Question about Astar Televison & Video
How do I program an astar tv - Astar Televison & Video
Need the code so that I can program my Direct TV
I just checked online at DirecTV and searched your Astar TV. This is the result I got...
"There is no setup code indicated for your product.
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    1. for Televisions
    2. for "AUX 1" devices - VCRs or DVDs
    3. for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key. "
Feb 11, 2010 | Astar LTV-3001 Television
32"ASTAR problem
Please call 323-767-6030 and I will trying to help you as much as I can for the astar ltv-3201 tv.
Jan 30, 2009 | Astar LTV-3201 32 in. LCD Television
Unerversal Remote Codes
Astar got sued by Philips and went out of business. Astar owned themselves rather then having a reproduction redesign of another set. They were a cheap Chinese company that made stuff for Compusa. I've repaired a couple of their sets and they're easy to work on but a little under built. So chances of matching the remote code up to another tv code will be left to guess and check. On some remotes you can enter a setup where you can press the power button over and over until you find the right one, then press another button such as enter or select to lock it in. See if your manual says anything about code search.
Jun 20, 2008 | Astar LTV-19BS 19 in. LCD Television
Astar 32" lcd tv
Good luck I have tired to locate the code for my astar 30in
Jun 19, 2008 | Astar LTV-3201 32 in. LCD Television
Astar 20
Your tv having the main board defective. please call 323-767-6030.
and I will go through with you.
Feb 09, 2008 | Astar LTV-20PW 20 in. EDTV-Ready LCD...
Code for astar tv
ASTAR LCD TV remote code for directv: 11531, 11548, 11738
The 11738 worked for me!
Dec 06, 2007 | Astar LTV-20PW 20 in. EDTV-Ready LCD...
Astar 27" TFT LCD TV, Model LTV-2701
the power cord is the same as a computer power suply. Can be found at a computer store and its really cheap.
Aug 14, 2007 | Astar LTV-2701 27 in. HD-Ready LCD...
Televison & Video Logo
Top Astar Televison & Video Experts
Jaime Hernandez
Jerry Umali
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
