Do not use bond paper because the register does not use a ribbon or ink for printing.
See installing paper roll on page 13 of the manual
Royal 1000ML Instruction Manual
Nov 24, 2013 | Royal Office Equipment & Supplies
Installing ink cartrage in a royal 435dx cash register
1. Open the printer compartment by lifting the black, plastic printer cover.
2. The ink roll is found in the front of the printer compartment, just behind the print
head, and is mounted in a plastic cartridge.
To remove, grasp the small clip on the left of the ink roll (where the words "PULL UP" may
be printed on the ink roll cartridge) and pull up.
The ink roll will easily pull up and away from the print head.
3. To replace a new ink roll, insert the ink roll according to markings "L" (Left) and "R"
(Right) by pressing downward to lock it into position, then close the printer cover. No tools
are necessary.
For best performance, store unopened ink roll package in a cool, dry place until installed.
NOTE: Replace with ROYAL Ink Roll, Part #013109.
Nov 16, 2010 | Office Equipment & Supplies
Changed rolls of labels on Zebra GX 420T and now nothing prints
Were the new labels thermal paper? Thermal printers need specially made paper to work right.
May 28, 2010 | Zebra LP 2844 Thermal Printer
Ink levels show emptry.
Need one plastic plate that you don't care much about, or a plastic disposable plate.
Tear off one section from a paper towel roll and roll it up into about a 1-inch diameter roll.
Flatten the roll
Soak the flattened roll in warm water
Lay the flattened roll down on the plate
Place the nozzle area of the ink cartridge directly against the wet paper towel
Fold the flattened roll as needed to support the ink cartridge so it stands upright.
The trick here is to make sure the cartridge is supported upright so the nozzles come in full contact with the wet towel surface.
The wet towel acts as a wick to soften and draw out the ink.
After awhile, you shoudl see a kaleidoscope of colors on the paper towel. This indicates the nozzles have been opened up and the ink is flowing. Try to print and see what happens.
Repeat as needed.
May 21, 2010 | Dell 926 All-In-One InkJet Printer
Don't have a manual. How do I replace the Ink
You can download the complete user manual which has the detailed instructions to replace the ink roll by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view this manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Mar 17, 2010 | Sharp EL-1801P Calculator
How do I reink the Dymo DateMark Stamp
You have to remove the ink roll door, on the front left near the bottom. Pull the roller out with a tweezers, add a few drops of ink to the roll and re-install. No matter how careful you are, you will get some ink on your hands...
Jun 22, 2009 | Dymo DateMark Date/Time Stamper
241.10 paper jam
Um I don't know what the other guy is saying since your paper jam has nothing to do with where he is telling to look...
From the service manual:
Error 241 subcode 10:
Page was not properly picked from tray 1.
Possible Causes:
Failure to feed possible causes include:
• Edge locking
• Worn or contaminated pick tires
• Overfilling of tray past the fill line.
Action:
Fan media.
Turn media over.
Reduce amount of media loaded in tray 1.
Replace pick tires.*
To replace pick tires:
Integrated tray autocompensator pick roll assembly removal
1. Remove the integrated tray, and look underneath the printer for the autocompensator arm. Pull the arm
down.
2. Press on the end of the tab (A) and pull the pick roll off the arm. Repeat this step for the pick roll on the other side. Next, gently release the autocompensator arm. Discard the used pick rolls.
Installation
1. Remove the new pick rolls from their packaging.
2. Pull the autocompensator arm down. Locate the recessed area on the pick roll, and align it with the tab on the arm. There are two arrows on each pick roll. Make sure the bottom arrow faces you as you align the recessed area with the tab.
3. Push the pick roll onto the arm with the tab aligned. Repeat this step on the other side to install the other pick roll.
4. Gently release the autocompensator arm. Insert, integrated tray.
Thanks and please take a moment to rate this solution as fixya.
Feb 04, 2009 | Lexmark T640 Laser Printer
How to install the new ink
I think on this one it takes a small ink roller that snaps in palce in the upper left of the printwheels. I think the ink rolls are purple on this model amd I right???
Jun 23, 2008 | Canon P23-DH Calculator
New ink roll in Philips fax Magic 2
Have just tec support (10p per min robbers !!)
Here is what you do
OPEN MACHINE
WITH THE NEW INK FILM IN, ROLL THE INK FILM ON ROLLER NEAREST TO YOU FORWARD UNTIL ALL THE SILVER STRIPS TO THE RIGHT ARE NO LONGER VISIBLE (THIS IS THE BAR CODE ON THE INK ROLL IT'S SELF)
REMOVE INK FILM FROM MACHINE
CLOSE MACHINE
TYPE IN OK 45 OK 7117 OK (THEN IT WILL ASK IF YOU ARE SURE) YES (CHANGE WITH < > BUTTONS BETWEEN OK BUTTON )
SET TIME AND DATE
OK
OPEN MACHINE
PUT INK FILM BACK IN
CLOSE MACHINE
YOUR DONE LOVERLY JUBBERLY !!!
HOPE THIS HELPS AS IT DROVE ME MAD Rob
Apr 04, 2008 | Philips PPF-531 Plain Paper Thermal...
How do i take out the ink thingy
You will need: 1 Replacement ink roll - Porelon PR42 Ink Roll (This roll will replace the black and red ink all on one roll) Available at OfficeMax or other supply stores.
You must first remove the clear plastic cover on top of the calculator (where the tape comes out). Remove the old ink roll. You will see on the roll where it says "pull up". It will pop out easily. Replace it with the new ink roll, it will just snap in place. Replace the clear plastic cover. It should now be ready to go!
Mar 28, 2008 | Casio FR-2650Plus Calculator
Royal EZ-Vue Calculator Logo
74 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
