My landlord has an older Duomatic /electromatic / climate control Furnace. He is looking for a schematic to see if it can be repaired. Any help would be appreciated'
This is an older furnace and does not respond to the thermostat. The fan does not shut off. He needs a schematic for his furnace guy to repair. There is no model # anywhere on the furnace. And thank you if you have the info he needs. I live in Sooke B.C.
    Top Expert:
  • 10,875 Answers
Posted on Apr 25, 2015
Olsen Duomatic Ultramax1980s a/c comes on, outside unit runs but the furnace blower runs slowly for three seconds every minute or two. hoping it was just the capacitor,Does it have a capacitor?
It doesn't sound like the capacitor. If it would be,it wouldn't start. You might try to cheat and change the speed by changing the speed by exchanging wires
Jul 16, 2017 | Heating & Cooling
97 Buick Regal climate control
Hi Levi, Im AL the owner of Big As Auto Repair.
Levi, If you have the same climate control, then below is a link to a repair video for your climate control. Sorry, this is the part 3 video, look a the side to find the part 2 video and watch it first.
1997 03 Buick Regal climate control display repair part 3
Jan 09, 2015 | 1997 Buick Regal
Per landlord, need to light pilot
You would smell the gas, so you're probably ok. Lighting the pilot is not too tough, first you have to get the cover off the furnace. Inside you will see pipes and parts. Hopefully on the cover, inside or out, or somewhere inside the furnace will be instructions.
If not, find a knob that has 'pilot', 'off' and 'run' or something like that. It will probably be in 'run'.
Usually, you have to push the knob down and turn it to get it to the 'pilot' spot. When you do, have something to lite the pilot, which will be inside the furnace more, near the burner. The burner looks like a gas stove or oven burner. The pilot place will be at the end of a small tube.
With the button held down, wave something burning around the burner area. especially at what may be the pilot. The pilot doesn't put out much gas, so don't worry about things blowing up.
Once the pilot has lit, hold the button down for a while, at least a minute. Then you should be able to release the button and the pilot should stay on. If it doesn't, you need a serviceman to come. Let the landlord know the pilot would not stay lit.
If the pilot stays lit, move the knob to 'run' or such, and the furnace should lite, if the thermostat is set higher than room temp. If it has been off, and the room is cool, it should lite.
If the furnace doesn't come on, let the landlord know.
Most landlords have service people for this, it was my job for a long time. Lighting pilots was a common chore for me. If you can, have the landlord send one out to show you how to do it.
As you see, it's not all tough, but it's not all easy, either.
Nov 29, 2013 | Heating & Cooling
WHERE IS THE BLOWER MOTOR RESISTOR LOCATED ON A 2006 EDDIE BAUER EXPEDITOIN? mY A/C AND HEAT WILL ONLY BLOW ON THE HIGH SETTING. IT HAS CLIMATE CONTROL AND DUAL CONTROL FOR THE DRIVER AND PASSENGER...
I found this wiring schematic at: http://www.f150online.com/forums/articles-how-tos/385953-replace-04-08-fan-blower-motor-resistor-emtc-hvac-3.html
It looks like it is located under the dash on the passenger side, and appears to be pretty close to the blower motor. The resistor or controller is different if you have a climate control system vs. a manual temperature control.
Here is a possible picture of the climate control module:
121889953
Apr 08, 2011 | Ford Expedition Cars & Trucks
I have an Intertherm furnace that now will not turn on....Its a gas unit..electronic ignition,,, and from what I could read on the furnace..the model number is G2RR050C12...geez..I hope thats...
The filter is in the bottom of the furnace. Turn T-stat off and go to furnace. Unplug furnace. Top door comes off first, pull up on top door then out and down, set aside. Bottom door lifts up and then out. There is ur filter at the bottom. azeddysac@yahoo.com change ur filter then hit me back
Nov 06, 2010 | Intertherm Heating & Cooling
2000 jeep grand cherokee limited with climate controle and 6 cyl. the ac blows cold on the driver side and hot on the passenger side.
If you have duel climate control, it sounds like the blend doors inside the heater box have broke. It is a rather large repair to do. If you don't have duel climate control, look for a broken, leaking or aged vacuum line under the battery try. Hope this helps.
Best of luck
Jun 16, 2010 | 2000 Jeep Grand Cherokee
Intertherm Furnace - Blower cycles on and off (varies in length)
Its still hard to say from your info...does it seem that the furnace is running a normal cycle except for the fan???...could be a wiring problem , circuit board/relay problem , or fan control problem....really the make and model of the furnace and age would help ....could be several things....does it heat your house to the correct setting??
Oct 29, 2009 | Heating & Cooling
Need blower motor schematics and / or schematics for a york Controller #031-01267-001
you will need the model of the furnace not the part # of the board. is the schematic not in the unit?
Sep 25, 2009 | Honeywell Power Humidifier: Furnace...
Colman furnace
look on your burner control relay - look for terminals marked T and TH.  connect up a honeywell thermostat here.
Oct 03, 2007 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
225 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
