Question about RCA Televison & Video
I have an old rca gvibe plus gold tv is it a box i can buy to hook up cable,ps4 and xbox to it via hdmi ?
    Top Expert:
  • RCA Master
  • 10,875 Answers
  • RCA Master
  • 5,631 Answers
Obviously it needs a HDMI connection. If it has one, you can hook up all those devices. If it hasn't, no way
Posted on Apr 25, 2015
  • 4102 Answers
SOURCE: Hooking up XBOX 360
Hi have you tried going into the menu option using the telly controll and switching the hd mode on this should then allow you to use the xbox through hdmi cable
Posted on Feb 29, 2008
  • 1030 Answers
SOURCE: HDMI Cable - No Sound L42WD22 RCA Flat Panel TV
No sound and a digital picture. i will assume you have no signal on analog rf cable. Thomson(RCA) have been having problem with these sets. The trouble stems from the digital cuircit board. We see alot of these. You used to get the digital board.. they are not availble.. so rca found the component on these that fail.. A VERY SMALL surface mounted fuse. With a lighted magnifer and some fine tip twezzers. we replace these fuses on these boards. Do you have any soldering experence..
Posted on Jun 10, 2008
SOURCE: Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
Posted on May 22, 2009
gage8405
  • 5 Answers
SOURCE: TELEVISION - PS3 AND XBOX HDMI COMPATIBILITY
You have to use the scart connector for on screen menu settings. Go to the video option and enable HDMI and/or match resolution output to your set.
You did not mention the model of the TV so here is another scenario,
Just because the TV is 1 year old doesn't mean that it is a 1080p capable, you could have set the HDMI resolution settings to 1080p and you will not get any picture if your set cannot process the information.
Posted on Jul 03, 2009
zlittell
  • 30 Answers
SOURCE: Television is not recognizing HDMI inputs
there is a possibility that there might have been a power surge sent over hdmi into the hdmi board on the tv. if on your model the hdmi board is seperate from the sine board then youll have a cheap replacement if not its gonna cost you roughly 300-400 is my guess.
call your repair guy
Posted on Aug 03, 2009
Having issues setting up the PS4 can't find the hdmi slot same size as the hdmi wire that comes with the console. Hdmi wire and tv shown in pic
  • Connect the included HDMI cable to your TV and the PS4's HDMI Out port Connect your console to your cable or satellite box Unplug the existing HDMI cable connecting your cable or satellite box to the TV and plug it into the PS4's HDMI In port Plug the PS4 into a power source Power on the PS4 Plug the controller into the PS4 using the included Micro USB cable Press the PS button on the controller to pair it with your PS4
Jan 10, 2017 | The Video Game Consoles & Games
Trying to hook up a PS4 2A Oli flat screen TV help please
its a ps4 so it comes with a hdmi cable. Place the hdmi cable into the back of the ps4 and put the other end into a hdmi input
on the TV . Don't know the TV but usually there are a number of HDMI input ports on most modern tv's.
Then switch tv source to HDMI .
Happy gaming Phillip
you will have to plug the usb cable into the controller and into the front of the PS4 and then charge the controller by pressing the power button on ps4. The controller has to be paired to the ps4. The manual that came with the ps4 should go into it in more detail.
Dec 25, 2016 | Televison & Video
Can i run through PS4
34 PS4 tips and tricks for getting the most out of your console
www.techradar.com/.../25-ps4-tips-and-tricks-for-getting-the-...
TechRadarJan 13, 2016 - PS4 tips and tricks. ps4. PlayStation 4 has just celebrated its second birthday but whether that lovely parallelogram has been snug under your ...
Is it useful to connect PS4 through the Xbox One? - Xbox ...
www.gamefaqs.com/boards/691088-xbox-one/70244880
GameFAQs
So being a PS4 owner I'll be getting an Xbox One and was wondering if its useful at all to hook my PS4 to the Xbox One via HDMI... What can you use this for?
Running PS4 via Xbox One's HDMI input - YouTube
? 3:07
https://www.youtube.com/watch?v=bWxVPsyMs_0
Nov 19, 2013 - Uploaded by DigitalFoundry
Ever wondered what happens when you run PlayStation 4through the Xbox One's HDMI input? ... Xbox ...
