Question about Philips MX5100VR System
How do I get sky tv through my philips mx5100vr home theatre
Using scart leads
  • Philips Master
  • 5,349 Answers
External Input Mode (for VCR features) To receive the signal from an external input (decoder, satellite receiver, video camera, another VCR etc.), connect to the AV2 (DECODER) socket, and enter "002" with numerical key pads to appear "AV2" on the TV screen.If you use the AV1 (TV) socket, enter "001" with numerical key pads to appear "AV1" on the TV screen. If you use the front AUDIO/VIDEO input jacks, enter "003" with numerical key pads to appear "AV3" on the TV screen.
Posted on Apr 27, 2015
Philips DVD player no sound
Are you using a scart lead to connect to tv try changing lead as some times scart leads don't have all the pins I prefer to use scart leads that have all the pins in them and make sure they are firmly pushed home also check settings on tv as some tvs allow you to mute av plugs
Apr 10, 2014 | Philips Dvd Video Player
Rdr dc90
Your recorder is mostly analogue with just a hdmi output, you need to link up using a scart lead or similar adapter lead for recording, looks to me like scart 1 (decoder) or the front sockets for input use while. the other scart looks to be just for TV to use.
If your TV has another hdmi then I would have thought your sky sat would connect that way leaving the scart for your video.
Though if it has only one, then you are looking at a multi input box for hdmi (some are automatic others have remote control) or demote your video's hdmi lead and connect it to the Sky sat, use the scart lead to link it with the video's scart 1 and the other scart socket to TV by the look of things.
Its a problem with older and younger equipment because they are built at different times with their connections decided by that time of manufacture.
Hope this helps..........
Sep 26, 2017 | Televison & Video
I cant get dvd recorder to record ext 2
Firstly, is the scart lead plugged in fully? Does it get the sound or nothing?
Is the recorder sitched to the correct input? It may be trying to pull a signal from the TV which may not be passing through the picture from the sky box.
Also, is the scart lead fully wired? Some only work one way so try spinning it round between the recorder and sky box.
Nov 24, 2011 | Philips DVDR70 DVD Recorder
Hook xbox 360 up to philips mx5100/37 home theatre
Try Putting the "prongs" (RCA connectors into the front AV socket of the Philips System.
You could hook it up at the back but that requires the xbox to SCART lead. (Scart is the 2 pin socket on the back (2) that are about 5cm long
If you aren't fussy then just plug it into the front and select the front av input and you are away!
Happy Gaming!
Jan 17, 2010 | Philips Audio Players & Recorders
Ghosting of picture from a Panasonic home cinema system
There must be a fault in the screening of the internal wiring to the scart outlet in the home theatre system. I simply changed the way the player was connected to the TV and the interference disappeared:-
1.) I used the RCA video outlet instead of the scart lead. Picture quality was not compromised. FYI the Panasonic Plasma TV I have has only RGB video input sockets at the back, so I used a scart to RCA adaptor to overcome this problem of connecting old technology to new.
2.) The surround sound when playing DVDs is generated directly from the home theatre system so there was no need to connect the audio from the home theatre system to the TV
3.) I used a pair of RCA leads to connect the "audio out" from the TV to the "audio in"on the home theatre system to provide the option of TV sound through the home theatre system.
Mar 18, 2009 | Panasonic Televison & Video
I have a philips dvdr70
From the Sky box, plug one SCART lead to your recorder and plug another to your TV. Then plug a SCART from the TV to the recorder.
You can then select the SCART connector for the sky box to record programs.
This will work after the digital switchover. The switchover is only for 'normal' tv signals from your tv aerial
Jan 12, 2009 | Philips DVDR70 DVD Recorder
Samsung le40a lcd - picture quality
Hi - I have some suggestions. The following factors effect picture quality:
1. Source (because LCD TVs have much higher picture quality than traditional CRT "Tube" TVs, the worse your source material, the worse it looks on a LCD TV).
DVD and Sky/Digital TV should look excellent on this TV when connected with a good quality Scart lead (nothing too expensive, but a Oxygen Free Copper Gold lead may help) directly into one of the TV's Scart inputs (avoid using "switching" boxes for multiple equipment).
Also, bear in mind that this is a HUGE screen (40 inches I think) and will REALLY show up bad source material.
The best advice I can give is, if you have HD-ready equipment use HDMI connections for everything (ideally with an HD-uplscaling DVD player which will "improve" the quality of standard DVDs on the TV - I recommend models by Philips) and check that you are in "Movie" or "Cinema" mode on the TV.
Make sure that all of your equipment, like your Sky digibox, is set to 16:9 mode (not 4:3) aswell to preserve the true widescreen aspect ratio.
Hope that helps!
Dec 31, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
No picture on TV through Sky, Home Cinema is on but have sound.
do have sound and picture at same time you will need a fibre optical cable, you connect that from your cinema system to your tv. then you need to set your cinema system to digital input or fibre optic or check by pressing aux on your remote and see which is the right one. i am not familier with panasonic as i have samasung.
Dec 10, 2008 | Panasonic SC-HT75 System
Connections
conect ps3 audio throw optical
Dec 26, 2007 | LG MU-50PX10C 50 in. Plasma HDTV
Panasonic home Theatre
You need to obtain audio leads and connect from home theatre directly to audio input in back of tv - be careful as there are normally 2 in back of tv
Dec 14, 2007 | Panasonic SC-HT720 System
Philips MX5100VR System Logo
158 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
