Computers & Internet Logo
a
anthony lowe Posted on Apr 25, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
So i take no one can help me thank folks for looking
Mister Danger
Level 3:
  • Master 5,631 Answers
  • Posted on Apr 25, 2015
Mister Danger
Master
Level 3:
Answers
5631
Questions
0
Helped
1199154
Points
47629
Sorry, I don't know what did you ask.
Car window issue?
Fixya Folks could use a little more information to help you out.
Make
Model
Year
elec or manual windows.
Thanks
1helpful
I need help on how to replace a ford 99 model super cab fan belt and what size belt would I need... also can I tighten the head gasket with a shifter.. cluless? ? Thank you. Carryn
First to get right fan belt you tell folks at parts store year, make & model & engine size and they look it up for you. To change belt depending in which belt you have to loosen alternator, power steering pump etc... bolts and slop old belt off new one on and retighten. (Parts folks can show you how also) If you have a bad head gasket, they need to be replaced not tightened.
4helpful
Fork seals gone on honda nsr 125
280 ml on the older models, and 320ml on the newer models.
1. you need to elevate the bike with a jack or something so the front wheel is off the ground.
2. undo the Allen bolt on the side of the fork, then proceed to take the main wheel socket bolt/bar out, so the the wheel comes off, the speedo drive will come off leave that hanging around lol.
3. take of the socket bolts attaching the brake caliper to the fork, dont leave it hanging secure it somewhere, so you dont damage the brake cable tube.
4.take handle bars off, one allen bolt on each one.
5. then unscrew the the 2 socket bolts that hold the folks on, if you follow the folks down you will see 2 socket bolts take them out. do the same on other folk.
6.then pull one folk at a time down, maybe tap it if its hard. and you will have the folk out in your hands.
7.unscrew the big socket bolt at the top of the folk out, but apply pressure, sometimes the bolt will fly off, so be careful.
8. take the big long plastic tube out along with the spring, and tip the folk upside down and pump it to get most of the oil out.
9.then go to the bottom of the folk and undo the allen bolt, when its moving around freely and not coming out put the spring in and push down and twist the allen bolt should come straight out.
10.pump it a few times and then you take the folk tube out completely and give everything a clean, it will be stiff when you get it near the top so get momentum and yank hard and it will pop out.
11. then the bottom pit of the folk that the tube goes into, if you look into it you will see the oil seal, take the cur-clip out and it should come out pretty easily.
12 give the folk tubes a rub down with fine sandpaper say 1000 grain or 800 grain, to get rid of little bumps, look carefully feel it with your hand, to see if theres any pitting, you will be able to see it, thats not good but make sure its not on the part of the tube which goes up and down the oil seal when compressed down.
13.put folk tube back in the bottom of the folk, then put spring in puch down tighten allen bolt.
14.put new oil seal on and push it down its best to use a oil seal hammer tool thingy, but if your careful you can tap it down with a hammer and something small and flat at the bottom, i used a bolt, worked well.
careful dont damage the oil seal.
15. put cur -clip back in, it should click, make sure its on the closest ridge to the oil seal.
16. put 280 ml, of oil or if you have a newer model 320ml, of fork oil in the tube, pump it a few times to get air out and oil to the bottom chamber.
17. put the spring back in and the long plastic tube, and put the top bolt on for now not to lose not to tight.
18. attach the folk to the bike again and same with the other one, make sure you align the little ridge on the top of the folk, with the top of the steering bar, the top steering the bar the folk go into last. its late lol getting confused lol. oh and when y0ou align make sure you tighten the bolts holding the folk in place.
19.then put the steering grips/bars back on and then tighten the top bolt tight cant remember the torque setting. then you know everythign from there. phew
I seem to some how blocked some folks from sending me emails
ask your email provider; it is specific to the service, and software you use.
1helpful
2answers
I need instructions for a st ferdinand crib model# 2295
We also needed these instructions, couldn't find them, but were able to use the Little Folks 'C' Series crib instructions instead - the two cribs are assembled in a very similar way.Those instructions can be found here:
http://babycare.manualsonline.com/ex/thread/view/idThread/3491018
Sep 30, 2009 • Baby Gear
Better manual for COnnex 3300HP.
these are some links that you should try www.safemanuals.com or www.eham.net this should help you find what your looking for god luck. please rate this
1helpful
Panasonic PT-51HX42F Alignment problem
need to replace both of the convergence ICs STK392-110 you can get new ICs at this link and they will provide free installation instructions with pictures so you can do the repair yourself. They also offer free online tech support in case you need more help. Its fairly easy takes about 45 minutes from start to finish. A repait tech will charge about 400.00 the parts cost 20.00 each at this link you need two.
http://servicemanuals.vstore.ca/
Grand Canyon Tech
Grand Canyon Tech
