Question about Weber Spirit? E-310 Propane Grill
The center burner does not light - Weber Spirit? E-310 Propane Grill
  • 5,631 Answers
Posted on Apr 25, 2015
The stove part has five burners, 4 outer and one in the middle. One day the four outer burners stopped lighting, but the center one still does light. The four outer burners all still click when...
Look for obstructions or a buildup on the spark tip on each burner. I use a tooth pick to clean around them. Let the burner completely dry before trying to light it since water will give a shorter path to ground which will produce a smaller on no spark at the burner.
Jan 03, 2015 | Whirlpool GFG461LVS Stainless Steel Gas...
Why wont the left and right burners lite using the electric ignitor?
Are the igniters for those burners sparking?
Aug 29, 2014 | Grilling
Burner does not light
A Kitchen Aid Food Mixer does not have a burner, you will struggle to find a solution in this department.
Mar 09, 2013 | KitchenAid Food Mixers
Center and back burners won't light
cross over tube could be out of postion blocked or you need new burner
May 15, 2010 | Weber Genesis Silver B Grill
Center burner doesn't ignite all the way around
I had this same problem. You will need to lift off the burner and remove the two 9/32" nuts and lock washers from the bottom of the center burner. Then separate the top section from the bottom. You will need to clean the inside of both sections down using a green scotchbrite pad removing and debris or small surface film the may have built up. Then rinse with warm water and dry them well. Reassemble it and your burner should work as good as new. Remember even just a small grease film on the burner holes will create this issue.
Apr 17, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Double ring burner won't light up.
the outer element may be broken if the center one is the only one getting hot
Apr 07, 2010 | Electrolux 23 in. EHD6670P Electric...
All of the sudden my front right burner will not light. I clicks like it wants to light and you can smell the gas but it will not light.All the other burners are working fine.
Take a look at the burner when it is clicking and make sure the igniter electrode is creating a spark. If the burner head is removable pull off the burner cap and head. Inspect the burner head for debris and clean. Make sure any small holes on the burner head are not plugged. There is usually a small hole where the electrode is that a gas must exit for proper ignition. If the burner has a center igniter for two burners then inspect the flash tube for that burner and make sure it is centered and there is no obstructions in the flash tube. On that burner there are little holes located in front of the flash tube call step-up ports. Check to make sure those little holes are not plugged.
Sep 10, 2009 | GE Kitchen Ranges
Front burners on gas range won't light.
My GE gas range is really sensitive about the gap between the igniter electrode and the metal disc that covers the burner. If the metal disc is slightly off-center, no spark will occur. Check to make sure that the gap between the igniter and the nearest metal is about the same as the back burner.
Jul 25, 2009 | Kitchen Ranges
Propane grill uneven heat
Could it be the draw off the tank is okay for two burners and not 4 hence the temp drop
Mar 21, 2017 | Grilling
GE Spectra Range/Oven XL44
Resettle the small center tops on the burners. If even one is slightly off center or not level, a burner will not light, although it will click. Cost me a service call to learn this!
Aug 29, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Weber Spirit? E-310  Propane Grill Logo
196 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
