Question about Kenmore 2537031321 Stainless Steel 26.7 Cu Ft French-Door Refrigerator Bottom Freezer, Energy Star
Error Code SY CF wire in ice caddy is exposed and when I removed the ice caddy, the code came up and now the fridge and freezer will not cool.
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 310 Answers
In some model years, the defrost timer was installed in the icemaker. So, even if the icemaker itself is inoperable, it must remain plugged in to the unit to operated the compressor.
Posted on Apr 25, 2015
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
Error code 24 e. Freezer defrost error. Now what do I do? Help Please!
You have a problem in the de-frost system. Could be a timer, very common, heat element, very common. Look on line or your owner manual and see what that code is telling you. The average person can not make this repair. Hope it is under warranty.
Aug 27, 2016 | Samsung RFG29PHDRS 28.4 cu. ft. French...
Fix my problem get sy cf on my display
Hello Eric espy, thanks for your post!
From my understanding you used the icemaker on your Frigidaire refrigerator and now have a code of "SY CF" on the display. That code of "SY CF" stands for communication failure after power up. This could be a possible communication error between the UIB (User Interface Board) and main control board. I would suggest performing a reset, which should clear any false error codes. If you continue to receive the error I would suggest contacting a professional technician for proper diagnosis and repair. This may help you avoid unnecessary part purchases. -Matt
Feb 22, 2015 | Frigidaire Refrigerators
What does an O F fault code mean on a frigidaire refrigerator mean
Sounds like off to me. An open sensor will be displayed in either the ff display or the freezer display. if it is an open freezer sensor it will display in the freezer display. A communication failure will show as a SY CF, and a communication error will display a SY CE.
Feb 18, 2015 | Frigidaire Refrigerators
I have a Frigidaire gallery refrigerator with a error code 5y cf I put in new ice maker and a new control board still have same code anybody got any sugstions plase
hello jon;
my name is peter. i am a retired field service refrigeration technician.
cf= cooling fan. is your freezer fan running? is the back wall of your freezer section iced up? is your fresh food section cold?
send me your model number. it is on a label, on the inside wall of your fresh food section near the top.
Jan 21, 2015 | Frigidaire Refrigerators
Refrigerator has error code 5Y CF
Thank you for your question, Friend.
Typically error code SY CF, is commonly referred to a communication failure after power. A tech would typically check the communication wiring wires between the main control board and user interface board to determine the cause of the error code. It could be a hit or miss calculation in the parts so I would personally reach out to a professional that will be able to identify the precise reason. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect. - Z
Aug 13, 2014 | Frigidaire Refrigerators
Will the fridge still work with code sy cf
Hello Friend, thank you for your post!
If you are getting an error code SY CF, it typically means that your refrigerator has detected an error between the main control board and the user interface (the control on the Freezer door). A tech would typically check the communication wiring between both parts to determine the cause of the error code. If the wiring is correct, then more than likely you are looking at a faulty main control board or user interface.
In the meantime, you may try resetting your refrigerator by disconnecting the power from it for up to ten minutes. You can do this by flipping the circuit breaker off and back on. This often clears most false-error codes. Hope this helps! - Z
Jul 06, 2014 | Frigidaire FGHB2844L
Frigidaire SY CF issues
Good Morning Jack, thank you for your question!
Typically error code SY CF indicates that your refrigerator has detected a communication failure after power up. The error code may possibly continue after replacing the part you have ordered. With this error code, a professional would need to check wiring between the main control board and user interface board. After proper diagnoses and if the error continues, the main control board may need replacing. Hope this information helps to some degree!
Dec 27, 2013 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire FGHS2644KF. Fridge just died. Flash code of 5YCF.
Hello erintu81 - SY CF typically indicates that the refrigerator has detected a communication failure after power up. The wiring between the main control board and user interface board will need to be accurately diagnosis. Depending on the results either or will need replacing. At this point, I strongly recommend connecting a professional to move forward accurately and to properly assist with the repair(s).
Mar 01, 2013 | Frigidaire FGHS2644KF (260 cu ft) Side by...
My frigidaire is displaying SY CF
Hello Angela Clark - Typically error code SY CF indicates that the refrigerator has detected a communication failure after power up. Contact a professional to move forward accurately. The wiring between the main control board and user interface board will need to be check and diagnose. Depending on the diagnoses the main control board may need replacing.
Dec 05, 2012 | Frigidaire FGHB2844L
Kenmore 2537031321 Stainless Steel 26.7 Cu Ft French-Door Refrigerator Bottom Freezer, Energy Star Logo
486 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
