Question about ESA ET427E 27" TV
Is it possible to connect an HD cable box to this model of television and if so how do I go about that task?
Cable box connections
The model listed has only ONE HD input and it is on the rear and marked DTV--it is a component input with red, green, blue and a red and white for audio---cable box would have to have same outputs on its rear.
Apr 18, 2012 | Mitsubishi WS-48313 48" Rear Projection...
We bought a used Philips 42" flatscreen digital TV with no remove and hooked it up to our cable box. It works beautifully but we have not able to reset the screen size using the side buttons and menu...
Yes there is a trick. Usually the cable box and its remote determines the picture's screen size. First off, this television is able to display hd on an hd cable box. Make sure that this cable box is connected with this television the hd way only. It should only be connected to your television with either a component (green,blue,red, white, red) cable OR and hdmi cable. The coax cable should not be used to connect the cable box to the television if you have an hd cable box. Next make sure the television is on the proper input/source to display the cable box in hd.
Now if all of this has already been done, look for the hd zoom # button on your cable remote. It is usually towards the bottom. When you press it you change the screen size. You can buy a philips remote-the original one for your television at http://www.replacementremotes.com if you need the wide/stretch/zoom/viewmode button to further adjust your picture size.
Jul 16, 2011 | Televison & Video
Problem is: i have an older rca scenium 52" and my newer HD cable wont plug into the older plug in the tv. can i purchase a cable that will take cae of this problem?
By "newer HD cable" do you mean HD cable box? Most cable boxes have a variety of ways you can connect them to the TV. The latest and greatest for newer TVs is over a connection called HDMI. Your TV probably doesn't have that and that could be what you are referring to. The other connections are called component and composite and consist of a number of colored plugs that you just match up. This could be the case but it is possible the cable company didn't provide you with the cables you need. Lastly, you should be able to connect the TV using a coax cable (the kind that usually has a nut at the end).
Mar 11, 2011 | Televison & Video
LC-26DA5U 26 in. HDTV-Ready LCD Television: i connect a hdmi cable 2 my hd cable box - the pic...
The cable box needs to be set to send different signals when using hd tv and standard tv. Usually a good setting would be 720p in hd and 480p in standard. The tv is working fine it is the cable box sending the signal. If you have another hdmi source such as a dvd player you may hook that up to show the tv is working just fine.
May 07, 2010 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
HOW DO I GET THE BLUE BOX ON MY SHARP AQUOS LCD TV TO STOP POPUP
This happens when you are connecting with a coaxial cable. If possible you will need to connect your set top box to the television with a composite/RCA cable and watch tv on input 2 instead of on input tv.
Mar 19, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
While changing channels the picture went dark on video 5 feed but we still had audio. I checked the HD cable box was find confirmed by running its feed thru video 2 with regular picture. I tried video 6...
It can still be your cable box, do you have another hd set to check and see if the hd output is working on the cable box? Seems too much of a coincidence that it happened when you were changing the channel on the cable box, the tv can only show what it is receiving.
Aug 19, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Television Won't Display Certain Cable Shows
Okay,i assumed this is what you have:
HD cable box with HDMI cable connection to the Samsung TV.
Listen careful as follow:
First you want to make sure using the same HD comcast box with HDMI connection for our Samsung TV as well as your other TV.Be sure the other TV do received the missing channels from the Samsung TV.You must be SURE you have tested both TVs with the same HDMI cable with the SAME HD cable box.
Now that you have confirmed the both TVS are using the same HD comcast box and the same HDMI cable but the connection that goes to the Samsung TV are missing some channels,at this point,use another HDMI connection behind your Samsung TV and see if you have the same problem.If so,please also try the left side of the HDMI connection and see if you could get the other channels.
Let me know!
solutiondoct
Jun 15, 2008 | Samsung HP-T4254 42 in. Plasma Television
Apex tv 2024
As long as the New Cable boxes have an analog output they will work fine.
Dec 27, 2007 | Apex Digital AT2002S 20" TV
ESA ET427E 27" TV Logo
Top ESA Televison & Video Experts
Colin Stickland
Colin Stickland
matt martin
matt martin
Are you an ESA Televison and Video Expert? Answer questions, earn points and help others
