Where do i plug in the power cable? - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,887 Answers
Refer its user manual for details.
Posted on Apr 25, 2015
Not turn on
Unplug all power cables and check for bad connections. Reconnect all cables. Does the power supply fan rotate? Yes or No? Looking through the vented left side of the tower with the power cable plugged in do you see an LED lit? If no fan spinning in the power supply and no LED lit, then I suggest you change the power supply. Either do it yourself (very easy to do or have a tech shop do it for you - it's cheaper to do it yourself).
1. Un-plug all power cables.
2. Unscrew side panels.
3. Count how many of each type of power cable is required for on board devices.
4. Calculate power requirements by watts.
5. Purchase new power supply that has the cables you require and the required wattage to support your devices.
6. Unplug all power cables inside.
7. Plug in new power supply.
8. Plug in power cable first before turning on the computer. The green LED on the motherboard should come on. Congrats you have power.
9. Turn on the computer.
10. Enjoy!
May 18, 2014 | Acer Veriton M420 PC Desktop
Widetech the max psu update, now black screen on monitor
Kind of hard to give you a cable diagram, Roslyn, when you haven't stated what motherboard manufacturer and model number.
Or computer manufacturer and model number.
(Back of computer next to Windows product key; or up on side of computer tower )
So we'll wing it..............
Widetech the Max. A modular line of Power Supplies.
1) Main power cable;
It will be either a 20-pin ATX main power cable, or a 24-pin ATX main power cable.
The WTM (Widetech the Max) will have a braided thick cable, that will have a 20-pin connector, and a 4-pin connector.
Looks like this,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20plus4
The 20-pin connector, and the 4-pin connector, should have a white arrow on the side. The arrows point to each other, when the two connectors are properly aligned with each other.
So, ATX main power cable plugs into Power Supply, (If removable), and 20 + 4-pin connector plugs into motherboard.
When the hooked end of the Lock, on the side of the power cable's connector; is over the Tab on the motherboard connector; the power cable is deemed to be plugged in properly, and tightly.
Note*
Orange wires are 3.3 Volts
Red wires are 5 Volts
Yellow wires are 12 Volts.
Black wires are Ground wires. (Also are Negative)
Note that the extra 4-pin power cable, that attaches with the 20-pin ATX power cable; has TWO Yellow wires, a Red wire, and a Black wire.
This way you don't accidentally somehow, plug the following power cable, in with the 20-pin ATX main power cable,
2) 4-pin ATX +12 Volt power cable:
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
When Processors started using more power, than just the processor socket (Motherboard) could deliver, this power cable was brought out to help carry the load.
Note*
TWO Yellow 12 volt wires, and TWO Black ground wires.
3) 8-pin EPS +12 Volt power cable:
http://www.playtool.com/pages/psuconnectors/connectors.html#eps8
Brought out for motherboards supporting multiple Processors, (CPU's), such as a server computer; but with processors needing more, and more power; is used quite frequently by motherboard manufacturers now.
NOTICE the power wires. The color code of the insulation of the wires.
FOUR Yellow wires (12 Volt), and FOUR Black wires. (Ground)
NOT to be mixed up with the following power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress8
This baby plugs into a GRAPHICS CARD (Video Card. Same/same)
A PCI Express graphics card, IF it uses one.
The PCI-Express x16 slot on the motherboard, is only capable of delivering 75 Watts.
This power cable can deliver UP TO an additional 150 Watts.
It is an upgrade of this power cable,
The 6-pin PCI Express power cable was brought out, to provide more power for a graphics card.
75 Watts.
So now you have the PCI-Express x16 slot on the motherboard capable of 75 Watts, and the 6-pin PCI Express power cable capable of 75 Watts; for a total of 150 Watts available for a graphics card.
PCI-Express x16 slot on motherboard, and 8-pin PCI Express power cable?
225 Watts.
This power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#eps4plus4
Is for a motherboard that uses a 4-pin ATX +12 Volt power cable, OR an 8-pin EPS +12 Volt power cable.
Is a combined power cable if needed, just like the 20 + 4-pin ATX main power cable.
This power cable is a SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
Used to plug into a Harddrive, or Optical Drive. (CD/DVD drive)
NOTE*
IF your SATA harddrive has a provision on the back; to plug in EITHER a SATA power cable, AND a 4-pin Peripheral power cable; ONLY use the SATA power cable.
