Question about Refrigerators
My kg French door freezer doesn't seal closed on one side
The left side of the freezer doesn't close.
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Refrigerators Expert
  • 310 Answers
Door alignment is out of spec or you may need a new door gasket.
Posted on Apr 25, 2015
The LG freezer door does not close fully on the right side but seals perfectly on the left side, ideas?
I would check and see if the drawer is just stuck, or has something in it, or just remove the drawer and see if it seals
Mar 02, 2015 | LG Refrigerators
LG french door refrigerator does not keep food cold. Left door pops doesn't stay tightly closed.
What do you mean by "pops"? If your problem is the door, then it is possibly leaking out your cold air. It could be the seal or the hinge.
Aug 11, 2014 | LG LRFD22850 Bottom Freezer Refrigerator...
I have kitchen aid superba the icemaker works fine, except at the door where ice is dispensed the unit freezes up the ice crusher area like there is an air leak in the door somewhere which allows warm air...
I have had this issue with my french door kitchen aid freezer drawer. I have a toddler who sometimes gets into the drawer. If it is left open just a hair, it will melt everything completely and water leaks out all over the floor.
The drain gets clogged when the door gets pushed back in for a tight seal and freezes again.
Try to focus on keeping a really tight seal every time you open and then close the freezer...its almost like you have to TRY to close it hard to ensure it is closed. Total pain, but it works. When the door is closed tight, it stays like it is supposed to .
Oct 16, 2013 | KitchenAid Superba Architect KSCS25INSS...
Need gaskets for CSX20E Hotpoint side by side
Seals don't lose their magnetism. Check the door closes all the way round and adjust the hinges if it doesn't sit straight. Check there isn't a relief valve frozen up or blocked (it allows air to escape when the doors are closed). Check the drawers are fully pushed back in and not stopping the door closing properly
Sep 11, 2012 | Hotpoint Refrigerators
GE French door fridge problem. When you close one door the other door pops open alittle most of the time. Is this normal on french door fridges?
Hello, In a word, Yes. It is totally normal, when you close a door it pushes air into the unit and depending on how it is closed the other door will "pop" open slightly from the "push" of air. Thanks for coming to fixya. macmarkus :)
Jun 20, 2010 | GE Profile 20.7 Cu. Ft. Side-by-Side...
The left side door has dropped and the piece that closes the gap between the two doors will not operate properly. It leaves the gap open and the refrigerator looses coolness. Need to know how to realign...
Check the lower hinge of that door for a broken closer cam. The upper hinge is adjustable and adjusting the corners in the front will shift the cabinet to align the door also.
Eric
Dec 11, 2009 | Samsung RF265AA Bottom Freezer French Door...
Fridge motor is loud when doors closed stops when open-3.5 yrs old- first time same problem fixed with replacing sensor 2/08 now sensor broken again???
the fan goes off when door opened and when closes it will turn back on is normal operation of fan and door control --as to noise --fan may be failing ---iced over ----if seal failing will cause unit to run more and allows more moisture into evap which can cause more ice over
Apr 25, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
Bottom drawer does not properly close
Okay, I fixed it for now. The design for this bottom freezer drawer is not good. What happened was most likely that my son slammed the door, and it bounced and was slightly open. Overnight, ice started to form all over the compartment, including inside the drawer guides. Some ice was probably obstructing the drawer glide from sliding shut.
What I did, not thinking this was the solution, was to prop chairs against the drawer to close it while I searched for answers on the Internet. In the meantime, some of this ice must have refrozen in the closed position (due to the weight of the chairs). When I went to check it later, I had a little trouble opening the drawer. I gave it a hard yank and some small frost flew off, as I opened the drawer.
It was not easy sliding it due to the frost. I then moved it out and in until it felt smooth, and finally closed the drawer and it stayed in the shut position.
Kids are instructed to close the drawer gently and visually check that it is sealed. There is also an air passage between the refrigerator unit and the freezer so that when you close the double french doors, some air pushed to the freezer section and momentarily pops the drawer open. You should make sure that the drawer closes before leaving the kitchen. If you are on vacation, prop chairs to make sure both the freezer drawer and the french doors stay closed. This is important if you're in an earthquake area as a small tremor could open the doors and you'll get a fire when the lights stay on and burn through the wiring (as others have noted).
Dec 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Amana side-by-side refrigerator/freezer
raise the front legs/rollers so unit is tipped back slightly.its ok if it opens as long as it closes.
Aug 07, 2008 | Amana SCRATCH&DENT 25 Cu. Ft. French Doors...
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