PS4 Tips and Tricks Guide - Trusted Reviews
Jan 20, 2016 | Televison & Video
Panasonic tx-48cx400b TV turns off when I connect my Ps4 through hdmi cable. Can anyone help?
Panasonic TX-48CX400B 4K UHD 48 Inch TV (2015 Model ...
www.amazon.co.uk > ... > TVs
Amazon.com, Inc.Buy Panasonic TX-48CX400B 4K UHD 48 Inch TV (2015 Model) at Amazon UK. ...PRO GOLD RED HDMI v2.0/1.4a HDMI Cable 3D 2160p PS4 SKY HD 4K Ultra HD ...This tv offers excellent picture quality through HD sources and Netflix HD and ... TVand PC are both connected to my network switch with Ethernet cables).
for LED TV VIERA TX-48CX400B - Panasonic
www.panasonic.com/uk/.../viera-televisions/.../tx-48cx400b.ht...
PanasonicExplore the Panasonic TX-48CX400B - LED - Uncompromising 4K picture quality is yours with this 4K Ultra HD LED TV featuring an HDMI 2.0 terminal. ... Many describe the 4K effect as feeling more like looking through a window than watching ... Simplyhook up your various devices - such as a Blu-ray recorder or the latest ...Missing: turns ‎ps4
Panasonic VIERA TX48CX400B ' 48 inch 4K Ultra HD 3D ...
Dec 26, 2015 | Panasonic Televison & Video
I have hooked up my DTV box via HDMI to my Yamaha. I have hooked up my Xbox via HDMI to my Yamaha. I have Hooked up my Yamaha via HDMI to my Toshiba flat screen. I can get video from all but I am not...
It could have to do with the settings on each input device (xbox & DVR) -check their audio settings. I have a better solution for your problem though:
Since HDMI supports 7.1 ch of digital sound, I'd recommend using the optical inputs on your HTR-6130 that are made for 5.1 ch sound. I agree that you should be getting sound via HDMI, I was able to from my xbox to my 6130, but it gets cut down to 2 channel sound (good, but pales compared to true 5.1 ch sound). It believe it has to do with Dolby not being backward compatible going from 7.1 to 5.1. Anyhow, in order to get an optical-out on your xbox, you'll need connect with the a/v cables that came with the xbox, along with the HDMI cable. Depending on how old your xbox is, and which model (like an elite edition, etc), You may need to buy a special converter that will allow enough room for both an HDMI connection and the A/V connection. Trust me, I have an HTR-6130 with an xbox and a cable-provider issued box running through it. Optical is the way to go for this particular receiver since it only supports 5.1 ch sound. You can still use the HDMI ports on the receiver as a switch between your two devices, or you could choose to bypass it if you TV has more than one HDMI input port.
Nov 20, 2010 | Yamaha HTR-6130 Receiver
I am using my xbox 360 via HDMI, and I have a 5.1 surround sound system hooked up via RCA output from the tv. If I switch it onto the coax input it works, but when I switch to HDMI it doesnt. Is there a...
no, there's no firmware upgrade that you can do on the tv. the reason for that is because you are sending digital sound to the tv with hdmi from xbox 360,and when you have rca cables connecting your tv and surround sound, the rca cables provide stereo sound. what you need to do if you want to use hdmi is connect optical cable from tv orxbox 360/ or tv to your surround sound to get digital sound, and it will sound better digital sound.
Apr 17, 2009 | Samsung SlimFit TX-S3082WH 30" TV
DTV hookup for an RCA XL-100 TV
Buy a box modulator which have RF input then have RCA output that's input to your TV or other option below.
Just click and choose whatever hooked up connection you want;
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ..
Plasma or Video Projector Wiring Guide
Blue-ray Surround Wiring
HP TVs - TV Cable and Connection Types
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Jan 07, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
Analog RCA input to HDMI output?
You have said the correct thing HDMI is digital therefore Analog will not pass.
You might have RCA audio outputs on your cable box so either send them into the TV from cable or into the AMP then use AMP volume to listen to TV audio (select unused input and remember it is for TV) the key is to remember that cable box will drive the initial vol so raise or lower cable vol then use AMP vol to obtain desired volume.
Nov 29, 2007 | Onkyo TX-SR605 Receiver
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
