Question about Air Purifiers
Like to replace lcd display panel ... how to replace directions please
Power Surge Electrolux double oven EI30EW45JS, now producing F11 code, installed new board, how to reset to see if problem is fixed?
Good Morning Jennifer Lynch, thanks for your post!
I see you have replaced the control board on your Electrolux wall oven and it is displaying an "F11" error code. "F11" stands for a shorted keypad, since you have replaced the board I would recommend resetting your wall oven. You can reset your wall oven by flipping the household circuit breaker off for ten minutes. If you need further assistance please feel free to reconnect. I hope this is helpful. -Matt
Oct 13, 2014 | Electrolux EI30EW45JS | 30" Double Wall...
My display is blank
The front panel (LED) panel needs to be replaced. Depending on where you are, you may be able to send to a local person to repair. The home office/factory offers a trade in at this time or a flat rate of repair depending on which unit you have. I'm happy to help you further. Message me on my site.
Vollara Home
Mar 27, 2014 | Ecoquest Fresh Air Air Purifier
I have problem with my EcoQuest air purifier. The display is unreadabl Its all scrambled it
I am having the same problem right now. Need to replace the LCD screen. Still checking things out.
Dec 03, 2012 | Ecoquest Fresh Air Air Purifier
My fresh air 2.1 won't go into away mode. I
Fresh Air purifiers are noted for two weak points. The display circuit board and the main circuit board. Call (336) 499-2505 and they will help you work through the problem. They give away information.
May 25, 2012 | Ecoquest Air Purifiers
I have a Kenmore Progressive 295 air purifier. I have the model number for the large filter and the dimensions of the carbon filter but, because it is older, can't seem to locate comparable replacement...
Have you looked at Sears' online parts store? Type in the model number, and it will display available replacement parts.
http://www.searspartsdirect.com/
You can also get there from the Sears home page:
http://www.sears.com/
Click "parts direct" at the top of the page.
Mar 10, 2011 | Kenmore 335 CADR Air Purifier
Just cleaned the unit. (Which I have done several times.) When pluging the unit back in I had the lcd display say the unit was in away mode. I pressed the buttons on the front to change the mode to 2500 sq...
Oops. It's possible that the incorrectly inserted plate caused the machine to malfunction. It may need to be sent to the factory so the computerized controls can be recalibrated. Call Vollara (new name for EcoQuest) Customer Service 800-989-2299.
Jan 31, 2011 | Ecoquest Fresh Air Living Air Purifier
Machine has been off for 6 months. Plugged it
If you mean the LCD is only partly showing, it should be replaced. Just sent in two for the same problem with clients. Apparently, supplier switched to cheaper parts, causing this. Should be under warrantee. Call fast. If you never set up the warrantee, you should do that first. I'm "SURE" you bought it less than 3 years ago...Right???? (Hint) 800-989-2299
Sep 21, 2009 | Ecoquest Fresh Air Air Purifier
Front display controls don't work
Sounds like the same problem I had with mine. I had to call and get an RMA number and they replaced the key pad, lcd display, and main board. This repair was covered under warranty. (Under 3 years old) They had it repaired and returned in about a week.
Sep 05, 2009 | Ecoquest Fresh Air Air Purifier
Hunter 730 carbon pre-filter replacement orange light
Filter lights on your Air Purifier http://www.fastbrowser.net/netpicker/Filter-lights-on-your-Airifie.htm One of the best things about your IQAir Air Purifier is that it has warning lights to tell you when to change the prefilter, gas or hepa filters. Of course how long they last depends on your pattern of usage. For the initial 80% of the filter life the control panel will display a green light next to the corresponding filter on the outline of the unit. When the orange light goes on it does not mean that the filter needs to be replaced immediately but that there is 20% of useful life left. IQAir gives you plenty of time and the machine will tell you how many hours you have left. Once the number of hours gets to within a few hours remaining the orange light will then change to red. It is at this time you should change the filter. If you forget to change it and there are no hours left the hours will go into the negative displaying how many hours you have gone over and the red light will change to a flashing red light.
Just in case you have lost the manual like one of our customers, this is how you reset the filter lights:
1. Press the menu button ( 7 times) until you get to where the display says new filter.
2. Press the enter button and hold it down for 3 seconds and a number 1 will be flashing after the words new filter on the display. This flashing number is so you can enter which filter you have changed. Filter number 1 is the pre-filter, filter number 2 is the V-5 gas filter, and filter number 3 is the Hepa filter.
3. You change the number for the filter by pressing the up arrow button.
4. Once you reach the correct filter number you press the enter button and the control panel will display a question mark after the words new filter on the display. Below this it will say, E = Yes M = Cancel. If you wish to cancel the entry so it does not reset a new filter life, simply press the Menu button.
5. If you want it to reset the filter life for the changed filter, simply press the Enter button. Once this is done, the filter light will change back to the green light, which will show the filter has been changed. If you go to the remaining filter life on the control panel for the filter number you just changed, you will now see the remaining life of the filter in hours has been reset.
  • When most people think of Oreck, an air purifier is usually not the first thing
  • IQAir Dental Series Air Purifier
  • UV air purifiers are very effective at neutralizing airborne pathogens
  • HEPA Air Purifiers
  • REPORT ON THE AIR QUALITY CLEAN UP IN OUR OFFICES
  • Ozone Air Purification
  • Ionic air purifiers come in three different forms
  • WHOLE HOUSE HEPA
  • Dehumidifiers - Ebac Orion
  • Furnace Filters, Electronic, Electrostatic Air Filters - Comparisons, Ratings,
  • Nov 26, 2007 | Hunter 30216 3-SPEED FLOOR MODEL Air...
    Air Purifiers Logo
    69 people viewed this question
    Top Air Purifiers Experts
    Michael Youngman
    Michael Youngman
    Are you an Air Purifier Expert? Answer questions, earn points and help others
