Question about Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder
Hi. When switch on there is no clock lit up on front and does not switch on. Can hear fan working. Tested 12 v adaptor and no issues.
Used to be my mothers and has not been used since 2011 when she passed away. Unit was hardly used. Many thanks in anticipation
    Habit-Forming:
    New Friend:
  • 131 Answers
When you say that you have tested the 12V adapter, have you checked it under load? This is the most likely cause of the problem, so I suggest trying another suitably rated adapter.
Posted on Apr 28, 2015
Cruise turns off when we roll down the windows
Strange electrical problems can sometimes be attributed to a bad ignition switch. The battery should also be load tested, especially if it is more than 4 - 5 years old.
Dec 03, 2012 | 2004 Chevrolet TrailBlazer
I need a manual and drivers (I think) and some basic information for a Maxtor One Touch 320 GB jlrranch@q.com
there is no manual for this drive and no drivers are required. if not recognized by your o/s check to see if you have the correct adaptor with a green light on the bottom of it. i have 2 of these drives and last week one couldn`t be found, i tried switching usb ports, then tied it on my laptop under vista which used to work, then did a system recovery in cas of corrupted usb drivers or registry. the drive still wouldn`t appear. when i plugged it in i would hear a beep, but somtimes the computer would find it and show it in the devices list, but it showed as a usb mass storage device, but no hdd.
i assumed both adapters for the 2 drives from maxto would be the same, however the drive that works is 12 volts 3 amp. the drive the can`t be recognized is 12 volts 2.5 amps. the green light is on solid and the front drive lights blinking, but i figured nothing to lose so i swapped out the adapters, and voila! my dead drive works like a charm with th 12 volt 3 amp adapter. with the old adapter 12 volts 2.5 amps it sounded licke a clock ticking. now its super quiet. to be sure of any drive damage i moved all the filef to my main drive and formatted it with " full" format. now i have to swap the adapter back to the other drive and pull of the data and reformat it. and buy a new adapter for the other drive @12 volts 3 amps. hope this helps not too confusing.
Dec 31, 2010 | Maxtor OneTouch III 300 GB Hard Drive
My Hp Pavilion HDX9095 won't start at all; (power
Dear John,
do you hear beeps from the laptop? if yes there could a problem with RAM module. if so changing RAM module will solve the issue.
Also try connecting an external monitor. to check if the display is not faulty.
Mar 24, 2010 | HP Pavilion HDX Laptop
87 CBR600 the front brake does not turn on the brake light
Hi and welcome to FixYa,
Initially, check the:
  • front brake light switch at the end of the front brake lever;
  • presence of IGN +12 on the black/brown wire going to the front brake switch coming from the fuse box;
  • presence of brake +12 on the black wire after the switch before the connector, brake +12 on the green/yellow wire after the connector going to the brake bulb socket.
The above assumes that the foot brake light switch works to light the brake bulb and that the brake bulb have been tested good.
Good luck and thank you for asking FixYa.
Dec 23, 2009 | 1987 Honda CBR 600 F Hurricane
2002 envoy 4wd problem. clicking sound comes and
Clicking sound- Possible electronic fan clutch failing. This is a typical problem with the 4.2L I6. When you hear the clicking, open the hood and listen if its coming from the fan clutch on front of the engine. this could also cause abnormal engine and transmission cooling. As for the "N" light and 4wd issue, have scanned at the dealer....Hopefully this helps
Jul 18, 2009 | 2002 GMC Envoy
99 Yukon - Blower Motor Not Working
replace the A/C control head... very simple to do. Pop off the dash panel and pull the control head out... unplug the 3 harnesses and there you go.
Jun 02, 2009 | 1999 GMC Suburban
Hi. My HP nx7000 Notebook does not switch on at all
If you have warranty get it in for a new m/board ok
May 07, 2009 | HP Compaq Business nx7000 Notebook
Canon P170-DH Calculator
CLOCK & CALENDAR FUNCTION
Look for the key with the cal/clock pic on it. Use to switch between calendar or clock mode. It is next to the feed key.
(12/24) Key used to switch between 12 or 24 hour at clock mode.
(Time Set) Key used to set the date and time in calendar & clock mode.
(AM/PM) Key used to switch between AM or PM at clock mode time setting.
(Format) Key used to select date format between "YYYY/MM/DD",
"DD/MM/YYYY" or "MM/DD/YYYY" at calendar mode.
Hope this helps, play with it I figured it out with instruction sheet.
Jan 10, 2009 | Canon P170-DH Calculator
I went through the same thing with my 99 suburban. It turned out to be the dash fan control switch. It is purchased seperate from the whole cluster for under twenty dollars. The instrument panel cover comes off gently by hand with the tilt steering in the down position. You have to then unplug the electrical plugs to get it out of the way. The heater ac control panel then comes out by hand far enough to unsrew the heater fan control from the back.
Nov 30, 2008 | 1999 GMC Suburban
No Beep No Display
motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
Jul 03, 2008 | Intel Motherboard
Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder Logo
108 people viewed this question
Top Sagem Televison & Video Experts
Andy Fraser
Andy Fraser
electracon
ka4iup
ka4iup
Are you a Sagem Televison and Video Expert? Answer questions, earn points and help others
