Question about Minka Aire Ceiling Fan
Light on ceiling fan is very dim. Do not have dimmer switch. Changed bulb but light is still dim. Could something be wrong with the fan?
    Genius:
  • Minka Master
  • 1,617 Answers
If it has a remote, press down on the light button and keep it pressed down until your light gets to full brightness.
Posted on Apr 27, 2015
  • Janice Wright
    Janice Wright Apr 27, 2015
    Thank you.....I've had this fan for 4yrs and I didn't know it had a dimmer light switch
Must I replace its 100 watt Sylvania incandescent bulb with another incandescent? What about an equivalent CFL or LED bulb?
Both will work fine as long as the light isn't on a dimmer. You can't dim CFL bulbs.
If you do have a dimmer, you can dim LED bulbs as long is you buy dimmable LED bulbs.
Which LED bulbs are best for built in dimmers CNET
Dec 29, 2015 | Minka Concept II Flush 44 Ceiling Fan by...
Hunterfan com
If you have a remote then you can't use the dimmer switch on the wall. Put in an on/off switch.
Sep 20, 2013 | Hunter 52" Ceiling Fan With Light And...
Dimmer not working but the light does come on.
What kind of wall switch do you have? Is it a remote wall switch? You can't use a basic Fan/light control with a remote.
Jun 03, 2013 | Hampton Bay AC414-LRU 52'' Kemper...
I have a hunter ceiling fan model 23898 which has a dimmer switch built in one day a light bulb blew out on it and now we cannot turn off the lights with the switch the only way is to loosen the bulbs in...
Has anyone found a solution for this problem? I have tried a bulb in each light socket and attempted to use the pull/dimmer switch that is on the fan itself. The lights no longer dim nor turn off. I have unscrewed all of the bulbs and tried each bulb in each socket one at a time and still nothing. I have also taken the pull switch out of a different hunter fan to put into this one, hoping that atleast the lights would turn on and off. Still the lights won't turn off using the pull switch. I am out of ideas.
Sep 11, 2011 | Hunter Ceiling Fans Individual...
If the legrand dimmer 400w - pro21 can function with led dimmable light "philips master led spot "
The answer is NO. You need a Trailing Edge dimmer to control LEDs.
The Phillips master LED spot manual says
Lighting controls: bulbs are dimmable 20-100% with ""select"" Trailing Edge RC devices
http://www.prismaecat.lighting.philips.com/FredhopperPDFWebServiceInter/docts/1d8ea75f-e889-424d-92dc-450fbeb85f6a/Smart_LED_Spot_da.pdf
The Legrand pro21 manual does not say anything about being a Trailing edge dimmer.
http://www.legrand.com.gr/gr/gr/liblocal/internet_greece/PDFS/NOTICES/IOBL/ROOSTATES/775637EN.pdf
Legrand diagrams show what appears to be incandescent bulbs, and say nothing about LEDs
LEDs cannot be dimmed as ordinary incandescent (tungsten) bulb.
More reading:
Wikipedia article on dimmers includes technical stuff on Trailing edge dimmers
http://en.wikipedia.org/wiki/Dimmer
2 sites show LEDs bulbs that dim:: both seem new ...
http://news.thomasnet.com/fullstory/LED-Bulbs-feature-smooth-dimming-range-566574
http://www.earthled.com/lumiselect-dimmable-led-light-bulbs.html
Oct 11, 2010 | Legrand On-Q/ ALC 600W Dimmer Switch,...
I have a Hunter ceiling fan with light kit. The controls for the fan and light are on the wall. It is a Hunter dimmer and 3 speed control switch. The fan works fine and the lights do not come on. I have...
Usually you have to press the light switch 3 times and hold to get dim effect adjustments, it is often radio transmitted in some newer models, if the pull switch is bad replace it anyways it could be dangerous if let alone!
Aug 23, 2009 | Hunter (25417) Ceiling Fan
Light flickers when dimmer switch isn't ''just right''
Compact fluorescent bulbs do not work on dimmers.  You have to use standard incandescent bulbs or not dim the lights.
Mar 20, 2009 | Hampton Bay 52 In. Brushed Nickel Romano...
Humming inside the switch
Is it connected to a fan motor also? - most dimmers are for lights only - if there is a ceiling fan connected you may experience a humming sound from the dimmer
Nov 12, 2008 | Lutron #D-600PH-DK 600W SP Push Rotating...
Not sure if this is the exact ceiling fan/ light kit we have... but looks similar.
Turned out that it was the dimmer switch that had shorted out.
My hubby figured it out, and replaced it.
Jul 19, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Minka Aire Ceiling Fan Logo
310 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
