Question about Maytag Washing Machines
What would cause the washing machine to start running when water was added to it ? Now it won't run a cycle
I have added water from my dehumidifier numerous times this has never happened before. I unplugged it for 24hours and when I plugged it back in it started to make the noise again.
    Top Expert:
  • Maytag Master
  • 10,875 Answers
Why are you putting water from a dehumidifier into a washing machine??? you might need to talk to a professional
Posted on Apr 25, 2015
Holding water
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
Washer won't spin
Good Day,
Avanti washer repair
Good Day,
Nov 01, 2013 | Washing Machines
Machine lacked about 23 minutes in cycle, it stopped with lights flashing. It will not drain, therefore cannot spin. It just beeps whenbi try to start it again.
Good Day,
Nov 01, 2013 | Whirlpool Cabrio Washing Machines
Machine stopped in mid cycle with the drain/unlocking light on. No error codes. Machine goes directly to the drain/unlocking position after start. Will not fill, spin, operate. Any ideas?
Good Day,
Nov 01, 2013 | Whirlpool WFC7500VW Washer
I have an Electrolux ESL6115 dishwasher model and although there is water coming out and the spray blades seem to be turning the dishes are always wet after the cycle has finished and there appears to be...
Its possible that if you live in a hard water area that limescale buildup is causing this problem if salt levels got low. The first thing that can be done is to run it with 2 or 3 cups of vinegar added & see if it cures it. If it won't accept opening the door to add this after wash has started then add it in a wide dish to catch water & wash it out during cycle. Adding a dose (half cup) of bicarbonate of soda alongside should work even better. This has worked really well for washing machine about to give up on & do regularly to prevent problem. Hope this helps.
Apr 28, 2011 | Electrolux 23 in. ESL6114 Built-in...
Machine keeps overflowing during wash cycle
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Water inlet valve
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
May 20, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Can I set my dehumidifier to turn cycle on and off while I am traveling
Normally a dehumidifier will run based on the humidity found in the air in the room it is located in, although many can be set to run all the time.
I don't believe your model can be set to run next Tuesday, Wednesday and Thursday because you will be home and th NOT run next Friday and Saturday because you will be traveling, for example.
Your machine should run on automatic until the bucket fills with water at which time it should stop running until you empty the bucket. Many buckets offer the feature of adding a drain hose you can run to a drain somewhere. Some people have a floor drain they use for such purposes. Others I have known sit the device on the counter and drain into a sink or in the bath tub and drain that way.
For best dehumidifying results, you should run your machine all the time.
I hope I have answered your quesiton. Thanks for considering FixYa.com
Jan 06, 2010 | Frigidaire FDL50R1 Dehumidifier
Face Clothes and Towels are smelling bad after being washed and dried in my Kenmore HE3 washer and dryer. Have tried running an empty cycle with bleach only, washed small loads with hot water, pre-wash and...
Try running an empty heavy duty wash cycle with a pint of vinegar added to the water, run wash cycle for two or three minutes then turn the machine off for thirty minutes then restart and let finish the full wash cycle
Aug 02, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
35 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
