Question about Olympus SP-350 Digital Camera
Removing back of the camera to replace LCD screen
I can not take the camera back apart, please help!'
  • 48 Answers
I can not remember exactly how the camera is assembled, but make sure you have taken or looked under all the rubber pads on the camera. There are sometimes hidden screws under such pads, or under the USB/Memorycard Door/Power spot on the camera.
Never force the camera, you will only break the clips and latches and cause your camera to become a paperweight. When you get the camera open, also make sure to watch, there are two-three ribbon cables connecting the back panel, the LCD and the backlight to the main boards, and you don't want to break those.
Posted on Nov 17, 2007
I broke the display panel and i need a new one con you send me one an how much cost me? I can replace de oanel.
If you can, carefully take your camera apart and remove the old screen, Look at the numbers on the back of the screen and ebay them, If your unfamiliar with how to remove a camera screen you can try and ebay soomething like " LCD+nikon coolpix l11 " and see of your able to find a LCD screen replacement. Most screens are under $20. The biggest thing if your doing this is to be careful with the screen connection and the little tab holding the screen cable in. Take your time and you will have little to no problem.
Jun 29, 2010 | Nikon Coolpix L11 Digital Camera
Touch screen shows wear and tear
LCD will be replaced as there is no cure for wear and tear on its surface. Required LCD part number is appended below:
A1334748A... FTS BLOCK ASSY (35STMG07)
Available in Sony Parts Store for $154
If you are handy with electronics stuff repair then can replace it easily, remove side and bottom screws and take apart front and rear cabinet of camera. Unlock connector that holds lcd flexible connection wire, remove solder connection of back light source plate from lcd flexible wire, solder back light connections in new lcd flexible wire and insert it in jack on main board of camera.
Local camera repair shop will help you to replace lcd if you feel uncomfortable doing so.
May 19, 2010 | Sony Cyber-shot® DSC-T200 Digital Camera
Sony cybershot dsc-w120 broken lcd screen (inside, not out) how can I fix it?
Camera will be apart to replace LCD. remove screws at sides and bottom of camera to apart it.
LCD is available in Part Store under following part number..
LCD901 "875329694" ACX358AKR-3
Oct 11, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Cracked LCD on Canon PowerShot A510. A few weeks back, I noticed that my LCD view screen was cracked on my camera. The camera still functions since I use the other view finder anyway. However, I obviously...
Your best option is buy a junk one off ebay and replace LCD. LCD replacement is very straight forward, just remove the screws, pry the case apart and the rest will be easy. Use the one you buy off ebay and practice getting it apart.
May 07, 2009 | Canon PowerShot A510 Digital Camera
Need to replace lcd screen
Remove screws,pull apart camer, pull screen part off, then pull ribbon connector out (it slides and pulls out) Reverse to install new screen.
Please tell me where you got the screen because I am looking for on e myself. Thank you
Feb 01, 2009 | Kodak EasyShare C653 Digital Camera
My daughter dropped my camera. Screen broken.
That screen is the lcd screen (liquid crystal display)
I had a fuji E900 that was dropped when the lens was extended , and it broke the lens mount ring inside the camera.
I took the camera apart to try and repaair it.
as part of the dissasembly I removed the lcd .
If you can find a parts camera.with a good lcd, it is worth the effort to simply replace your lcd.
if you need mor info email me , and I will try to describe the dissasenbly sequence for the fuji that I had, perhaps it will be the same for your camera.
Jan 05, 2009 | Fuji FinePix S5500 Digital Camera
How to replace LCD monitor/screen in an Olympus C5050 camera
Easy, remove the 9 screws that hold the rear case and pull the case apart,.remember there are 4 screws under the hotshoe base and 4 under the memory door and one under the USB cover. You need to pry and slide the hotshoe base back with a slim screwdriver and youll see 4 screws, remove the rear ones. There will be 2 ribbon cables attached to the rear case, the LCD and the buttons. These pull out carefully with gentle pressure. The LCD can be removed with screws and another ribbon cable connector that needs to be unclipped and then removed. replace LCD, Put it back together and make sure the ribbon cables are fully seated. Good to go.
May 06, 2008 | Olympus Camedia C-5050 Zoom Digital Camera
Broken LCD screen
your answer to this problem is easy. First take the batteries out of the camera, then open the camera ( screws should be in the back) the screen should just pop out of the cover and there is a ribbon cable that connects the screen to the circut board. Gently un-hook that ribbon where it plugs in to the board there might be a slid lock to hold the ribbon in place, it should unlock when you pull the cable out (memorize what position the ribbon is before unplugging). Now the fun part, do the same thing to the other camera, (carefully). To install the new screen, plug the ribbon back into the slot and it should be snug, if not there is a lock on it, gently push it back away from the ribbon ( a little finger pressure). Now, simply put it back together the same exact way you took it apart and don't forget the batteries. Have fun taking pictures...
Nov 01, 2007 | Olympus SP-350 Digital Camera
Olympus SP-350 Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
