Question about DeLonghi Magnifica 3300 Espresso Machine
Delonghi Magnifica 3300. When machine turns on and/or when trying to make coffee it pumps few secs of water and stops with water led blinking red. Thanks for any ideas to diagnose the issue.
Also noticing the preinfusion cycle is not performed. The machine starts brewing without making the perfusion cycle and then stops short with water led blinking
    Genius:
  • 1,179 Answers
Posted on Apr 25, 2015
Testimonial: "Thank you for your quick response. I've followed the troubleshooting instructions on page 19 without success. It prompts my attention that the perfusion step is not done. The machine is not doing any weird noises, it only stops pumping water"
Your question: "I have a Delonghi magnifica 3300 that is 7 yrs old. It doesn't heat the coffee very good and the steam frother doesn't work well either. I have always used filtered water and descale i
If heater not working properly ,but still working the heat transfer poor ,probably need to disassemble and actually manually clean heater unit with wire brush till really clean,otherwise replace heater unit as heaters are usually fully sealed. get on line and search for Delonghi magnifica 3300 (parts diagram , replacement parts,parts). then you will have part no and hopefully someone who can supply parts.As for frother if water not heating to enough to make hot coffee the not heating enough to make steam either so frother does not work,if blocked then need to clean out frother tube.
Sep 07, 2014 | DeLonghi Esclusivo Magnifica ESAM3300...
Squeaking delonghi magnifica
Take it apart and clean it properly plug use sileco to lubricate for a longer use water heat coffee all of these make machine to fail
Keep service as importance
Jul 09, 2014 | DeLonghi Magnifica 3300 Espresso Machine
All lights blinking red simutaneously
grinder is very fine, turn the knob inside the coffee to a large chislo.Ako not fix it, there are probably some trash between the blades of the grinder.
Nov 26, 2013 | DeLonghi Magnifica 3300 Espresso Machine
This is difficult to describe but my delonghi magnifica has developed a small problem, after turning the machine on via the front panel On button, the pump activates (slightly) even though no other buttons...
It might be a normal cleaning cycle or flushing itself out. You don't mention whether it's not working anymore, so is it just that the sounds and lights seem concerning, or has it actually stopped working?
Oct 28, 2013 | DeLonghi Magnifica 3300 Espresso Machine
There is a red light flashing thru all the icons underneath the controls
Run the hot water tap until the lights stop blinking. It is asking for the water circuit to be primed IIRC.
Sep 30, 2011 | DeLonghi Magnifica 3300 Espresso Machine
I have a Magnifica. The descale red flashing light won't reset after going through the descaling procceedure.
I have the same problem with my Delonghi Magnifica, so maybe there is a glitch in the machine..
Aug 20, 2011 | DeLonghi Magnifica 3300 Espresso Machine
Boought brand new delonghi magnifica 3300 and did everything the directions say, it turns on, and the motor runs, but no water comes out when we try to run the water for the first time out into the cup...
Read instruction manual first before assuming there is problem. It happen we are not familiar to the operation of the machine the troubles becomes- "operators errors rather than machine errors".
If you already read operating manual and still not yet understand. Call their service hotline, ask something about your problem.
It easy as that! I hope my advice help you.
Apr 04, 2011 | DeLonghi Magnifica 3300 Espresso Machine
Lost the instructions / booklet and cannot recall how to clean / descale my DeLonghi ( Magnifica Model) Coffee Machine. Are you able to assist? Many thanks
fill water right to line ... turn unit on ....when its ready to use push and hold the descale button for approx 5 secs the lights wer cups are should stay on.... now place descaler in water ......put a larg container under steam pipe..... turn vaule open fully... it will run for approx 10 secs then stop for at least 15 min...until water runs out ... when light for water comes on fill tank up again with clean water place back into machine and it will flush through until empty .... when light for water comes on again ..job done ..turn vaulve to shut. ///
Feb 06, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Descaling coffee makes esam4200
100ml of descaler per tank of water. then they say 1 rinse, but I have to rinse 5 times to not taste the descaler anymore.
Jul 21, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi Magnifica 3300 Espresso Machine Logo
759 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
