Question about Garden
Engine stalls when engaging deck for cutting - Garden
  • 3,519 Answers
Try running it up on some ramps so you can get access to the underside of the deck. With the engine OFF, see if the mower blades will rotate. Use a hose and do a good clean up of the underside. Check to see if there is a blade brake on any of the pulleys and make sure that it is linked properly so that it releases when you try to engage the blades.
Posted on Apr 25, 2015
  • Anonymous Apr 27, 2015
    Thanks Ted.
    You are Spot On!!
    First time owner.
    A piece of tree root somehow made its way to my blade and jammed everything up.
    Fixed now.
    Appreciate you
  • Ted Maxwell Apr 27, 2015
    Glad to help! On with the day :)
SOURCE: Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
Posted on May 15, 2009
  • 87 Answers
SOURCE: engine cutting off
Depends on how it cuts off. If it gradually slows down over a few minutes or surges, it's likely the carburetor needs to be cleaned and rebuilt. But if it's an immediate cut off, it's likely to be a safety switch such as the one that shuts down the engine when you get off the seat if the mower is running. Sometimes this happens frequently to a light person who bounces on the seat when mowing.
Posted on Jun 07, 2009
panilling9
  • 284 Answers
SOURCE: engine chokes & dies when deck PTO engaged...
you need to start with your electric clutch and then backwards to your idler pulleys and deck spindles and bearings.
your electric clutch should almost stop the blades instantly when disengaged ,check the center bolt in the clutch to be sure it is tight also
remove the belt from the electric clutch and energize clutch any noise? sometimes the bearing goes bad in the clutch itself.
check all of your 3 spindles for noise and loose. remove belt and spin by hand and listen for quiet and they should turn free with no binding
check blade tightness
any item the belt goes around needs to be looked at for secure and operable.
Posted on Jun 09, 2009
  • 133 Answers
SOURCE: ride on Mountfield Lawn mower 1228H - engine cuts out
Check to make sure there is no obstruction in the blades or on top of the deck where the belt goes. Also check that your pulleys turn freely and that a bearing didn't freeze up.
Let me know if this helps.
roundo4
Posted on Aug 08, 2009
mickey813
  • 472 Answers
SOURCE: John Deere CR125 hydrostatic mower, engine runs
sounds like you have carb problems
Posted on Oct 15, 2009
How do I fix it?
Charlie, Check safety switches reverse, seat, deck engagement,etc. and the wires,plugs to switches, ensure battery is good and charged check ground connections and ignition plug is clean tight and no pinched bare wires, etc., check the blade spindles are not seizing and move freely, belt is on properly.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://support.mtdproducts.com/app/answers/detail/a_id/193/~/engine-shuts-off-upon-cutting-deck-engagement---riding-mower
http://www.tractorbynet.com/forums/general-lawn-garden/157053-engine-starts-cutting-out-after.html
Craftsman Lawn Tractor stalling out
https://answers.yahoo.com/question/index?qid=20090510130417AAN6YxP
May 15, 2016 | Garden
Why does my rover rancher stall when i go to engage the cutting deck
1>the pressure switch under the seat may be malfunctioning? (it will cause the engine to die immediately when trying to engage the cutting blades because it thinks your not sitting in the seat.
2>dirty or clogged air cleaner element will cause engine to die when engaging cutting blades. This can be tested very easily by removing the air cleaner element and then trying to engage the blades again. If this works then replace air cleaner element immediately before running the engine anymore.
I have personally experienced both of these problems myself more that once.
Feb 17, 2015 | Garden
Engine stalls
could be a stuck pulley or bearing, or debris in the cutting deck. make sure the blades turn freely with mower off and blades dissengaged. If they dont, remove the deck and check all of the pulleys for freeness.
Jun 02, 2014 | Craftsman Garden
What is causing my enginge to stall when I try to engage my mower deck?
Check the seat switch it might be disconnected. It will cut the mower off if you leave the seat without disengaging the deck.
May 24, 2014 | John Deere L100 Series
I HAVE A DLS CRAFTSMAN LAWN TRACTOR AND WHEN I ENGAGE THE CUTTING DECK IT STALLS OUT
There is a seat switch to protect the driver in the case of him/her being thrown out while the blades are going, and if this is disconnected or not working the engine should cut out as soon as the blades are engaged.
Tilt your seat back and check the switch connections out.
Oct 30, 2013 | Craftsman Garden
Why does the engine of my Kubota ride on cut out when cutting
Sounds like you have a bad safety switch somewhere, possibly the seat switch.
Aug 10, 2012 | Kubota Garden
Engine stalls when you engage cutting deck, do i need a new clutch
first i would check the safety switch on the seat then check all the pulleys on the mower deck for binding if the clutch was bad the engine wouldn't stall
Jul 08, 2012 | Garden
Need a troubleshooting manual for a craftsman mod. 917.287070
Went out to cut grass and the blades will not engage and when I put it in gear it does not move. Belts are intact. I cleaned the deck of dirt and grass. Still nothing. Just replaced the cable to engage the blades last year. Cable seems to be working.
Jun 25, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Sep 07, 2009 | Garden
May 14, 2009 | Mtd Garden
Garden Logo
121 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
