Question about Toro Garden
Replace AC49 spark plug witha champion plug number
Toro leal blower
  • Toro Master
  • 1,169 Answers
.Autolite B7...Bosch 7808, WR12EC...
Champion 592, 592M, J12, J12C, J12J, J12JM, J14, KJ12, QJ12, RJ12, RJ12C, UJ12, XJ12, XJ12J
Posted on Apr 25, 2015
  • Toro Master
  • 4,526 Answers
You either have an incomplete number for your AC spark plug or it is a very old, unusual or obsolete type because there are no equivalents for that number.
I suggest instead of trying to find an equivalent you should use the make and model number of your appliance and buy the recommended spark plug from the application catalogue of your choice. I am not fond of Champion plugs for no particular reason and prefer NGK.
Lawnboy model 10415 serial number 5901752 correct spark plug
Joe, Factory Lawn Boy SPARK PLUG 614009, replacement plugs champion CJ14, NGK plug # BMR4A.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Boy 10415 Lawn Boy Gold Series Walk Behind Mower 1995 SN 5900001...
614009 Spark Plug
Which spark plug for Lawnboy engine
https://www.shoplawnboy.com/Comergent/en/US/adirect/Toro?cmd=ToroLBOnlineModelLookup
Aug 04, 2016 | Garden
CHANGE SPARK PLUG ON TORO CCR 3650 SNOW BLOWER
First disconnect the spark plug wire from the spark plug. Then use a socket wrench to remove the spark plug. Install the new spark plug into the cylinder head and reconnect the spark plug wire. The Toro CCR 3650 uses a NGK BPMR4A plug gapped to 0.032".
Jan 25, 2016 | Toro Garden
Is a Champion RJ19LM equivalent to a R C J 8Y?
NO I DONT THE SPARK PLUG IS THE SAME PLEASE CHECK WITHA LOCAL DEALER BEFORE USING THIS PLUG
Feb 25, 2015 | Toro Power Clear 221QE Electric Start 21...
Is a champion rcj6y spark plug the same as a champion cj6 spark plug. I have a cj6 spark plug in my blower & replaced it with a rcj6y plug & it hits the piston
You answered your in question they are definitely different..a plug hitting the piston can damage or even break the piston just trying to start the blower...replace it like the one removed..good luck
Sep 24, 2014 | Garden
Toro model 51575. Was using it as a vacuum and it just shut off. Checked breakers ...all ok. Plugged it in direct to outlet and still nothing. What might be the problem?
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers
Apr 06, 2014 | Toro Blowers Rake and Vac - Electric...
What is the correct gap setting for a Champion RJ2YLE spark plug used in a Toro Lawn mower?
Briggs & Stratton Part Number 799876 replaces Champion plug RJ2YLE. For use in Quantum Series 625, 675, and 725 engines built after Date Code 110701xx. The gap for this spark plug should be set to .020". This spark plug should not be used with Quantum Series 625, 675, and 725 engines built before Date Code 110701xx, or any other L-head engine family.
Apr 20, 2013 | Toro Garden
Do you know what the proper Champion part number is for a Toro 51972 weed trimmer is? This was purchased used and it had a RCJ4 Champion plug in it and I just need to verify that this is the correct plug....
that is the correct spark plug for the unit. i work at a power equipment store where we work on homelites. 90% of the time it wont start or run right is usually carb issues . need to get it rebuild or replaced
Aug 25, 2011 | Toro& Electric String Trimmer
Problem is my hardly used Toro Blower Vac is getting no Power
If it has not run for awhile, check the brushes. they might need to be replaced. The plug is usually moulded right on power cord. That might have to be replaced because if there is a problem with a broken or disconnected wire right at plug there is no way to see it. Hope this helps.
Dec 07, 2010 | Toro 51599 Electric Blower 12 Amp
I have a UT08580 Mighty Lite backpacker blower with a missing spark plug, I need to know what plug goes in it.
The Homelite part number for this spark plug is 870174001. This number crosses to Champion spark plug RCJ6Y which can be bought at any Home Depot, Lowes, Ace Hardware, etc for about $3
Oct 20, 2009 | Homelite Consumer Products Backpack...
Garden Logo
110 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
