Question about Music
Can I operate this system without an amplifier. Can I operate with just mixer?
    Top Expert:
  • Music Master
  • 3,107 Answers
Wht mak and model are you asking about?
Posted on Apr 28, 2015
Periodic cutting out of main amp
Check proper impedance speakers, as this amplifier's minimum impedance should be 4 Ohm, check for the proper fan operation and free air flow thru the entire power amplifier section, hope this helps.
Aug 03, 2013 | Peavey Xr 8600 8 Channel Powered Mixer
How to hook power amp to mixer
The output of mixer connects to channel A or B of the separate amplifier and the output of the am connects to the speakers. Amp channels are listed as A and B or 1 and 2 instead of Left and Right because the manufacturer does not assume how you may wire your system. Please remember that compression, limiters and EQ device connect between the mixer and the amplifier with their prespective IN and OUT levels adjusted accordingly.
Apr 30, 2012 | Mackie 1604 Vlz3 16 Channel Mixer
How to connect a numark cdn25+g
This should help:
http://www.numark.com/images/product_downloads/cdn25_quickstartguide.pdf
You do need an amp.and a mixer. You mixer should have microphone jacks, and a pream or switch to allow you to use lowZ, High Z or amplified microphones.
Mar 29, 2012 | Numark CDn25 Professional DJ CD Player
I can't hear anything from my boss micro br without headphones....help!
I asssume you have ti connected to a mixer/amplifier as you have to have some sort of sound reproduction system connected. If you are going through a computer, you have the computer settings set improperly.
Sep 22, 2011 | Boss Micro BR Digital Recorder
Can i go straight out of the pre out on my fender frontman into a powered mixer pa system
yes,, Pre means before powered or amplified ,, so yes you can do this to a powered mixer, just be sure that the power is off before making any connections,, without the ground of the rca cable touching , the blast to the speakers can invert the cone !!
Aug 26, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
Would I need a mixer or amplifier with this product: Pyle-Pro Rack Mount 8 Channel Wireless Microphone System with 8 Lavalier/Headsets (PDWM8900)
The unit has a built in mixer as well as individual outputs. You would need an amplifier/speaker that could receive from teh mixed output jack of this. Use BALANCED TRS cable.
Aug 20, 2011 | Pyle PRO 19 RACK MOUNT PRO DJ MIXER SFX
How to hook up speakers? Sound sounds muffled
You DON'T connect speakers to this... this is NOT a powered mixer... you MUST use external amplifier !!!! You use bvalanced (TRS) cables to a suitable power amplifier which connects to speakers. Some Behringer mixers such as the PMP5000 have built in amplifiers to drive speakers... yours does not.
Jul 23, 2011 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I was just wondering how many watts the behringer xenyx 1222usb mixer can push?
The board is a mixer only, not an amplifier. A mixer simply, well, mixes audio sources into a line output which then goes to the amplifier. Your question really has no answer since wattage is determined by the amplifier used. Essentially, it can "push" as many watts as the amplifier can deliver.
Jun 23, 2011 | Behringer XENYX 1222FX MIX BOARD
Will a Behringer UB2442fx-PRO run 2 main PA speakers plus two passive stage monitors without blowing up?
ALL the speakers will either have to be POWERED or have external amplifiers. The mixer has NO power amps capable of driving speakers. When connecting, make sure that the mixer is powered by the same receptacle as the speakers or amps. Used balanced line for interconnection.
Jan 24, 2011 | Behringer Music
How do I attach power amp to 1832 mixer
There are a number of configurations for a mixer like the 1832, the most common are PA system and Recording system. There are Main output jacks which carry the mix as summed in the main faders. These in a PA system would feed the pa amplifiers which drive the house speaker system for the audience. These connectors are XLR 3 pin type on the rear, intended for professional pa amplifiers which use balanced +4dbv line input level. Amplifier which have 3 pin XLR connectors for input signals can accept that high level signal. For home style HiFi amplifiers, the signal level is nominally -10DBv and balanced or unbalanced signal lines with 1/4in diameter phone plugs which are connected to the mixer by way of a second set of Main output connectors which are 1/4in phone jacks. Use whichever amplifier input level your amp has.
If you are not using it as a main PA house mixer, but using it for recording, the main output connectors go to a 2 channel recorder or computer sound card recorder. The power amp and your monitor speakers are connected to the connectors labeled "Control Room" (CTRL Rm). These output are useful for recording because the signal through the mixer can be monitored from several buses, Solo, main mix, selected by buttons provided. The buttons only affect the signal heard through the control room monitors, and not the main output which only sees the main mix so selecting "solo" does not interrupt the signal going to the recorder while the engineer in the control can be checking other signal paths through the board.
Jan 21, 2011 | Behringer Xenyx 1832fx Mixer 18 Input 32...
Music Logo
20 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
