Question about Mr. Coffee Single Serve Brewing System powered by Keurig
I have had this coffee maker for 4 months. I loved it until yesterday, the offe had a horrile taste. I ue only bottled water and I have cleaned the machine and the awful taste is still there. help!
  • Mr. Coffee Master
  • 5,631 Answers
Same happened to me when I burned out a rubber gasket whle overheated my coffee maker. Take it to an authorized service technician to check it.
Posted on Apr 25, 2015
Testimonial: "Thank you for the info. Very helpful. Will do."
    Top Expert:
  • Mr. Coffee Master
  • 10,875 Answers
What did you use to clean it??,only use vinegar,rinse by running clear water through machine 3 times,different water each time,
We love our model E9 coffee maker. However, our coffee has been bitter. In South Florida our water isn't the greatest, but I use double-filtered tap water, and also bottled water. We also use good...
t is most likely the coffe you are using,I would suggest you try different roast from different brands until you find what you like..for axemple Lavazza coffe from Italy has all kind of different roast.
good luck
Aug 25, 2011 | Jura Capresso Impressa E9 Espresso Machine...
Coffee maker never makes proper size, almost always have to run it 2-3 times to get even a small mug. Intermittently shuts off completely, have to turn it on in back. (B70)
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Jan 02, 2011 | Keurig Platinum B70 Coffee Maker
Coffee just drips out of machine, have left off over nite, worked fine now just drips & we get only about a 1/4 cup. Have not desaged as is only about 6 months old?? Bob Spackman
wer
Dec 25, 2010 | Keurig Platinum B70 Coffee Maker
My coffee maker heats up brews but not makeing coffee just pooring out water all over
dsfds
Dec 24, 2010 | Keurig B60 Coffee Maker
My coffe is tasting salty-its awful
234999fff Sorry to read about your issue.
Dec 22, 2010 | Keurig B60 Coffee Maker
Keurig coffee maker makes loud noise single cup brewer. Make loud noise prior to brewing.
Dec 20, 2010 | Keurig B60 Coffee Maker
The coffee maker does not dispense a full cup everytime. What's wrong?
ads9asd9a9d9dd9
Dec 15, 2010 | Keurig Special Edition B60 Coffee Maker
Lost instruction manual. How do I clean coffee maker to get rid of strong acid taste coffee? MoldelB60 single cup coffee maker
Most coffee pots are cleaned by running 1 part white vinegar and 1 part water. Just put in the reservoir and run a cycle. Once completed, run again with 1/2 pot of water only and it will clean it. If you use your pot daily, this should be done once every few months. If you have foul tasting coffee, you should use bottled water to rectify that. Plain tap water has minerals that dilute the taste of the coffee and over time build a residue in your pot.
Oct 09, 2010 | Keurig B60 Coffee Maker
Funny tasting coffee
Vinegar/water cleaning is a good idea, but it won't necessarilly solve funny-tasting coffee. First, replace your charcoal water filter - you can get the Cuisinart brand-name replacements at Lowe's, Bed/Bath/Beyond, or Williams-Sonoma in most areas.
To do the vinegar/water cleaning, just pour 1/3 caraffe distilled white vinegar and 2/3 caraffe water into the water reservoir and brew it like it was regular coffee - I would simply bypass the self-clean function if your Cuisinart has one. Repeat up to 3 times, using a fresh batch of vinegar each time.
(if you have the caraffe-less DCC-2000, then just pour in 4 cups vinegar and 6 cups water).
Then run a full cycle of water. Then run a combo of 12 tsp lemon juice and 12 cups water (or 10 tsp and 10 cups water) to improve the taste.
On your next batch of coffee, use bottled water just to rule out any possibility that your local water supply may be contributing to funny-tasting coffee.
Now your coffee should be tasting fine again.
-Tha Mp3 Doctor
Apr 03, 2009 | Cuisinart Coffee Makers & Espresso...
Metal Tasting Coffee
vinegar is not the best it remove calcium in little piece descaler produit melt go buy the descaler produit 1part descaler 1 part water put in water container start the machine after a few second turn it off leave it there for 15 minute repeat untill empty rinse very good after that product is corosif 2 or 3 full rinse thanks for using fixya pierre
Feb 12, 2008 | Cuisinart 12 Cup Digital Thermal Coffee...
Mr. Coffee Single Serve Brewing System powered by Keurig Logo
732 people viewed this question
Top Mr. Coffee Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Mr. Coffee Craft and Hobby Expert? Answer questions, earn points and help others
