Question about 1996 GMC Suburban 2500 4WD Front Wheel Bearing & Hub Assembly for 8
Where is the vehicle speed sensor located - 1996 GMC Suburban 2500 4WD Front Wheel Bearing & Hub Assembly for 8
  • Brock Saint Aoro
    Brock Saint Aoro May 02, 2015
    Hi alarkarl9, The VSS is on the transmission I don't know what trans you have so i can't give you exact location right off hand
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 34 Answers
Usually the vehicle speed sensor is located in the tranny!
Posted on May 20, 2015
Speed sensors located on motor
Lorraine, speed sensors are not located on engines. there are transmission speed sensors and wheel speed sensors.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Speed sensors locations Google Search
Vehicle Speed Sensor Location
vehicle speed sensor VSS
wheel speed sensors Google Search
Apr 08, 2016 | Cars & Trucks
What parts have to be removed to change output speedsensor on 97 sebring convertible jxi?
Hi Nicholas, Im AL the owner of Big As Auto Repair.
FRONT WHEEL SPEED SENSOR
REMOVE
  1. Raise vehicle on jack stands or centered on a frame contact type hoist. See Hoisting in the Lubrication and Maintenance section of this manual, for the required lifting procedure to be used for this vehicle.
  2. Remove the tire and wheel assembly from the vehicle.
  3. Remove the speed sensor cable routing bracket Speed Sensor Cable Routing Brackets from the steering knuckle. Remove the wiring harness sealing grommet retainer and speed sensor routing bracket from the inner fender.
  4. Remove speed sensor sealing grommet from the inner fender Wheel Speed Sensor Connection To Vehicle Wiring Harness Then unplug the speed sensor cable from the vehicle wiring harness Wheel Speed Sensor Connection To Vehicle Wiring Harness
  5. Remove bolt Speed Sensor Head Attachment To Steering Knuckle attaching the speed sensor head to the steering knuckle. Then remove speed sensor head from steering knuckle. CAUTION: If speed sensor head locating pin has seized to the steering knuckle, do not attempt to remove speed sensor head by grasping with pliers and turning. This will damage the speed sensor head. Use only the following procedure.
  6. If speed sensor head can not be removed from steering knuckle by hand, the locating pin on the speed sensor head has seized to the steering knuckle do to corrosion. Remove speed sensor head from steering knuckle using the following procedure. Remove disc brake caliper from steering knuckle, and remove brake rotor from hub/bearing assembly. Then insert a pin punch through hole in front steering knuckle Speed Sensor Head Removal From Steering Knuckle and tap speed sensor head locating pin out of steering knuckle.
Hope this helps and please visit my auto-repair-website at:
http://www.bigasautorepair.com/
Oct 08, 2015 | Cars & Trucks
Where is speed senor on a Hyundai Sonatas
Hyundai VSS locations:
On 1999-2003 vehicles, the vehicle speed sensor is built into the speedometer. On 2004-2005 vehicles, the vehicle speed sensor is attached to the output shaft of the transaxle.
On 1996-2003 vehicles, the vehicle speed sensor is built into the speedometer. On 2004-2005 vehicles, the vehicle speed sensor is attached to the output shaft of the transaxle.
Hope helps (remember rated this).
Jul 14, 2010 | Hyundai Motor 2004 Sonata
Where is the speed sensor located at on a 91 Honda Acoord?
1991 Honda Accord 2.2L FI 4cyl the Vehicle Speed Sensor is located mounted on transmission.
Hope help with this (remember rated this help).
May 11, 2010 | 1991 Honda Accord
Where is the speed sensor located?
The vehicle speed sensor is located below the air cleaner assembly, it is held in with one bolt (I believe 10mm):
  1. Remove the bolt and vehicle speed sensor assembly.
  2. Remove the clip and speedometer driven gear from vehicle speed sensor.
  3. Remove the O-ring from vehicle speed sensor
  4. Coat a new O-ring with ATF and install it to the vehicle speed sensor.
  5. Install the speedometer driven gear to the vehicle speed sensor and clip.
  6. Install the vehicle speed sensor assembly and torque the bolts. Torque: 16 Nm (160 kgf-cm, 12 ft. lbs.)
Mar 23, 2010 | 1999 Toyota Camry
Where is the wheel speed sensor located on a 2001 pontiac grand
2001 Pontiac Grand Am 2.4L SFI DOHC 4cyl
Vehicle Speed Sensor - Location:
The speed sensors are built right into the wheel bearings of your vehicle, at the front and rear locations. They work both with the anti-lock brakes and with the traction control systems on the vehicle.
I hope help you with this (remember rated this help) Have a nice day, good luck.
Sep 23, 2009 | 2001 Pontiac Grand Am SE
Location of speed sensor for a 2003 dodge durango
the speed sensor for this vehicle is actually in the rear differential of the vehicle. this is the sensor that runs the speedometer also known as the vehicle speed sensor. there are also two speed sensors in the front one on each wheel known as wheel speed sensors these are for the abs system only
May 17, 2009 | 2000 Dodge Durango
Location of speed sensor a for 99 dodge intrepid
The "Vehicle Speed Sensor" signal is generated by the transmisson output speed sensor. That is the one located at the rear of the case. It is externally mounted. That supplies "vehicle speed" info to the other On-Board Computers. The input turbine speed sensor is located just behind the bell housing area of the case. I believe the trans controller is the only module that needs that info. The Crank Position Sensor give engine RPM info and it is located on the bell housing near the engine block. I hope this helps.
Mar 29, 2009 | 1999 Dodge Intrepid
2005 ToyotaCamry fault code P0500 Vehicle Speed sensor Malfuction
They are not the sensors you want. The car uses the abs wheel sensors for vehicle speed. Your problem lies in the abs system , possibly the left front sensor, abs ecu or speedo cluster, Clear the code and see if it stay out otherwise you'll need to go to a trusted technician. .
Mar 13, 2009 | 2006 Toyota Camry
1996 GMC Suburban 2500 4WD Front Wheel Bearing & Hub Assembly for 8 Logo
Top 1A Auto Parts Vehicle Parts & Accessories Experts
Tom
Mike Stager
Mike Stager
Are you a 1A Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
