Apple iPad Mini Logo
A
Anonymous Posted on Apr 25, 2015
An ipad in lost mode can not unlock....do not have icloud info
Harrie
Level 3:
Top Expert:
  • Apple Master 6,746 Answers
  • Posted on Apr 25, 2015
 Harrie
Apple Master
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1284423
Points
83153
When the iPad was set, there was an Apple iTunes account connected to the iPad. Apple would not have activated the device. You should be able to get a message to the mail address that you connected to that account. Ask Apple to reset the password via their support. Go here:
https://www.apple.com/support/appleid/manage
2answers
How to unlock an ipad
If you remember the password of your iPad, it's would be easy. However, you can still refer to below steps to unlock an iPad without password.
It is a good habit to have your iPad backed up regularly. In case of your iPad is locked, disabled or being stolen, you can easily recover your data from it. Otherwise, you'll lose all the data. To unlock iPad screen without password or to unlock disabled iPad mean you have to remove your previous pass code and restore your iPad. Here we introduce three methods which you can follow.
Method One: How to unlock iPad without password using iTunes
  • 1. Connect iPad to the computer you have synced with.
  • 2. Open iTunes on your computer and connect it with your iPad. If fortunate, you can enter the iTunes without password. But in most cases, there would be prompt asking for a pass code. Try another computer you've synced with, or use recovery mode. (The recovery mode will be mentioned in method three.)
  • 3. Find your iPad in summary and make a manual backup. Once the backup have finished, click Restore your iPad with the most relevant back-up.
Method Two: How to unlock iPad screen without password with iCloud
You can also use iCloud to remove your password and recover your data if you have backed up before it was locked. And it is in the premise that you have set up Find My iPhone on your iPad, and you did remember your Apple ID, you can use iCloud to unlock your iPad.
  • 1. Open your laptop or computer, go to icloud.com/find or open the iCloud app.
  • 2. If the sign-in window pops up, just sign in with your Apple ID.
  • 3. There's an All Devices button at the top-left of the window, click on it to call out a drop-down menu and choose your iOS device.
  • 4. Click Erase (your device) in the prompt to finalize the process.
  • 5. Now you can either recovery data to your device from a backup or set up as new if there isn't any back-up before.
Method Three: How to unlock a disabled iPad in recovery mode?
If you've neither synced with iTunes nor set up Find My iPhone in iCloud, you'll need to wipe your iPad to factory setting to remove the password, which means you'll suffer losing all your data on iPad and get it as a new one.
Please pay attention there is a slight difference in putting different models of iPad into recovery mode.
iPad Air
  • 1. Turn off your iPad Air, press and hold the Home button.
  • 2. While holding the Home key, connect the USB cable to the device. Wait until the Apple logo appears and keep holding the Home button for few more seconds.
  • 3. Continue holding the Home button until the iTunes logo appears.
iPad mini/iPad pro
  • 1. Connect your iPad to your computer or laptop and open iTunes.
  • 2. While your device is connected, force to restart it.
  • 3. Press and hold the Sleep/Wake and Home buttons at the same time. Don't release when you see the Apple logo. Keep holding both buttons until you see the recovery mode screen.
Now you have entered the recovery mode, and
1. When you see the option to Restore and Update, click it.
restoring-ipad-software-cpmn0ithqpr5j0kd3fh1ly4i-5-0.png For more details, check: How to Unlock iPad
No how to unluck my ipad
There are a number of ways to unlock iPad. You can resort to iTunes or iCloud "Find my iPhone" feature. Just follow below steps to do that.
For more methods, check: How to Unlock iPad?
Ipad is disable
If your iPad has been disabled, it is completely locked down. The only way you'll be able to use it again is by restoring it using iTunes or iCloud. If you have a backup, you'll be able to recover your data, but this process will delete everything that is stored on the iPad. Except for the following methods, there is no other way to unlock a disabled iPad.
  • Using iTunes
  • Using iCloud Find My iPhone
  • via Recovery Mode
  • via DFU Mode
How to Unlock Disabled iPhone with without iTunes
2answers
How do i bypass a icloud activation screen on ipad 2 reported lost
Unlock Timeframe: 7-15 working days
iPhone Carrier iCloud Activation (Clean Only) Choose an option... iCloud Activation (Clean Only) iPhone Model Choose an option... Choose an option... iPhone 6 Plus iPhone 6 iPhone 5S iPhone 5C iPhone 5 iPhone 4S iPhone 4 iPad Clear selection
IMEI: Please add IMEI number which contains 15 characters only
2helpful
4answers
How do i unlock my ipad i bought it used and i dont have a password and now it is locked and asking for password
You will have to restore it by connecting to iTunes on your computer. That will erase all settings including the password. If you have a backup you can get it then set up as a new device with a new password.
How can I login to my iPad when the passcode isn't working?
You have to reset your iPad. Just follow below steps.
How to unlock iPad without password or how to unlock disabled iPad? It is a good habit to have your iPad backed up regularly. In case of your iPad is locked, disabled or being stolen, you can easily recover your data from it. Otherwise, you'll lose all the data. To unlock iPad screen without password or to unlock disabled iPad mean you have to remove your previous pass code and restore your iPad. Here we introduce three methods which you can follow.
iPad Air
iPad mini/iPad pro
2. Wait for the process to finish. Then you can set up and use your device.
itunes-summary-4wdcyutupah1kirb0sfrwsm2-1-0.png For more details, check: How to Unlock iPad without Passcode
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