Using BOTH power cables will burn up the harddrive. May not happen immediately, but I ASSURE you it will happen.
4-pin Peripheral power cable, is also erroneously known as a 'Molex' power cable.
Molex was the first company with the CONNECTOR design. The name stuck. Kind of like calling an adjustable open-end wrench, a Crescent wrench,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
[ IDE (PATA) harddrive shown in photo. Not a SATA harddrive ]
Note that between a SATA power cable, and a SATA data cable; the SATA power cable's connector is longer.
SATA power cable connector has 15-pins.
SATA data cable's connector has 7-pins,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
Note the L-shaped opening of the SATA data cable's connector; and the L-shape of the motherboard connector.
The SATA power cable has the same L-shaped opening.
NOTE that color of connectors does NOT matter.
Could be green with pink polka dots.
It is the wire color code, and connector SHAPE, that matters.
[Applies to ALL cables, and connectors}
Sometimes the SATA power cable, and SATA data cable connectors; have a lock on them.
May not see it very well. It is usually a slightly raised bump on the connector. This is depressed with a thumb nail to unlock.
Unlock WHEN installing, and removing.
ALWAYS use the connector when plugging in, or unplugging a cable.
DO NOT pull on the wires.
(Even if you have to stand on your head, and whistle 'Dixie')
I lay the computer opening side UP, on a static free towel, on a table. Much easier to get to the cabling.
ONLY plug in the cables you need, to the Power Supply.
That's what Modular cabling is all about.
Gives more room when not using unnecessary cables, and more air flow through the computer case; for cooling.
I just installed a ThermalTake TR2 600 power supply. It is Modular Cabling also.
I'm willing to bet you didn't plug the Processor (CPU) power cable in.
Either a 4-pin ATX +12 Volt power cable, OR an 8-pin EPS +12 Volt power cable.
Make sure the Ram Memory is seated tightly also.
It get's bumped loose when installing a Power Supply.
No,.....you CANNOT just visually inspect, and let it go at that.
You HAVE to remove ALL ram memory modules ('Stick'), and plug them back in again; to be ASSURED that they/it are seated tightly, and correctly.
Well that about does it for me kid, post back in a Comment if you have additional questions.
Regards,
joecoolvette
Jan 01, 2013 | Computers & Internet
My external hdd has is not detecting
Seagate is a company that manufactures external hard drives.
These hard drives can be used to house large files or even to backup an entire hard drive.
When your Seagate external hard drive is not working properly, you might ready to send it into the company for repair.
Before you send it away, you can troubleshoot the problem and potentially save yourself a lot of time and grief.
Look over the power cable going from the wall outlet to the back of the Seagate hard drive. Make sure that there aren't any breaks or tears in the electrical wiring.
If there are breaks, replace the power cord.
Look over the power cable and make sure that it is plugged into the wall outlet in your home as well as plugged into the back of the hard drive.
Plug the power cable directly into the wall outlet or into a surge protector.
Do not plug the power cable into an extension cord.
Seagate Data Cable
Disconnect all of the USB devices that are plugged into your computer's USB ports except for your mouse and your keyboard.
Disconnect the Seagate external hard drive from your computer.
Unplug the power cable from the back of the Seagate external hard drive and restart your computer.
Wait until your computer has fully booted and then plug the power cable back into the hard drive.
Look over the USB data cable to make sure that there are breaks or tears in the cable.
Look over the ends of the cable where they meet the computer and the hard drive.
Make sure the pins are straight.
Replace the cable if needed.
Plug the data cable into the back of the hard drive.
Plug the data cable into your computer.
Hope this helps.
Nov 23, 2012 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Computer does not recognise speedstream 6300
you try form USB or LAN interface \\Ethernet connection (recommended)
  1. Plug one end of the RJ-11 telephone cable into an unfiltered telephone wall jack (enabled for Sympatico High Speed Internet service).
  2. Plug the other end of the RJ-11 telephone cable into the DSL port on the back of the modem.
  3. Plug one end of the RJ-45 Ethernet cable into your computer's Ethernet port.
  4. Plug the other end of the RJ-45 Ethernet cable into the Ethernet Port 1 on the back of the modem.
  5. Insert the rounded end of the power adapter into the Power port and the dual-pronged plug end into your power outlet.
  6. Press the power button to turn on the modem.
USB connection
  3. Plug the small, square end of the USB cable into your computer's USB port.
  4. Plug the wide, flat end of the USB cable into the USB port on the back of the modem.
May 28, 2012 | Efficient Networks Speedstream 6300...
