Question about Westinghouse Televison & Video
I have tried every code provided by time Warner and the alternate instructions to program my remote to work with my Westinghouse 40" TV and it will not power on or change volume with the remote
PyroMan6x9x9
  • 150 Answers
SOURCE: Emerson Remote code
Get back to me with model and make of the remotes themselves, I'll see what I can find. Or you can check out http://www.xdiv.com/remotes/ Good Luck
Posted on Sep 14, 2007
whytfang
  • 170 Answers
SOURCE: I need programming instructions for Jensen Remote
Here you go...it took a while but I found the user manual cause I ROCK....that's right say it with me....He...Rocks...hehe...but anyway here is the link address if the link doesn't work...
http://safemanuals.com/user-guide-instructions-owner-manual/JENSEN/JER-321-_E
I hope this helps...good luck and thanks for rating my effort....the Fang
Download the completeuser guide (3257 Ko)
Posted on May 20, 2009
  • 20 Answers
SOURCE: remote codes for dynex tv time warner remote
time warner has only one code and it is 400
Posted on Nov 26, 2009
SOURCE: DirecTV remote won't work with my new RCA TV
yes go into kitchen open bin drop in these remotes are not meant for our tv/dvd/sat etc they are for a chinese system save your hair chuck it away sorry to say I got one of these oh dear !!!!!!!! you would be better getting a sky type copy remote from the two pound shop I did works great
Posted on May 05, 2010
SOURCE: Need Time Warner Remote code for LG 42LB5D HDTV
For Time Warner Cable digital remote controls to work with your 42" LG HDTV, do the following:
1. Press "TV" and "OK" simultaneously for 3 seconds, until the button "tv" light on the remote is on.
2. Enter the TV code. In this case, it's "113". With the right code, your component will turn off. Quickly press the power button on your digital cable remote to turn it back on. Press the "TV" button again so that the remote saves that code.
3. You should be done.
Posted on Jun 19, 2010
My cable provider is Time Warner. I looking for the universal code for my tv to work. My t.v is a Westinghouse
If the steps below are not successful I would call TW customer care line.
Turn on the device, such as your TV, that you want the remote to operate.
On your remote, press the corresponding device button [such as TV, DVD, CBL] and the OK/SEL buttons simultaneously for three seconds. The device LED will light indicating that it is ready to be programmed.
Note: The LED will remain lit for 30 seconds, and the next step must be completed while it is on.
Point the remote control at the device and press the CH+ or CH- button. The remote will emit power on/off code signals. Continue to step up or down until your device turns off.
Verify that the correct code has been selected by pressing the POWER button. Your device should turn back on. If it does, try changing the channel to verify programming was successful.
Press the corresponding device button to store the code. The device LED will blink twice to confirm the code has been stored.
Good luck
Apr 23, 2016 | Westinghouse Televison & Video
Where is "set" button on the remote so I can set DVD code?
You need to be using the TV's remote, not the Time Warner remote.  You are reading the TV's manual to set it's remote, not the Time Warner remote.  If you want the Time Warner remote to operate the TV, you will need to find the instructions that the Time Warner box/receiver provides and enter the TV's code.
Mar 24, 2009 | Toshiba 36A50 36" TV
Westinghouse codes
I just bought a 40" Westinghouse at BestBuy and had the same problem. My TWC remote still had the code from my old analog Samsung. Fortunately I kept the code sheet from Time Warner and using the 3 digit method reprogrammed it. Westinghouse uses 4 dif codes on their LED-LCDs. Here are the 3 digit code nos. 076 276 435 001. I ran thru the first 3 and mine was 001. Whoever your provider is use their remote to do this and not the one that came with your set. I used that remote to make all the adjustments on my set to fine tune it, color, sound, etc.following the menu. Hope this helps.
Aug 18, 2014 | Westinghouse Electric LD-3255VX 32 in. TV
Need codes for uw40tc1w
Codes depend on your remote manufacturer. We've got the same TV (uw40tc1w) and none of the codes seemed to work. However, we got a code to work finally using Time Warner Universal Remote UR5U-8780L via code 435. The issue we had was the instructions said the TV would turn on/off when we pressed the right code in. That never happened/TV never responded--even though the right code was entered. So, what we decided to do was program each recommended code in as though it were the right code and press the ON/OFF button. Through trial and error we found the right code. Luckily it was truly one of the codes recommended by the remote manufacturer--not Westinghouse.
Mar 26, 2012 | Westinghouse Televison & Video
My tv remote quit working. I would like the code for Daewoo TV, model No. DTQ-13P2FC to enter in another remote.
For Time Warner Cable TV Remote Codes for DAEWOO-TV's - Go to Time Warner Cable web site to PROGRAM REMOTE -- Site URL is http://www.timewarnercable.com/en/residential-home/support/pyr.html Then select TW Cable remote model. Under Control a Device -- first select type of device (TV) Then select Brand Name (DAEWOO). TW Cable lists several codes to cover different models. Choose a code and input into remote to see which code works. Try all codes. There were several codes to choose from and to try inputting into my TW Cable remote. Finally, the next to last code worked on my TW Cable remote -The Atlas OCAP 5-Device Remote Control by Universal Electronics. The code for this remote for Daewoo TV Model DTQ-13P2FC is 1661. Hope this helps. Otherwise, try checking the site of your cable or satellite provider & you should be able to get their add device codes for free.
Jun 21, 2011 | Daewoo DTQ-13P2FC 13" TV
I want to set the remote to change volume on TV,we can change the channels using the Time Warner remote but cannot change the volume using thesame remote, we have to change the volume on the Toshiba...
I am not familiar with the Time Warner remote, but Tivo remotes require pressing "tv power" and the "Tivo" button at the same time to program them.
Maybe you are pressing one a little ahead of the other.
Oct 18, 2009 | Toshiba 26 26AV502R 26 in. LCD HDTV
Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
i bot a new tv i don't have the book for the time warner remote so i don't know how to program it to work the tv it only works cable box
where can i find how to program remote that comes with time warner cable
Dec 26, 2008 | Onkyo TX-SR573 Receiver
TIME WARNER REMOTE WILL NOT WORK ON TV CONTROLS
I work for a cable company and there are some new tvs that wont program to our remotes.... but you can go to there office, ask for the newest remote... and make sure you have instructions and try to do the auto program... if you dont find it within about 5 minutes of scrolling the codes... your out of luck :-/
Dec 10, 2008 | Televison & Video
Directv remote code needed
Follow these steps:
http://support.directv.com/app/answers/detail/a_id/3188/~/white-remote-control-programming-steps
When it asks you to enter the code for your tv use 10178
It works like a charm!
May 01, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Remote control codes
You need remote rc64 to control the Olevia 32 inch LCD. You can call Directv and order the remote. Use code 11610.
Oct 15, 2007 | Olevia LT32HVM 32 in. LCD Television
Televison & Video Logo
50 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
