Question about Whirlpool WTW6400SW Cabrio Washer
It goes to F1 shortly after lid is locked. - Whirlpool WTW6400SW Cabrio Washer
Ok that's what I thought because there is not an FL error, anyways F1 is a very bad error code and it means that your main control board under your control board has detected an internal short in the board itself. To correct your issue you will need to replace the board
quoted from another site
however i think the pump housing has cracked allowing water into the pumps electronics
so you may have to replace the pump
and perhaps clear the error
a good visual inspection is needed first of the pump drive motor and the controller board
usually its water somewhere causes the issue with the controller board
the board is easy too repair
each output to the likes of the pump etc
is switched by a three pin triac device
and its driver
so can be fixed
so you need to source a new mainboard
or repair your one
and perhaps change the pump or look too why the controller board has gone wrong
i strongly suspect the pump housing has leaked water
and the pump control circuit has an issue
so if the controller board is an issue
it will be caused by another issue moreover the pump or door lock
does it let in any water before the fault occurs???
Posted on Apr 28, 2015
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: delayed lid lock and F1 signal on dial. Push pause...
Keypad/User Interface Failure
A fault code of "F" then "1" flashes when there is a primary control failure.
You will need to replace the machine/motor control assembly.
Page 14 and 16, in the manual link below will help you with this.
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
To Access/replace the CCU:
#1
Unplug the Whirlpool Cabrio power cord from the wall outlet. Turn off the water supply to the washing machine. Pull the washer away from the wall so that you can access the screws behind the control console. Remove the hex head screws securing the control console to the washer with a nut driver. The screws are on the lower rear edge of the control console.
#2
Lift the control console up, and rotate the console forward so that the face of the console is resting on the top of the washer. Locate the interface board cable connector to the right of the plastic tube on the back of the console. Pull the end of the connector straight out of the control console. The primary machine control is the box that the plastic tube connects.
#3
Place small pieces of masking tape around the nine wires connecting to the primary machine console. Label the wire locations onto the masking tape with a pencil. Grasp each wire at the connector with your fingers, and pull the wires away from the primary control. Pull the plastic tube out of the primary control.
#4
Locate the nut toward the bottom of the primary control. Remove the nut with a nut driver. Lift the front of the primary control slightly, and slide it down to disengage the retaining clips. Pull the primary control out of the control console. Insert the new primary control into the control console. Slide the primary control up to engage the lower clips. Secure the primary control to the console with the single hex head screw.
#5
Push each of the wire connectors into their respective positions on the primary control until they lock into place. Push the plastic tube hose over the port on the right side of the primary control. Remove the small pieces of masking tape from the wires.
#6
Position the control console back upright on the top of the washer. Secure the control console to the washer with the three hex head retaining screws. Slide the washer back against the wall. Turn on the water supply and plug the washer into the wall outlet.
TECH SHEET LINK: http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567037.pdf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@!$^
Posted on Sep 21, 2010
blueextc3221
  • 15935 Answers
SOURCE: cycle begins then shortly after
#1
#2
#3
#4
#5
#6
WTW 4800XQ1 not working. Start lite goes on, fill lite goes on, then start lite goes off.
Hello. When you press the start button, you should hear the lid lock engage, then disengage after a short pause, then re-engage. If this doesn't happen, the lid lock might be defective, (the locking, unlocking, then re-locking is a self test). The motor should make some short, slow spins to determine load size. Listen for the motor--if all you hear is a "pulsing faint humming or buzzing noise", there is a part failure causing the motor to not move correctly. Because of the electronic design, you will have to call for service to determine the failure cause.
Aug 19, 2015 | Whirlpool Washing Machines
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Whirlpool cabrio washer doesn't start, Can I fix this by myself?
If you replaced the lid lock then you know how to get the top of the cabinet up lift the top up there should be a technical sheet in a plastic packet on the front panel it will tell you how to run a diagnostic if not there turn machine off press and hold any button except power/cancel for 3 seconds release 3 seconds repeat until 88 appears after that any fault codes should appear I have only had to replace a control twice on these units I am curious to see if you get an F50 or F51 code this is the most common when this machine first starts the lid should lock a short rotation of the basket lid unlocks then locks a short fill then rotation of the basket let me know what you find could be the control but I would like to eliminate the rotor and RPS sensor
Jan 18, 2015 | Whirlpool WTW6400SW Cabrio Washer
How to replace filter
Hello! Happy to help with that. To replace the filter simply twist the dirt cup lid off of the dirt cup. Remove the old filter and replace with the new one. Twist and lock the dirt cup lid back on. This vacuum takes a Dirt Devil F1 filter. Follow the link below to purchase the filter directly from dirtdevil.com. Thanks!
F1 HEPA Filter
Aug 11, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Dishwasher keep beeping F1 and F5
F5 is the fast and rinse LED
It simply means the lid motror current is to high during the start - The lid is jammed up or down. Or the electronic controller has failed!!
Dec 29, 2013 | Fisher and Paykel DishDrawer DS605FDSM...
Lid lock flashing
There are two issue needs considering. Should you have very less load and get wrong setting so the sensor can not weight. Do you have any error code like F1, F51, etc...
Try to turn the drum by hand see if it is freely turn to make sure nothing was caught in between.
This motor has a nut that was loosen by time or by working with large load for long. Lift over the washer to the wall, then you can kneel down and look at the bottom. There is a 1/4 hex head nut-see if it is loosen and reset the unit again.
F1 code - the control board dead, need to call Wp for replacement, as far as I know, they cover 1 time part and labor for this code.
F51 code-motor issue or weight sensor, need to figure out which one cause problem.
Oct 21, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 Error on Fisher & Paykel Nautilus
It leaked before leading to this.
1- Unplug the power.
2- Dry out the leak.
3- Before taking off the lid seal, check if Lid actuator working by going to diagnostic mode. 4- Select LD.
5-Pull the drawer half way out so you can see the lid going down or not when you turn on by pressing lock button.
6- Press the lock button again to release the Lid.
7- Most the time it is a Lid actuator problem and your seal look good, then you replace the Lid actuator only.
8- If it is a problem with the Lid actuator and your seal look bad then replace all .
Jun 21, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel dishwasher
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin.
If a flood condition is detected, both draws will activate the drain motors and flash F1.
Remove the bottom drawer by pulling the lock pins on each lower side corner. Slide down and remove front cover. Release the drawer slide clips and remove drawer then dry the catch basin.
There are three possible scenarios for this error code;
1. Defective lid motor(s)...Each drawer has two lid motors, attached to the cabinet on either side of the drawer, that pull the lid tight to the drawer when the cycle is started. (this was very common on early models)
2. Something too tall was placed in the drawer preventing the lid from closing completely.
3. (only seen this once) the drain hose developed a crack causing water to leak only when draining.
Jul 03, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher paykel dish drawer
The motor impeller is located inside the tub.
To remove/inspect:
1. Remove dishrack and filter
2. Twist the strainer lock ring counterclockwise to disengage.
3. Lift and remove strainer and lock ring assembly
4. Remove impeller, inspect for damage and/or debris in sump.
Hope this helps....
The F1 code is retained in memory as the most recent fault (may have happened awhile ago) and may not be related to the current issue.
However FYI
F1 code can be caused by several things:
1. Defective lid motor(s)...Each drawer has two lid motors that pull the lid tight to the drawer when the cycle is started. (this was very common on early models)
OR
Jun 16, 2008 | Dishwashers
Whirlpool WTW6400SW Cabrio Washer Logo
42 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
