If you have an Android device with Infrared you can download SureMote Universal Remote for free from Google Play and then it doesn't matter if you lose your remote :-)
You should look up in the user's manual of your universal remote. If you can't find it, follow the procedur to get unknown code. If still can't get a code, your onlty resurce is to get the original remote
SOURCE: Lost Remote for my Durabrand HT-395 Home Theater Systom
There are no codes you program into the remotes unless they are learning remotes. If you did the manual search for the code, then the universal remote will not work on that unit I'm afraid. You see you are not entering the code into the remote when you push the numbers the book tells you to. What you are doing is accessing the pre programed codes that are already programed into the remote. You cannot add any codes for universal remotes unless like I said before, they are called learning type remotes. Those cost loads of cash. Good Luck
SOURCE: rca rt2770 home theater universal remote code
hehehe i just found it mebbe i will tell u mebbe i will jk this is it either - 0790,1913,31023,31609,31254 mebbe one of those will help. the first one worked for mine. i take it u know how to program the remote
SOURCE: searching for home theater system remote control codes compliment
Here is the link for you to find the codes for an RCA remote.
http://remotefinder.rca.com/default.aspx?site=rca
I hope you are looking for this one. if not , please do let me know.
Please do rate this solution and thanks for using FixYa!
SOURCE: need to program 311w U. remote to RTD215 home theatre
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
