Question about 94 95 96 97 98 Chevy Silverado Billet Grille Grill 2pc Insert
Whats causing gas to get in the oil - 94 95 96 97 98 Chevy Silverado Billet Grille Grill 2pc Insert
  • Brock Saint Aoro
    Brock Saint Aoro May 02, 2015
    Hi Anonymous, Do a compression on your cylinders, the only place your oil and fuel meet is in the combustion chamber, it sounds like you have some bad rings. You can find out by doing either a leak down or compression test.
  • Chevrolet Master
  • 1,051 Answers
If you have a fuel injector sticking it can cause the gas to flood the cylinders and flow into the oil pan. Pull the plugs out and you should see one that has to much fuel on it or else it will be black. Be sure to change the oil and filter before starting up the engine again because if it fires the gas in the oil you will blow the engine.
Posted on Dec 03, 2015
  • Chevrolet Master
  • 3,519 Answers
Older engines had mechanical fuel pumps attached to the side of the engine and driven by a push rod. If the diaphragm in the fuel pump failed, gas could get into the engine crankcase and dilute the oil.
Posted on Apr 25, 2015
Gas in oil
Generally speaking, there are two ways for gas to get into the engine oil.
A leaking fuel injector, or a faulty fuel pressure regulator.
Apr 28, 2013 | Volvo 740 Cars & Trucks
My trimoto 125 mixes gas in the oil whats theproblem
Gas in oil usually gets there in a 4 stroke engine in one of 2 ways- through the induction system from a defective valve in the carburator, or a ruptured diaphragm on a fuel pump that is attached to the crankcase. If the carburetor has a float bowl, the float may be faulty, the needle and seat may be faulty or dirty, otherwise the diaphragm types can have either or both types of valving to control fuel flow into the engine.
Apr 27, 2012 | Motorcycles
Whats the best premix gas to use on a Husquarna 125B hand held Blower
The best mix to use is what's recommended in the manual but in most cases blowers use a 50:1 mix. The difference from 40:1 to 50:1 is negligible but you have to use what the motor is built for. Too much oil causes a loss of power because the gas won't burn efficiently. Too little oil and you risk damaging your piston or cylinder.
Feb 22, 2012 | Husqvarna Hand Held Blower 125 B Grass...
I have a 01 cavalier and at idle or low rpm the oil warning light comes on and then turns off when you step on the gas. this only happens after the engine is warm. whats causing this?
You might get lucky and have a faulty oil pressure switch.More likely though,the oil pressure is dropping at idle due to a worn engine.Replace the switch and hope for the best.If the trouble persists,you'll need to do engine work
Sep 06, 2011 | 2001 Chevrolet Cavalier
Whats the oil to gas mixture ratio for a Homelite 42 cc chainsaw?
Use 2.6 ounces of oil per gallon of gas to give you a 50 to 1 ratio of fuel to oil.
Jun 16, 2011 | Homelite Garden
Gas mixing with oil even while motor is running. whats causing this?
if its smoking alot oil ring on piston stuck in oil passing the piston engine will smoke
Feb 11, 2011 | Karcher 2500 PSI Pressure Washer
I was wondering whats the oil everyone is using,on motocross bikes. not gas /oil mix. motor oil? thanks
two stroke gearbox oil, or four stroke engine oil,both are designed for use in the gearbox. has to state for motorcycle use on the label, as car oils can have friction modifiers that cause clutch slip, and dont be fooled into using automatic transmission fluid, some swear by it cause its thinner and good for the clutch , but the gears will wear faster, and eventually break.
Apr 07, 2010 | Suzuki Rg 250 Motorcycles
Check gage light comes on for 2004 chevrolet trailblazer''
Check gauge light can come on for a number of different things, from Low fuel to low oil pressure to high engine temperatures. When the light comes on check all the gauge's and see whats causing it, one or more of the gauge's will be showing an issue, Low fuel or low oil pressure, Low battery power. Any of the mentioned things can cause it... Figure out whats causing it then you can remedy the situation...
Apr 19, 2009 | 2004 Chevrolet TrailBlazer
High limit tripping
Foxtrot---i answered you last time im the hobart tech,your still having this issue?tell me exactly whats going on--we'll solve this!
Jan 11, 2008 | Kitchen Appliances - Others
94 95 96 97 98 Chevy Silverado Billet Grille Grill 2pc Insert Logo
91 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
