Question about Grundfos Hardware & Accessories
My grundfos 15-90 water pump is getting very hot after worked 10 minutes.what is the problem
  • 82 Answers
SOURCE: Grundfos installation with Buderus boiler. Pump
Do you have more than one zone? If so, it is difficult to tell if the circulator in question is actually running. A trick is to get a screwdriver and place the metal end on the front of the circ and the other on your ear. You will hear it if it is running. If you do hear it, is the circulator itself very hot to the touch? If it is, it may be burnt out, or the zone needs to be bled of air. Another doubtful, but possible, answer is that the circulator is installed backwards. There is an arrow on it and it should be aimed towards the flow of water.
Posted on Dec 31, 2009
  • 61 Answers
SOURCE: My hot water heater sprung a leak and after
pumps of this type will fail quickly without water. They are lubricated, and cooled by the fluid that runs through them.
Posted on Jan 03, 2010
SOURCE: The hot water comes on immediately and sometimes
If your grunfos pump is clogged with hard water sediment, then it probably needs replacement.
You can try soaking it in CLR for a while, but I doubt it can be salvaged.
Sediment adheres to surfaces and there is no way to get inside the pump and scrub it out with a tooth brush.
You might benefit from replacing pump with the type that has a timer. That might save a bit of money. Or you can add a timer to the ordinary grundfos. If pump works fewer hours, it shouldn't clog up as quickly (or so the theory says)
And your water system might benefit by flushing your water heater each 6 months to prevent sediment from forming in the water heater.
http://waterheatertimer.org/Water-heater-recirculation-system.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Posted on Oct 21, 2010
  • 1015 Answers
SOURCE: Just bought a house and it has a grundfos
I would guess that the pump is to recirculate hot water so you have nearly instant hot water. The pump should be set to run during periods of high use. I doubt that pump is wired into water heater controls. I would check setting on heater thermostat and turn up if needed. I hope this helps. Thanks
Posted on Nov 21, 2010
SOURCE: After replace the cold water
Many times when pipes are worked on, the work loosens sediment that was built up in the pipe.
Sediment is probably why cold water line was replaced.
That's why faucet aerators get clogged up after pipes are worked on.
It sounds like your grundfos pump got clogged too.
Immediately unplug the pump so motor is not overheating.
Motors are meant to turn freely and can be damaged when blocked.
Take apart the pipes at grundfos pump and see if you can clean out the line.
If line cannot be cleaned or pump doesn't restart, then the grundfos has to be replaced.
Also look at adjoining pipes and see if there is a clog in nearby elbow, especially where galvanized and copper pipes join..
Posted on Dec 26, 2010
I don't understand how to set the timer on my UP 15-10-B5/TLC Grundfos circulating pump. When it is not plugged in, we have a hard time getting hot water
Sounds like 2 problems:
1) Crossover and 2) Setting timer
Recirculation system has check valve that stops backflow of water when pump is turned off.
When check valve is clogged with sediment, or has worn out, then cold water enters hot pipe or hot water enters cold pipe when faucet is turned on.
Take apart connection where grundfos connects to both hot and cold pipes, and clean with white vinegar or CLR.
http://waterheatertimer.org/Crossover.html
Open following link for setting typical FM/1 analog timer module on Grundfos recirculation pump:
Your timer module may vary in appearance.
Slide switch selector might be located below timer dial.
http://waterheatertimer.org/images/IMG_9325-grundfos-timer-800.jpg
Aug 30, 2011 | Grundfos UP15-10B5/TLC 1/25 HP...
Same problem as another writer described: the Grundfoss comfort system for hot water only. I do not get instant hot water as the last pump (until it quit working). The pump gets very hot. I...
If the pump is hot, the motor has overheated and will stop working. There's no cure for motor at this point. Be sure to de-lime and de-scale re-circulation pumps occasionally.
Return pump and exchange for new. Sounds like you already diagnosed the problem correctly.
Mar 27, 2011 | Grundfos Comfort System Recirculator ...
After replace the cold water pipe line, my Grundfos recirculator pump does not work anymore. I have to wait 3 min to get hot water. Do you know anything wrong here? Thanks
Dec 26, 2010 | Grundfos UP15-10B5/ATLC 1/25 HP ...
Just bought a house and it has a grundfos timer/pump attached at the hot water tank. I have no hot water and the timer doesn't turn (as I've seen other timers do). Is it supposed to turn so that the...
Grundfos is a sealed unit and not a repairable item.
The timer dial should turn.
And pins located around dial control ON-OFF functions as timer dial rotates.
Does the receptacle have power?
If receptacle has power, and Grundfos is not working, then it is broken.
Grundfos manuals for UP series pumps do not show breakdown or parts list of any kind.
http://www.us.grundfos.com/web/download.nsf/Pages
Bigger question:
Why don't you have hot water?
Is water heater functioning?
Water heater is a separate appliance from Grundfos pump.
Grundfos pump circulates hot water from tank into the lines so there is no waiting for hot water ... but hot water heater should still make hot water.
Add a comment about water heater if that is also a problem.
You could have 2 problems, and water heater is main issue.
For do-it-yourself electric water heater repairs:
http://waterheatertimer.org/6DIY.html
Nov 20, 2010 | Grundfos The UP1510B5ATLC 125th HP 1...
The hot water comes on immediately and sometimes takes ten to fifteen minutes I have the grundfos up10b5/atlc in my attic. The water is really a hard water kind. Can i clean it?
Oct 21, 2010 | Grundfos UP10-16B5/ATLC Comfort Series...
My Grundfos Comfort System is not working. I has been installed correctly....the pump is running, I checked and replaced the valve....still no immediate hot water. The installation instructions...
Turn on the hot water at the farthest faucet from the water heater. Once hot water is at that sink immediately go check other taps in the home. If you have to wait more then 10 seconds for hot water at other taps then you have a branched system.
Sep 01, 2010 | Grundfos Comfort System Recirculator ...
I have a problem with the MQ-35 pump starting and running for about 10 minutes when there is constant demand (such as running a sprinkler) and it then alarms and shuts off for 30 minutes before it will run...
This sounds like a issue with air still being in the system and not being removed from the system to make things work properly. I did try to findthere number and was unable to locate it. The only other option for you is to return the product and find one with better support
May 04, 2010 | Grundfos MQ3-35 3/4 HP Pressure Booster...
Hardware & Accessories Logo
90 people viewed this question
Top Grundfos Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Grundfos Hardware and Accessory Expert? Answer questions, earn points and help others
