Question about Euro-Pro Irons
Handle on my steam iron is too hot to touch
The handle gets way to hot and i need to wear gloves to iron
  • trish
    trish Apr 27, 2015
    this steam iron works and gives steam and is the right temp but the handles gets way too hot...need to wear special gloves or it burns your hands...what is wrong with this iron and can anyone help me to fix this???
  • Euro-Pro Master
  • 2,963 Answers
Could be a hidden recall. I'd check MFG website, or email their customer service.
Posted on Apr 27, 2015
What can be done about leaking steam?
ensure your iron steam button is not set into perminent steam function. leaving the iron with the point of the iron pointing upwards should reduce steam to the handle. also the iron may need to be descaled to ensure any steam switch funtion is not stuck in an on position.
May 12, 2014 | Euro-Pro Steam Generator EP8001 Iron
Wet steam coming out of iron
You have to take part the iron by unscrewing the three bolts on the side handle with a small phillips driver. Then loose the allen screw on one side of the black thermostat wheel to unloosen it. Then take out the two bolt plastic protectors under the handle and unscrew the two allen bolts, carefully separate the top from the botton of the iron, carefully not to pry loose the cables from the top to the hot shoe.
On the back you will see a small white square box, that is the thermostat, which has a button on top, all you need to do is to push it in. This will make the iron heat up unless you have a thermostat failure (Black wheel with temperature indicators), which you will need to order the part and change it.
Mar 07, 2013 | Reliable i30/120V Professional Steam Iron...
HI I have a Bosch Sensixx B25L iron. Steam isn't coming out of holes, seems to be escaping from edge of iron. Handle very hot (Too hot to hold on to), burns your hand when steam button is pressed
I just fixed mine - it had exactly the same problem.
First, though, check it's not within the Bosch TWO year guarantee; if it is, they'll either fix or replace it.
If it's not under guarantee then the problem is probably the rubber tubing that connects the external steam tube to the hotplate. You'll need to dismantle the iron. Mine had split right next to the spring clip that holds it on. I shortened it, clipped it back on and all is now well.
Jul 28, 2012 | Bosch sensixx TDA 8333 Iron
Users instructions elitech 2000w steam iron
alas we've had the same problem since day one, just opened it up, must be the boiler unit leaking at the start to emit the steam so the handle gets hot and now the seal is totally gone it will just leak when the water gets too hot
Dec 12, 2011 | Irons
I have a Tefal Pro Express Turbo iron (purchased in 2005). In the past 2 days the steam is constantly on - the button does not appear to be stuck. I can't get the steam to stop... unless I take out...
Yes, if your electric cord was extremely hot to touch is not common. It's posing danger to your unit and to your entire electrical system that may cause fire. Please let a qualified electrician inspect and repair your unit. The unit thermal fuse may not functioning that automatically switch off or cut the electric power of your unit when it gets too hot. Thank you for asking.
Jun 14, 2011 | Tefal Pro Express GV 8120 Iron
NO STEAM COMING OUT....IRON IS HOT AND WATER IS HOT, BUT PUSH SWITCH FOR STEAM??NOTHING COMES OUT
you need to use a descaler, the holes have become clogged. you can buy this in most hardware stores
Mar 23, 2010 | Rowenta DG-980 Iron
I have an elitech steam generator iron but water does not get hot so no steam (iron works fine)
I have had this iron for 5 months and only been used 4 times. When I turn it on , there is water leaking out of the iron and the handle is too hot to touch after a few minutes
Dec 28, 2009 | Irons
Rowenta Powerglide 2 INOX vertical steam, no steam, just water leakage
replace the o-ring gasket on the tank fill cap. It is a simple neoprene "O" ring you can buy at your local hardware or NAPA aauto parts store for less than $3.00.
st. louis mo Ralf
Sep 09, 2008 | Rowenta Steam Generator DG050 Iron
No steam comes out of iron
Hi, there is probably a something broken in the moulded plastic trigger assembly (there is a plastic broken finger that actuates a micro-switch under the rubber handle cover). If you are so inclined, use an orange stick and gently pry up the rubber handle cover on either side from the front to the rear cord end to access, inspect and troubleshoot. I am in SoCal and use the California Electric website to obtain parts or go to the Rowenta home website to locate useful manual information, PDF reader and dealer near you.
Jul 09, 2008 | Rowenta Steam Generator DG050 Iron
Irons Logo
288 people viewed this question
Top Euro-Pro Irons Experts
Henry  Thomas
Henry Thomas
Gil Shultz
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
