Question about GE 30" Self-Cleaning Freestanding Electric Range - White-on-White
+ pad on control not responig most of the times
Can the control modual be fixed
    Top Expert:
  • GE Master
  • 10,875 Answers
Yes,it costs about 135 bucks
Posted on Apr 25, 2015
My Samsung Microwave model number CE 1111TL is howing a error and at times the keypad doesnt function . What is the cheapest way to fix it .Thanks
The only way possible to see if the touch pads are working is to test the voltage of the control pads when it contacts. The input of the Microprocessor should be checked for the pad control impulse to come in. If there is no trigger voltage to the mP this can be the control pad problem.
The mP must be checked for the working voltage and also the frequency oscillation at the crystal leads. If so the mP is working with a suspected control pads which are not able to set the program or timing.
There is no way but to remove the sticker pad and replace, One difficult way to have a chance is to remove the carbon sticker pads and check continuity , You can use a carbon pen to line the tracks so that the multi-meter reads a continuity. With this you can have a temporary fix
Jan 11, 2013 | Microwave Ovens
1994 XR-7 Since new the car has always done about 27 MPG now Torq. converter will not lock on the highway with or with out cruise control on, mileage at about 20 MPG. Thinking of replaceing transmission...
Before replacing electronics, try a good healthy trans fluid and filter change. A partially clogged trans filter will increase pressures causing your lock-up converter to disengage.
Jan 04, 2011 | 1994 Mercury Cougar
The oven won't ignite. I have had igniter replaced 4 times...why do we continue to get this proble
The model number you provied has a missing number at the end so I am using GS56LXSS0 for this example. This unit is using a spark ignitor instead of a Glow Ignitor.
This system also uses a Spark Modual control board to provide the spark to the spark ignitor. The spark modual is a common part that goes bad and could be your problem and is located in the control area part # 9758080
Note : All the spark Ignitors on your Stove are connected to this spark modual and if any of them are shorting anyware this will cause a problem with the spark modual and the amount of spark given to each spark ignitor.
Dec 19, 2009 | Whirlpool GS563LXSS - stainless Steel Gas...
2005 grand prix, ac fan runs on high all the time
Problem is the inside blower fan, not the raditor fan. T/S to a bad relay on the blower control modual which had to be purchased from the dealer. $274 later it is fixed.
Jun 21, 2009 | 2005 Pontiac Grand Prix
Top burners igniter not working
It sounds to me like the spark modual has gone bad. There is a part that is usually behind the control pad and display for the range and oven. It usually looks like a rectangular black box with wires plugged into it. Thats the spark modual. With any luck it will say spark modual on it. Buy the replacement and then plug the wires in the new one just like they were in the old one. You may want to take a photo or write down where each wire goes before you remove the old part. I would also search online for a break down diagram for your appliance so you know for sure how to get to the spark modual. It is a pretty common replacement part so it shouldnt be too expensive. Sorry I couldnt be more specific.
May 15, 2009 | Magic Chef CGS3760 Gas Kitchen Range
My transmission appears to be slipping from gears
first check the level of the tranny fluid the truck needs to be running and in nutral if you have fluid it is probably the modual,the shift control modual comonly goes out the dealer will tell you you need a new transmission take your truck to a good transmission shop and have them check the modual tighten the bands and flush the transmission I had the same problem and that fixed the problem, the cost was around 350.00 also check to make sure that you dont have any leaks in your tranny lines. hope this helps
Feb 27, 2009 | 2001 Dodge Ram 2500 Truck
LOCKS HAVE A MIND OF THEIR OWN!!
A good possibility is the control panel on the driver's door for the power windows and locks. This is called a modual and they are known to corrode inside sometimes due to water that may drip in when the driver's window is cracked open and it's raining out, or snow melting. They are also known to defect after some time too. To see if this is the problem, remove the "modual" from the door panel and unplug the electrical harness from the modual. If the power locks stop cycling, you will have to get a replacement modual from your local GM dealership or possibly your local parts store like NAPA and such fourth. In the mean time, remove fuse number 14 from the fuse box located underneath the hood in the engine compartment on the driver's side behind the windshield washer fluid tank. the fuse is for all the powerlock motors in the vehicle. This will stop the motors from continuing runnig and draining your battery.
Jan 13, 2009 | 1998 Oldsmobile Bravada
Gas cooktop problems
there is a part in the cooktop called a spark modual. it controls all the ignitors when it goes bad that what it does. replace the modual to fix the problem
Nov 25, 2007 | KitchenAid 31 in. KGCS105 Gas Cooktop
GE 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
