Why do red arrows flash at bottom when trned on?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Televison & ... Master
  • 1,745 Answers
What model/made
Posted on Apr 25, 2015
HOW TO USE THIS PRODUCT. EVERYTHING I TOUCH EITHER FROM THE ARROWS OR FROM THE TOP FLASHES GREEN , THAN ONE FLASHED RED , SO i thought it was the hot wire, so i used it on the bottom of the switch and the...
The green light flashes when you turn on the unit, or adjust the sensitivity. Hold the front arrow to increase the sensitivity. Hold the rear arrow to decrease the sensitivity. The unit only senses the hot (black) wire. To test the ground or common, you will need a contace tester, not this non contact tester. Set the new default by adjusting the sensitivity on a known good outlet. When you have reached your desired default sensitivity, press and hold both arrows at the same time for two seconds. The new default sensitivity is now set, and will return to that point every time you turn the unit off, then on again.
This unit is designed to only let you know if you are handling a live wire or not.
Mar 08, 2011 | Mastech MS8902A 600V Noncontact AC Voltage...
I have a honeywell cm927 control unit, and the red light on the receiver keeps flashing. i can manually turn the boiler on and off at the HC6ONG receiver. i've tried the faqs in the manual but to no joy....
The red flashing light means that there is an issues with the RF comms between control unit and receiver. You can reset by switching the boiler off and back on and then re-sending the temperature signal. You need to check batteries in you thermostat and also the position as the signal could be interfered with or it may be too far away from the receiver.
Sep 25, 2010 | Honeywell Programmable Thermostat Heater
The unit will not turn on in the "auto" mode. cool on is flashing.
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Aug 08, 2010 | Honeywell Heating & Cooling
Our honeywell ultrastat thermostat screen flashes and goes blank. Then we reset the power via the electric box and it works for about 15 minutes and goes out again.
HONEYWELL WEBSITE:
Go to honeywell.com
May 29, 2010 | Heating & Cooling
I have a cm921 thermostat with the correct batteries showing full charge. Yet the battery light is flashing and says battery low. Also displayed room temperature is a lot higher than the actual room...
HONEYWELL WEBSITE:
Go to honeywell.com
Feb 28, 2010 | Honeywell Programmable Thermostat Heater
My dishwasher AEG FAVORIT keeps beebing and not working it flashes with a arrow and stright line? it stoppted half way through
The arrow straight line meens end of program. However the flashing lights do indicate an error codeas per the handbook. This could be the ati flood device (polystireen float / micro switch) at the bottom of the machiene indicating a water leak. This device puts the washer in pump out mode and nothing els works until the error has been rectified.
Sep 19, 2009 | AEG 23 in. Favorit 50750Vi Built-in...
Ihave a T8600C1014 Chronotherm which was replaced with 3 AAA batteries. Why does 45 degrees keep flashing and the Air will not come on
Go to honeywell.com
under the red welcome sign
bottom red box that says
type in the model# of t'stat
click on arrow to the right
then click on the PDF files
Jul 31, 2009 | Honeywell Enviracaire 12520 Air Purifier
Remote control codes required
Hold The Clear Tv buttom until all 4 light flash red , then press code search at the bottom right , then the up arrow until ur tv goes off and finally record , after that u only need to press the red tv buttom to open it or close , If it doesnt open it back its because u press the up arrow after the tv was shut off so do the same thing be using the down arrow .
Apr 14, 2009 | Sanyo DP42746 42 in. Plasma Television
Getting Akai model PDP4273M plasma to accept a new remote
Mar 19, 2009 | Akai PDP4273M Television
Covergence out of alignment on 1/4 Vertical left side of screen
You need to manually adjust the alignment:
On remote, press Menu to get to the main menu
Then arrow down to "ADVANCED FEATURES"
Then press "enter"
Then Arrow down to "CONVERGENCE" and press "enter"
"Red Convergence" should be highlighted
Press "enter"
You now have Green, Red, and Blue overlapping crosses.
If Red is out of whack, use arrows to align
To toggle to blue (and back to red), press "VIDEO"
Then align blue cross
Once the crosses look aligned, and nice and white, press "AUDIO"
This will bring up the Advanced Convergence screen
This is a grid of the same overlapping colors
You have control over the Red and Blue
If Green is very out of whack, you'll need a repairman…
While the "target" is flashing, you can move it around the screen with the arrows
Place it over an intersection to adjust, then press "enter"
Now the "target" is steady (not flashing), and you can use the arrows move your color
When it's aligned, press "enter" again
Now "target is flashing, and you can go to the next square.
You cannot adjust every intersection.
Some areas need to be adjusted via the adjacent intersection
When you're happy with color you're working on,
Press "video" while target is flashing to change to the other color
Repeat the above (blue is much harder to see and adjust for me…)
When you're happy with the entire grid, start hitting "Menu"
Each press brings you back out one menu level, until you are out of them
Once you're used to the process, it should take no more than a minute or two.
Mar 02, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