Bios setup does not show sata HD windos xp find them
I have had problems like this many times with some of my IBM machines. What i find most often the reason the bios will not recognize them is because the hard drive has gone bad.
Troubleshooting 1. Unplug power cable from computer before doing anything inside of the computer. Unplug sata cable from motherboard and hard drive. Unplug power cable from hard drive.
Plug the sata cable back into the motherboard and into the hard drive. Plug the power cable back into the hard drive. Plug the power cable back into the computer.
Boot computer and enter bios(by pressing F8, Enter, Del ect..) Does the hard drive show in there now?
2. If you have another hard drive.
Unplug power cable from computer before doing anything inside of the computer. Unplug sata cable from hard drive. Unplug power cable from hard drive.
Plug the sata cable into the second hard drive. Plug the power cable into the second hard drive. Plug the power cable back into the computer.
Boot up the computer and enter the bios. Does this hard drive show in the bios? If so then i would say that your original hard drive has gone bad.
Apr 20, 2011 | Abit AV8 Motherboard
The monitor will not come on when i turn it on
1. - Check for power at the socket. (plug in something else)
2. - Check for power at the power cable. (plug the cable into something else you know works)
3. - Plug into monitor, and see if ANYTHING lights up when the power switch is turned ON.
4. - If you get some indication of power, try a new cable to the PC, or plug into different PC. That will localize if it's the monitor, the cable, or the PC.
May 28, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Hello I hv an Acer aspire 4702z model z01 who's
remove the side of the computer and make sure the power connector is plugged in to the drive. if it is not then plug it in and the problem is solved. if it is the drive is dead or you have a faulty power supply try plugging in another power connector ... if it is an ATA power connector it has 4 wires and usually a white plug but not always white. there is also a dat cable called a ribbon cable and it looks flat 2 inches across and grey. if it is a SATA drive connector it will look like a thick cable with a black plug coming down from the top of the computer where the power supply is. There are 2 cables plugged in to the drive the bigger plug is the power cable the one with the smaller plug is the data cable usually orange or red. Make sure everything is plugged in if it is the drive is mostly dead. you can buy a new drive for around $25 at a computer store. easy to replace... i hope this helps
Mar 24, 2010 | Acer Computers & Internet
The power does not come on
Would request you to try some of undermentioned steps, this would help you identify what is the main issue:
  1. Try different power source or outlet. Make sure that the power socket is working properly.
  2. Unplug all cables from back of modem & plug only power cable. If power light does not come on, then you might need to get modem or power adapter changed.
  3. If power light comes on, then plug sat in & out cable, if light goes off then issue could be with these cables & you might need to call your ISP provider to send installer & look after the dish.
  4. If power light is still on, then plug lan cable & if light goes off then you need to change LAN Cable.
Oct 20, 2009 | 2wire Computers & Internet
Power-on "initializing" power-off, repeat same cycle(process)
The all-in-one product display always reads "Initializing" This may occur in a low power situation. Follow these steps in order to determine the cause:
  1. Verify that the computer and the all-in-one product have a three-prong power plug.
  2. Unplug the product cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
  3. If the all-in-one has an ADF with an external cable plugging into the back of the product:
    1. Turn off the unit.
    2. Unplug the power cable from the wall outlet.
    3. Unplug the ADF cable from the back of the product.
    4. Plug the ADF cable to the back of the product.
    5. Plug in the power cable, and turn on the power.
      • If no change, the problem is not the ADF.
      • If the problem clears, turn off the all-in-one, unplug the power cable, and plug in the ADF.
      • If the error returns, the ADF is defective. Contact HP Customer Care to get the ADF replaced.
  4. Unplug the USB or parallel communication cable from the back of the all-in-one and try to power up the all-in-one. The computer may be grounding out through the communications cable. If this corrects the issue, check the grounding of the computer and outlet. If the above steps did not resolve your issue, contact HP for additional issue verification or the servicing of your product.
Jan 04, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Televison & Video Logo
Top Televison & Video Experts
