Question about Troy Garden
My troy bilt 2 cycle 425 CFM won't start. I changed spark plug it acts like its going to turn over then doesn't.
  • Troy Master
  • 4,483 Answers
If the spark is good and strong it is most likely a fuel problem. Small engines have very small fuel passages and lots of dirt tends to be introduced during refuelling by not exercising the care and attention to detail needed.
As small 2-stroke engines age they often become more difficult to start even when there is nothing tangible wrong with them. Usually this can be overcome to some extent by changing the procedure for starting a little and using an acquired intuition rather than the starting instructions in the handbook.
Sometimes when all else fails a little spray from the ether can into the air intake might help get it started.
Posted on Apr 25, 2015
  • 26 Answers
SOURCE: My 2 cycle gas trimmer will not start? It's only 2 years old
Have you cleaned the spark plug , replaced it, or the carberation system?
If not, then this could be the problem.
Plug builds up corrosion over a period of time and cleaning is requird. also resetting the gap.
GAs goes stale too to flush out the old gas and put new gas.
Posted on Jul 12, 2009
  • 77 Answers
SOURCE: I have a Troy-Bilt 31cc 2-Cycle Gas Powered that doesn't start
Coil bad or wire to coil bad. I tell everyone what Ill tell you,when it comes to small engines,troy bilt,poulan,weedeater brand all JUNK,JUNK JUNK! Theyre made cheap,not built to last,theyre throwaways. Carbs are made in china. If youre ever in walmart next time go back to the garden section and pick up a weedeater or poulan brand chainsaw or trimmer. Look at the package good and look at the factory life expactancy. Its not in months,not even days,but in hours. If I was you I would tell myself NO MORE! I would buy a dolmar or stihl,pay the extray,cause you wont be aggrevated in the long run. P.S. Dolmar offers a 100% coverage for ONE YEAR on all equipement.
Posted on Aug 11, 2009
  • 74 Answers
SOURCE: leaf blower won't start. I think it's the module
If you haven't done it already, install a new plug. It's possible you're being fooled by a faulty/fouled plug. A fouled plug may not spark visibly - like if there is dirt down in the recesses of plug around the electrode. It would be a good idea to check it with a new plug before spending $80 bucks for a new ignition module.
Posted on Aug 13, 2009
rycgl
  • 1545 Answers
SOURCE: What spark do I use
Your 31cc engine uses a Champion RDJ7Y. The gap is .020".
Posted on Jan 08, 2011
2strokeJim
  • 577 Answers
SOURCE: Troy Bilt TB320BV blower won't
unhook your switch's and see if you get spark then
Posted on Aug 01, 2011
String trimer
Sounds like air in the system, take spark plug out, pump bulb 3 or 4 times, replace spark plug and try to start. Repeat.
Apr 17, 2014 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
I got a no start on a troy bilt 31cc leaf blower. I've replaced the carb, fuel lines, fuel filter and cleaned spark arrester. The spark plug is always dry as a bone so i know its not drawing fuel. Im at a...
See if you have spark to the plug, if not replace coil. You did everything else it should start, make sure start switch is to the on position. You replaced carb are the lines connected to the correct places and not kinked. Is your clunk clean. not much else to go wrong. Good Luck......
Sep 12, 2013 | Troy-Bilt Blower/Vac 31cc, 200 MPH, 405...
Troy bilt weed eater
I have a troy built 2 cycle pro-line tb90bc spring assist trimer.
its getting fuel and it wouldn't start I took out the spark plug and it was wet with fuel. pls fwd any info to ss.beepat@hotmail.com
May 06, 2013 | Troy-Bilt Tb90bc 17-inch 31cc 2-cycle Gas...
Won't Start. Need manual (lost it). Where is the spark plug located so I can change it
You can get your manual here. You will need Adobe Reader installed on your computer to do so.
You will also need the serial number off of your machine to get the download from MTD/Troy Bilt.
You should find the spark plug at the end of a thick black wire. You may have to remove a cover to see it clearly.
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001
Dec 06, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
I have a Troy-bilt 2-cycle trimmer "TB70SS" which apparently has no spark, might be the problem and how do I fix it?
Begin by changing the spark plug, and checking to be sure that the fuel is fresh [less than a month old]. The best way to check for sure to see if you have spark is to unscrew the spark plug, hook it up to the wire and then pull on the cord. You should see spark. This works best with an assistant to pull while you hold the spark plug 1/2 inch from the metal on the machine.
Nov 03, 2009 | Troy Bilt Tiller/Edger 26cc, Model No....
Troy-bilt TBP6040 4-cycle stalls out after about 10 minutes. Started doing this the 2nd time I used it. After it stalls out it will not start until it completely cools off. Fresh fuel in it. Arrestor...
I have the same model from Troy-Bilt. I have only had it about 4 or 5 months. Mine has started using a LOT of oil. I noticed a significant increase in temperature compared to my old Husqvarna 2 cycle. Mine does not completely stall, but it does start to sputter when it gets hot. I am going to take mine back to Lowe's where I bought it. So far I am VERY unhappy with the TBP6040.
Aug 24, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Garden Logo
100 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
