Cant get input to come on screen - Televison & Video
  • Televison & ... Master
  • 2,045 Answers
Check batteries status on your remote. If these are OK then refer to UG how to factory reset the TV set.
Posted on Apr 25, 2015
To play videogames on an old tv PLEASE HELP
You'll need to switch the TV into Video mode. Most TV sets will have a button on the front panel labelled "input" or "tv/video," and pressing this button will cycle through the various inputs your TV has.
Alternatively, this button may be located on your remote control.
Rarely, no button exists, and video input is selected by changing the channel below channel 2; as if you were trying to select channel 1. This will select the video input on sets without a separate input selector button.
Dec 20, 2012 | Televison & Video
Cant get tv to antenna
Hi there
Have you checked the INPUT on the remote?
Try to put the input back tothe antenna on the screen menu.
All the best
kolbri
Apr 15, 2012 | Mitsubishi LT40164 40 in HDTVReady LCD TV
My settop box has given me a blue screen and now i
A Blue Screen, means that there is NO signal be "Given" to the "Input" that the TV is currently using. Try another "Input" or check your antenna is OK, you are "ON" the right "Input" too.
Mar 02, 2010 | Televison & Video
I cant get the color to my screen
the screen is in PAL mode you must Push the input button then the up or down button to switch between PAL and NTSC in that input
Jan 15, 2010 | Sony MV-7101DS Car DVD Player
Trying to set up my xbox to my orion tv but cant get it to work. the screen shows nothing but snow
You have to switch the TV to the proper input. If you are getting snow, the tv is on the cable input. Xbox only works on the composite or component inputs on the set. The inputs are labeled at the jacks that you have connected too. Find the input button on the tv remote and switch the tv input to the input number you are connected to. Thanks for using fixya.
Dec 13, 2009 | Televison & Video
Cant find input on screen to play dvd
Select av?, the ? is the number of the socket the dvd is plugged into, normally written next to the socket. If you are using the front/side inputs they will be a shared input so you may have to turn off another unit to view.
Sep 03, 2009 | Televison & Video
Cant find HDMI Input in input screen
it has automatic signal detection,just like a computer with windows xp. if you plug in a jack,it tells you
Jul 17, 2009 | JVC HD-52Z575 52" Rear Projection...
Dynex 42" HDTV - pressed "Comp" button now cant get back to TV
Press the TV button on the remote. You are confusing the Comp button with the Input button which allows you to switch between input ports.
Dec 14, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Dvd wont work.
First, is the DVD player output (Video out, audio out) connected to the TV input? Have you used the Yellow cable from  DVD video out to the TV video in? Mixing the audio and video cables will result in no signal. Have you selected the proper input with your TV remote control. Most plasmas accept a variety of input signals; you must select the right one. I deal with a number of these issues. Usually the connections are made improperly or the correct input source is not selected with the TV remote. Put a DVD in the player and press play. Be sure you have made the proper connection from DVD player video/audio out into an auxiliary or video input on the TV. These could be labeled Line 1 or Line 2.  With the DVD playing, run through the input options on your remote control. The button might be marked source, video or input. The screen should display your choices i.e. video 1, video 2, etc. When you see your DVD program, you've got the right combination.
Dec 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
CANT ACTIVATE THE VIDEO INPUT
I'm assummiong you can't select the dvd input. go to this website and you can get a copy of the manual to tell you exactly how to select it. http://www.retrevo.com/support/Sanyo-DS27910-TVs-manual/id/17567dj493/t/2/ It will tell you to select the INPUT/TV-VCR button and select source TV ot AV1 or AV2. good luck.
Nov 28, 2008 | Sanyo DS27910 27" TV
Televison & Video Logo
Top Televison & Video Experts
