Question about Pool & Spa
My bestway pool heater is flashing red and making a continueious ring noise is this what it is ment to do thanks in advance
  • 1,631 Answers
Best way pool heater???
Never heard of it!
Is this an import heater from China?
Like maybe for one of those Toy Pools?
... Anyway, if it never flashed red before, then there's a possible problem.
any noise other than a quiet hum, is not normal.
is this gas or electric? I'm curious
Posted on Apr 26, 2015
E05 on bestway
check safety circuit and gas then ignitor 5 usually means gas
Oct 15, 2013 | Pentair Mastertemp Pool & Spa Heater Dual...
Pentair MiniMax NT fan turns on then off after a minute or less. Flashing red light 3 times indicates Ignition lockout. How do I fix this? Thanks in advance
For some reason the ignition is not working or there is a gas supply issue. Best get a tech out to check it, these heaters are tricky.
Sep 10, 2013 | Pool & Spa
Pentair Pool Heating Rapidly Increases Temp on Panel then shuts off.
Check the Thermal Reg in the header and also make sure you have adequate water flow thru the heater, make sure your filters are clean and there are no external by-pass valves open.
If you remove the Thermal Reg in the header and the heaters seems to run fine the replace with a new one.
May 03, 2017 | Pentair Minimax NT Heater
Timer on chlorinator will not go on after 24 hours
The 24 hour timer is probably faulty and needs to be replaced.
Jun 04, 2012 | Bestway Usa Type 2 or II Bestway...
We have refiled our lay z sap, after it dispaly shows 3 dashes
You probally just need to break an air lock in the pipes. You can ether force water down the skimmer pipe or find your drain valve and open it for a minute or two till it runs just water and no air. This will get water to the pump and the heater. This should fix you up.
Aug 02, 2010 | Pool & Spa
Fridge freezer problem
Sounds like the defrost system of your freezer is not working. It could be either the defrost timer, defrost thermostat or the heater has a problem. The defrost timer turns off the compressor periodically to sent power to the defrost heater via the thermostat. The defrost heater then powers up and heats the evaporator coil to melt the accumulated ice buildup on the cold coils. Most likely issues are that the timer motor is not advancing the timer or the heater itself has burned out.
Jul 14, 2010 | Freezers
Bestway Lay Z Spa pump not working!
check recirculation pump and heater element
Oct 23, 2017 | Pool & Spa
My spa is showing - - - and flashing the red heater light. what dose this mean and how can i fix it?
depending on what type of spa you have, the three dashes usually mean that the control system is in "watchdog" mode and is normally caused by one or more faults in the series of sensors. You need to test or have someone test the high limit, water temperature sensor, and the flow sensor/switch. One of the sensors or possibly more than one is most likely bad. Check to make sure mice have not got under and chewed the wiring.
Hope this helps. There are so many spas on the market, without knowing which spa you have, it's difficult to offer accurate solutions. Sounds like you have a sundance spa.
Oct 01, 2009 | Intex BESTWAYS 12X30 FAST SET POOL
Pool & Spa Logo
188 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
