Question about Garden
Tines clear of debris ,won,t turn by hand .when switch is on no response
    Top Expert:
  • 10,875 Answers
Take apart the transfer case and find what is binding
Posted on Apr 25, 2015
Tiller runs great just having a problem with the tines turning plowed my garden last week and for some reason the tines quit turning like its locked or something please help me
Two possibilities. Something has jammed the tines.
Pull the spark plug wire off and tuck it away someplace so as not to touch the plug.
Tip the tiller up and examine the tines for obstacle such as a rock. If there is nothing jammed try to turn the tines by hand. If the they turn freely you most likely broke a shear pin that secures the tines to the axle.Clean the axle and tines and examine very closely for the pin.
If sheared ( broken) you will need to drive the broken piece out and replace the pin.
There may also be a problem in the transmission case. You would need to remove the tines and case to open it
Apr 01, 2016 | Garden
Why did my tines stopped working
Hello, Did you notice if the tines moved when you turned the belt pulley to install the new belt? If the tines do not move when you rotate the driven pulley by hand, the worm gear might be stripped. If the tines do move when you rotate the driven pulley by hand, the belt tensioner might not be working properly. It could be as simple as an adjustment.
Aug 28, 2014 | Garden
Tines
Either clutch is bad or teeth are striped in bottom gear box. remove tines run engine and see if you can feel movment in lower gear box, if yes the gears are gone. If no remove engine to expose clutch.
May 20, 2013 | Ardisam Inc Earthquake Mini Cultivator
Engine won't turn over
take out the spark plug and pull it over until it clears out
Apr 30, 2012 | Garden
Own an older (1990's) American Yard Products model WER500 Weedeater rear tine rotortiller. The engine runs great but when I engage to til, the tines won't turn. The belt is fine and pulleys turn...
Yes, there are shear pins on the tines and on the wheels. Can you check to see if the belt actually moves when the pulleys turn?
May 13, 2011 | Garden
The tiller won't stay in gear for the tines to turn. It jumps into forward without turning the tines.
Check the wire to make sure that when you engage the tines it is actually engaging the lever. This seems like your are either low on the fluid for the trans or it is stuck in place and will need some good lubrication and turned by hand. You can also with the engine off, engage the tines, and try to turn it by hand. if it turns by hand then the tarns is no good.
Nov 09, 2010 | Yard Machines 21A240M000 Garden Tiller
THE TINES WON`T TURN, THE MOTER WORKS THE TINES WON`T TURN
SOUNS LIKE SOME THING CAME LOOSE IN SIDE THE TRANS
Oct 01, 2009 | Craftsman Garden
Tines will not turn
Find out what drives the tines ei...belt,chain ect... or is there any signs of locking pins missing??
Please rate
Th U
Mar 17, 2009 | Honda Garden
Garden Logo
94 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
