Question about Pool & Spa
Pump does not run. Power source to spa ok (pool lights come on) screen says HL code (for overheating) but cool now and won't kick on
    Top Expert:
  • Pool & Spa Master
  • 4,290 Answers
Hl means hi limit check recirculation pump
Posted on Apr 20, 2016
SOURCE: Pump works in spa mode, but doesn't work in pool mode. Why?
We need more info. Which control system is it? Suntouch, easytouch, intellitouch.......? It sounds like a programming problem in the controller.
Posted on Jun 26, 2009
  • 990 Answers
SOURCE: spa water is overheating and get a HL error code
This is a problem in your board or something is jumping the safety circut. You should have someone look at this to be sure that no other problems have come from this. Good luck.
Posted on Dec 19, 2009
john224
  • 1378 Answers
SOURCE: hot tub no heater or pump heater light flashing
Thank you for posting your question here on Fixya.com.
Start with the pump. If it is bound up and not starting nothing else will work. Close off your valves and disconnect the pump unions. Once free, reach in with the pump unplugged and try to turn the impeller by hand. Will it turn? If not, you'll need to free it or get the pump repaired. Once the pump is working and water circulating your heater should start working.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Mar 10, 2010
macdirk
  • 116 Answers
SOURCE: Need to replace pump Impeller on A.O. Smith
To get to the Impeller you need to remove a series of bolts, or a large clamp, that holds the two halves of the pump together. Once you do that, if their is a diffuser (housing that goes over the impeller), remove it. To remove the impeller, you need to lock the motor shaft. You can do this a couple different ways depending on the motor. There will either be a small cap that grants access to the motor shaft on the back of the motor, or you remove a larger housing that grants access to the wiring and other components in the back of the motor. If it's the small cap, then you can hold the shaft with a wrench. If it's the larger housing, then you can slip a wrench (probably 7/16") under the thermal overload switch and onto the shaft to lock it in place. Now you can unscrew the impeller. Check to see if the impeller has a screw in the center. If so remove this first. It will be reverse thread. The impeller should spin off counter clockwise. If the impeller is very tight, be careful not to damage it. If you don't have an impeller wrench, I strap wrench, or very large locking pliers with a rag around the impeller works well. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Posted on Oct 12, 2010
john224
  • 1378 Answers
SOURCE: How do I connect the
Your line leads go on the L1 and L2 terminals in the rear of the motor. It will not matter which wire is on which terminal as long as you seperate them with only one wire on either terminal.
John
Posted on May 02, 2011
I am getting a Hi Limit 2 Fault message on my heater
overheating check gas pressure if too low will overheat if ok check manual bypass see if spring is bad also make sure filters are clean and pump is functioning ok
Sep 01, 2015 | Rheem M206A 206K BTU Pool and Spa Propane...
FL code with Great Lakes spa ...Pumps won't run and tub is cold... light won't even come on.
FL code is because no flow from pumps check to see if recirculation pump fuse is ok
Aug 02, 2013 | Jandy Laars Lite2 Pool & Spa Heater -...
Live in florida - pool pump goes off for a half hour and then turns back on and then operates normally for a while. it then repeats the same eequence. is this due to overheating
it does sound like overheating. runs for a while, trips the high limit, then cools and restarts. this could be a supply power problem, under sized wiring, or loose or damaged terminals associated with the wiring.
Aug 13, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
AquaLink RS8 switchs itself from Pool to Spa pump
make sure no programs if ok remove spa side remote plug if ok then replace spa side remote istill does it reset board but before write down all auxs and jvas
Mar 15, 2010 | Jandy AQUALINK RS TELELINK KIT
Spa water is overheating and get a HL error code
Dec 18, 2009 | Qca Spas Majestic Series Aruba Xl Hot Tub
Pool & Spa Logo
41 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
