Question about Canon imageCLASS D660 All-In-One Laser Printer
Paper jam at "exit" - canon D660
I can see torn paper at the exit roller but can't see a way to get behind the roller to remove the paper. there does not seem to be a "user" accessable path to this paper, but I do have a screwdriver and some time. Any thoughts?
  • 3 more comments
  • bilg Nov 14, 2007
    Thanks for this but are you talking about a Canon D660? There is only a paper drawer in the front and no door on the left (exit) side.
  • bilg Nov 14, 2007
    Yes there is a door at that end.
    would you please just confirm that this is a good approach for a jam that is at the other end of the copier. (the left or exit end)
  • bilg Nov 14, 2007
    ok, I will give these ideas a try tonight
  • bilg Nov 15, 2007
    I did not see the screws that you were referring to, but I was able to get more of the cover panel, etc stuff out of the way at the exit end, and was lucky enough to pull out the paper. There does not seem to be an easy way to access this place for possible jams.
    anyway, thanks for your ideas.
  • Anonymous Jun 24, 2008
    paper jamming at exit (left side) - cannot get it out from the inside of the copier and cannot get it out at the exit. Unable to do anything right now.
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Open side door and front door, there should be foor screws holding the fuser.
remove screws and take out unit ( be careful, there is a wire connected to the machine, you do not nesscessarily have to disconnect it. ) take out paper and replace.
Posted on Nov 14, 2007
  • CheckitRight
    CheckitRight Nov 14, 2007
    I was talking about the right side actually, there should be a door there
  • CheckitRight
    Although I'm not familiar with that exact model, most multifunction copiers are built very simalar.
    It goes trough the fuser and out the exit assembly, so removing the fuser is the first step. If it is not partially in the fuser it will be in the exit delivery system and I'm sure you would have to remove the fuser anyway. One model I worked on that was a mfc, you also had to remove the plastic cover of the exit assembly then remove a small bracket, take the cover of the exit off and remove the paper ( approx time 20-30 min.)
    Good luck.
I have a paper jam on my very old canon fax machine...Canon Super G3. The paper is held up in the rollers and has can I release the rollers so that I can get the torn piece of paper...
To remove the paper jam, follow the procedure---
1. Open the front cover.
2. Remove the cartridge.
3. Open the face up cover and push down the green paper release levers on both sides of the face up paper output.
4. Hold sides of the jammed paper and carefully move it inward then gently pull out.
5. Remove if any paper bits present near the rollers.
6. Don?t pull the paper upwards but straight between the rollers.
Please check page#62 for details in the manual---
Canon Super G3 Fax
Apr 01, 2011 | Canon Office Equipment & Supplies
Paper is jammed in my HP Photosmart C3180 All-in-One. Can't figure out how to open machine to remove paper.
Follow these steps to clear the jam from the product. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray.
CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Remove any loose paper Do not pull jammed paper c01954290.gif c01961869.gif Step two: Clear the jam from the rear of the All-in-One Follow these steps to clear the paper jam from the rear of the product.
CAUTION: Never pull jammed paper from the front of the product. Pulling paper from inside the front cover can cause mechanical damage to the product. Always access and clear paper jams through the rear access door.
  1. With the product powered on, disconnect the power cord, USB cable, and Ethernet cable from the rear of the product.
  2. Press in the tab on the rear access door to release the door. Pull the door away from the product to remove it. Figure 1: Remove the rear access doorc00703963.gif
  3. To avoid tearing jammed paper, gently grab both edges of the jammed paper, and then pull with even pressure to remove.
  4. Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product.
    CAUTION: Make sure to remove any bits of torn paper from the rollers inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure 2: Check the product for bits of torn paperc01979299.gif
  5. While you have the rear access door removed, check the rollers with your fingers. Rollers should roll freely and feel springy. If rollers are missing or do not turn freely, buy a replacement rear access door. Click here to order a replacement part from HP .
  6. Reattach the rear access door. Gently push the door toward the product until it snaps into place.
Step three: Clear the jam from the front of the All-in-One
CAUTION: Carefully remove bits of torn or jammed paper from the front of the product. If you pull too hard on jammed paper, you might damage the print mechanism.
  1. Make sure that you disconnect the power cord from the rear of the product.
  2. Open the cartridge access door. Figure 3: Open the cartridge doorc00372271.gif
  3. Gently pull out any jammed bits or torn pieces of paper from the rollers inside the product.
    CAUTION: If the paper tears when you remove it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If pieces of paper remain in the product, more paper jams might occur.
  4. Close the cartridge access door.
  5. Reconnect the power cord to the rear of the product.
  6. Press the Power button (c01602202.gif ) to turn on the product.
Mar 13, 2011 | HP Photosmart C5180 All-In-One InkJet...
Paper jammed at exit rollers of Canon D860. Paper
If you remove the plastic covers on that side of the printer, you will see a small screw holding a bar against the rollers. Set the printer on end so you can remove this screw with out dropping it into the printer, and then the rollers will be loose enough that you can get the paper out.
May 12, 2010 | Canon imageCLASS D860 All-In-One Laser...
This is near the exit area right before copy exits into the tray or sorter It appiles heat and pressure to the copy as it goes between the upper and lower fuser rollers so that the toner melts into your copies and won"t rub off keeping the image from smearing Often the copies will be warm--this is normal.
Apr 21, 2010 | Canon ImageClass D660 Copier
Paper jam in exit area. How do you remove?
The paper jammed on fixing unit area. Probably the pressure roller is worn-out causing the paper to stick on it rather than sliding the paper out. Remove the fixing unit so that you can remove the paper. Removing the fixing unit needs a lot of skills, I recommend you call the nearest service center for assistance.
Feb 17, 2010 | Canon ImageRUNNER 1670F Copier
Paper jam. paper tore at the exit roller. I
Jan 22, 2010 | Canon ImageClass D660 Copier
Paper jammed in Cannon D660
Typically this happens becuase the lower fuser roller (P# RF5-2601) is worn and makes the paper stick before it comes out - OR - the upper fuser film sleeve (P# FG6-7948-UFFS) is torn or worn out. Do not try poking something in there in an attempt to get paper out. You will just damage more stuff. The fuser unit (P# FG6-7947) needs to be removed and parts replaced within it to do it right.
Mar 19, 2009 | Canon imageCLASS D660 All-In-One Laser...
Nov 29, 2007 | Office Equipment & Supplies
Canon imageCLASS D660 All-In-One Laser Printer Logo
1,181 people viewed this question
old marine
old marine
