Question about Sportline 228 Giant Sport Timer Stopwatch and Whistle WV2787BK
How do I remove the (blinking) marks above the stopwatch timer?
How do I set time on Westward 6JG70 stopwatch?
Go to date and time screen. Hold Mode button for 5 seconds or until seconds figure on stopwatch starts blinking. Then use upper right button to choose seconds, minutes, hours, year, or date. Use upper left button to set the blinking figure. Press Mode when done.
Oct 09, 2014 | Westward 6JG70 Digital Stopwatch,...
What is the countdown timer in stopwatches?
The "countdown timer" in stopwatches allows you to set a specific amount of time and once you press the start button the timer counts down until it gets to zero. This is beneficial in numerous of cases where you want measure how much can be done in specific amount of time. For example, if you want to measure how many sit ups you can do in 2 minutes, you can measure it with this feature.
Aug 29, 2012 | Coleman Exercise & Fitness
Is there a website where I can compare prices of stopwatches? I feel like I'm going in circles trying to find a good price.
Don't worry, it can get a bit overwhelming when you go from one website to the next. There are a few places that you can compare prices for stopwatches, but take a look at this yahoo link which has comparative prices for stopwatches and timers. http://shopping.yahoo.com/stop-watches-timers/
Aug 20, 2012 | Exercise & Fitness
What's the best brand for stopwatches?
The best stopwatches are made by Seiko. Seiko is also the official Olympic Games timer so you can get the idea that they are a solid brand. The only drawback is the expensive prices the charge even on simple stopwatches, just to get the idea, the cheapest I found cost 89$.
Aug 02, 2012 | Exercise & Fitness
How to stop alarm
If you do not have the manual, you can go to their web site "sportline.com", select "sport timers".
Go to the model that you have and click on "learn more".
You will see a tab marked "manual", click on this and then on "download manual".
Jan 24, 2010 | Sportline Stopwatch
I need to find someplace to download the instructions, since mine didn't come with any
I just bought a Sportline 241 last week. The instructions are as follows. Note that there are no instructions for setting the 12/24 hour time option. Mine is in 24 hour mode (which is what I wanted), but I do not recall if it arrived that way or if I stumbled onto this mode when setting the time/date or alarm functions.
I hope this helps.
SPORTLINE 241 WALKING ADVANTAGE KEYCHAIN STOPWATCH
FEATURES:
24 hour stopwatch
Time-of-day and calendar
Alarm clock
BATTERY:
Replace with LR41 battery
TO SET TIME AND CALENDAR:
From normal time display, press MODE button three times to enter Set Time/Date Mode. Seconds is automatically selected.
Press SPLIT/RESET button to cycle through minutes, hours, day, month, day of week, seconds.
Press START/STOP SET button to change digits on any of the above (seconds only: resets to 00).
Press and hold START/STOP SET button to advance digits rapidly.
Press MODE button once to return to normal time display.
From normal time display, press and hold START/STOP SET button to see the month, day, and day-of-week.
TO SET ALARM:
From normal time display, press MODE button twice to enter Set Alarm Mode. Hours is automatically selected.
Press SPLIT/RESET button to cycle through minutes and hours.
Press START/STOP SET button to change digits.
Press MODE button to return to normal time display.
From normal time display, press and hold SPLIT/RESET button to see the alarm time setting.
TO ARM/DISARM ALARM SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press START/STOP SET button to arm/disarm alarm sound.
Alarm will sound when indicator shows in upper right corner.
Release SPLIT/RESET button to return to normal time display.
TO ARM/DISARM HOURLY CHIME SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press MODE button to arm/disarm hourly chime sound.
Chime will sound when dashes appear along top of display.
STOPWATCH OPERATION - GENERAL:
From normal time display, press MODE button once to reach stopwatch timer display.
After use of any stopwatch feature, press MODE button once to return to normal time display.
START-STOP (TIME-IN/TIME-OUT) TIMING:
With stopwatch timer on display, repeatedly press START/STOP SET button to start or stop the timer. When timer is stopped, press SPLIT/RESET button to reset timer to 0.
SPLIT TIMING:
With stopwatch timer on display, start the timer with START/STOP SET button. Repeatedly press SPLIT/RESET button to split or release the timer. Press START/STOP SET button to stop the timer. Press SPLIT/RESET button to reset timer to 0.
1-2 FAST FINISH:
Press SPLIT/RESET button for STOP #1.
Press START/STOP SET button for STOP #2. The stop time for #1 will now be shown.
Press SPLIT/RESET button. The stop time for #2 will now be shown.
Press SPLIT/RESET button to reset the timer to 0.
Apr 17, 2009 | Watches
How do I use the stopwatch on iPod nano?
"iPod Software 1.0 for iPod nano introduces a Stopwatch feature. You can use the Stopwatch as you exercise to track your overall time and, if you're running on a track, your lap times too. The Stopwatch menu is located in the Extras menu. To access the Stopwatch from the main menu, select Extras, then Stopwatch, and then Timer (Extras > Stopwatch > Timer) to see its display. Total time of session Current lap time Left button (Start function shown)1 Battery indicator Right button (Clear function shown)1 The left and right buttons' names and functions will change, depending on the current state of the Stopwatch. Using the Stopwatch When you first enter the Stopwatch screen, the left button is labeled Start and the right button is labeled Clear. To use the Stopwatch, select the Start button (use the Click Wheel to highlight the Start button, then press the Center button). The Stopwatch creates a new session, and both the total time of the session and the current lap time begin counting: When these counters begin, the left button changes to Pause and the right button changes to Lap: If you select the Lap button, the current lap time will be recorded in the session's log, then the Stopwatch resets the lap time to zero and begins counting the new lap's time. The total time of the session will freeze for 5 seconds after you select the Lap button so you can quickly view your total time at the end of that lap. After 5 seconds, the total time of the session displays the correct total time and resumes counting. If you select the Pause button, both timers will stop counting and the left and right buttons will change to Resume and Done, respectively. If you select Resume, both timers will begin counting again. If you select Done, the Stopwatch records all the final times and creates statistics for your session in a log. Please note that selecting the Done button does not reset the display. You will see the final times for your total time and lap time displayed: To reset the display, select the Clear button (appears after you click Done and then select Timer again). Stopwatch Behaviors You can play music and use the Stopwatch at the same time. When iPod nano displays the Stopwatch screen, the Play/Pause, Next/Fast-forward, and Previous/Rewind buttons control music playback as usual. If you're playing music, you'll see an icon in the upper-left corner of the Stopwatch screen that indicates the current playback state: A play icon indicates that music is currently playing. A pause icon indicates that a song is currently paused. You can use the Menu button and the Click Wheel to navigate to other menus without interrupting the Stopwatch. Note: The Stopwatch will prevent your iPod from sleeping if it's counting. The Stopwatch will automatically stop if any of these three conditions are met: The total time counter reaches 24 hours iPod goes into hibernation (you can start it again when you wake iPod) You conne
Sep 28, 2005 | Apple iPod nano
Sportline 228 Giant Sport Timer Stopwatch and Whistle WV2787BK Logo
615 people viewed this question
Top Sportline Exercise & Fitness Experts
Tony
Are you a Sportline Exercise and Fitnes Expert? Answer questions, earn points and help others
