Question about Boston Acoustics Audio Players & Recorders
Subwoofer burned out, need replacement resistor specifications.
Boston Acoustics Tvee Two has overloaded two sets of resistors. They are so burned I cannot see the markings. Can someone have a look at a working one and give me the colour codes - Please. I need two pairs both from the power board. The air in the corner nearest the joined wireless board. and the pair at the other end of the board in the centre. I think the previous owner just had it on full power permanently and blew them.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,745 Answers
Do you mind to take pictures of res locations what you need?
Posted on Apr 25, 2015
My subwoofer had no sound or power. I replaced the ZN3 diode and now I have power but still no sound. Any suggestions?
If this is a boston acoustics sub, then I assume you replaced ZD3. You also need to check R9 on the back of the board. It is a surface mount resistor and should read 10 ohms. This resistor sometimes goes open when the diode shorts.
Jun 05, 2015 | Audio Players & Recorders
Boston Acoustics TVEE 26 factory reset
Reprogram the remote to function with a different brand of equipment that you do not have. The remote can't affect the receiver if it is not talking to it.
Feb 23, 2014 | Boston Acoustics TVee Model 26
Boston acoustics pv-1000 won't power on
Just fixed my PV1000 that would not power on. Verified 185vdc on bulk capacitors. Measured 11vdc on U5 (UC3842) from pin 5 (gnd) to pin 7 (vcc). Then measured 0vdc from pin 5 (gnd) to pin 8 (ref). This should be 5vdc. This means that U5 is shut down for undervoltage. Turned out to be two open resistors. R94 100k 2w and R77 33k 2w. Never would have guessed that as there was no sign of heat discoloration. They are next to each other between U5 the UC3842 PWM IC and Q3. This prevented the proper startup voltage for U5. Replaced them and I'm off and running once again. Hope this helps someone.
Oct 27, 2013 | Boston Acoustics PV1000 Subwoofer
Can't get sound out of Boston soundbar when hooked up to 46" LCD Philips? Soundbar works fine when hooked directly to iPod.
You may have to go into the settings on the tv and turn off the internal speakers in order to get audio out of the jacks on back.
Dec 27, 2012 | Boston Acoustics Tvee Model 25 Sound Bar...
Programming time warner remote to boston tvee volume
I had just about given up on programming my Time Warner universal remote with my Boston Soundbar until a mental lightbulb came on. This is a two step process. Step 1: Program your Time Warner remote (I have CLIKR-5, instructions available for other models at timewarner.com) Using Pre-Programmed 3-digit Code method -Turn on soundbar - Press device button (I chose AUX) and OK/Select simultaneously until device button stays lit. - Point remote control toward the soundbar and enter code (447 for Boston Acoustics) - Press the device button again to store the code. The TW instructions say you should now be able to turn the device off to verify that it works, but this is not true for the soundbar. Hang in there with me. Step 2: Program your remote from the Boston Soundbar. - Press the power button and the volume up button simultaneously until the indicator light flashes orange. Here's where the instructions provided with the soundbar fail to explain how to do this. Each button is individually programmed into the TW remote. What you have done so far is enable the remote to accept the programming. - Volume Up: press the volume up button on the soundbar while it is flashing, the light should become steadily orange. - While holding the remote steady about a foot away from the soundbar, slowly press the volume up button on the TW remote four times. The orange light should flicker each time you do, turning green when completed. - Volume Down, Mute, Power: repeat the steps for Volume Up, except press the button on the soundbar you wish program to the TW remote while the soundbar is flashing orange. It should become steady before you press the corresponding button on the TW remote. Good luck, I hope this helps. -Deidre.
Dec 05, 2012 | Boston Acoustics TVee Model 25 Sound Bar...
Volume on Boston sound bar will not go up very high
There is a internal problem with it, Take it in for repair, out put transisters are probally fried,
Dec 02, 2012 | Boston Acoustics TVee Model 20 Soundbar...
Tvee model 25
Have you checked all your wire connections? To make sure thier not loose.
Aug 05, 2012 | Boston Acoustics Tvee Model 25 Sound Bar...
No sound in sound bar and subwoofer
It could be that the unit is bad, it could also be that the device providing the input is bad. I doubt the cables are bad, but that could be also. Could it be possible that your television has a menu setting that turns the outputs off and on?
Even without the sub, you still get sound through the Bar.
Only way to test it is, different cables, alternate device to provide input for sound.
Dec 14, 2008 | Boston Acoustics TVee Model Two TV...
Suround sound dvd
Get a Boston Acoustics Tvee Soundbar System.
Dec 06, 2007 | Boston Acoustics TVee Model Two TV...
473 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
