Question about Zenith Televison & Video
MAKES SOUND NOISE AT START UP
WHEN YOU START T.V. IT MAKES LOUD SOUND NOISE. THOUGHT IT WAS FAN SO I REPLACED IT . NOT IT. ALSO REPLACED BULB BECAUSE IT NEEDED CHANGIN T.V. STILL MAKES LOAD SOUND WHEN YOU START IT UP THEN WILL QUIET DOWN A LITTLE .WHAT CAN IT BE?
  • 65 Answers
SOURCE: Toshiba DLP fan noise (52hmx95)
i constantly hear complaints about fan noise in dlptvs if you sit in front of your computer you will hear the same noise even in the next room there is no solution to the fan noise problem this product has a huge cage fan and a second and third three inch fans in it.... more than the samsung product it can be noticeable if the tv is on hard surfaces ie wood floors ,inthe corner, glass top etc the vents on the back of the tv allow for proper cooling of the lamp at shutoff so it doesnt shatter the tube its kinda like annealing glass its designed to extend the life of the lamp .... which im sure youve priced call toshiba and tell them your lamp is bad right now and get a new one for an emergency ( warranty if you can do it ) they are also improved this product is known to have short bulb life sometimes the zinging noise you hear is indicative of a bad color wheel in the light engine which would require replacement ( not cheap) toshiba will not piece out the color wheel assembly individually
Posted on Dec 09, 2006
  • 1039 Answers
SOURCE: Replaced bulb and now no picture and a loud humming sound
replaced the light engine. yhis set is probably not cost affective to fix.
Posted on Apr 25, 2009
SOURCE: buzzing sound with volume off/mute samsung 6163
It sounds like your color wheel. If you are handy at all you can change it pretty easily for the price of the part (probably around $90-$110) and a couple hours of your time. Here is a link to a video showing you the step by step process. http://www.youtube.com/watch?v=Cx4pbNjsxfU good luck..
Posted on Jun 04, 2009
SOURCE: Getting a loud buzzing noise in the rear of my
I have just experienced the same issue with my mitsubishi WD62525 as well...thought it may have been a lamp issue as well....replaced the lamp with the spare and still have the same symptoms...(only difference is that my timer light just continues to blink green and never turns red???) I cleaned out the rear filter...was not really that dusty so not sure what else it may be????
Posted on Sep 14, 2009
ladywinn
  • 5138 Answers
SOURCE: 50 inch rca dlp tv. new bulb. makes a loud
Color Wheel needs to be replaced. Call PartStore.com
1-866-925-7278 For Part number go to Encompass Parts Distribution they will list part number.
Posted on Apr 28, 2010
What could be causing loud grinding noise when i switch on aircon? Aircon now not working but only makes loud sound.
Sounds like the bearing or part of the clutch in the A/C compressor has failed, or possibly component on a/c fouling on something due to recent repairs however would be unlikely and probably just a coincidence..
Check A/C compressor turns by hand, should be firm but not make any noises.
Check for fouling components related to a/c compressor clutch.
Feb 12, 2016 | Cars & Trucks
Excessive fan noise at start up
Check if fans are covered wit dust or wires block the airflow,
if stil u get the sound then you have to replace the fans
Jul 10, 2010 | Packard Bell iMedia 6826 (P481000502) PC...
Apr 28, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
ASUS Lap top computer, 2 months old' makes loud fan type noises at each start up.
Hi
Its normal for a laptop computer or a desktop computer to spin its fans at maximum speed during start up - its part of the power on self test.
If the fan is very loud like on this video the sound is very bad -
that would be a bad fan, constant bad noise. but if your fan only makes noise in start up, its normal.
your warranty should cover the replacement of the fan if its bad.
Oct 02, 2009 | ASUS Z71V Notebook Computer - 15.4"...
Makes very loud noise at start up.
It sounds like the bearings are going bad on the motor. Does it make the same sound when it is running?
Aug 09, 2009 | AO Smith 2 HP 115/230V 56C Replacement...
Dvd10 optoma projector makes a loud noise
Hi, I'm not sure if it's the same problem I had..
I had it on picture mute, for maybe 15 mins, which may not have been a good idea. While it was muted, it made a sparking sound, and then a very loud grinding noise. When turned off, the lound noise stops, and the fan continues as usual for about a minute. As soon as it's turned back on, the grinding noise is back. But the logo seemed to display ok.
I took it in for repairs, and they said they needed to replace the color wheel to fix the problem.
optoma dv10 mode
Sep 26, 2008 | Optoma H30 Multimedia Projector
Cooling fan
Yes. It can be replaced. Try to check which fan is making that sound. Do you have a laptop or a PC? On a PC, there are 3 standard fans inside it. one for the CPU, one for the power supply and one for the computer casing fan as well. It depends on which of those fans it's coming from. On a laptop, some laptops' fans actually makes a loud noise which is common but there is a way that it could be lessened but it might slow down your pc and it might overheat it as well. The loud noise on the fans of a laptop actually indicates that it's trying to cool down the system. If it doesn't stop the loud noise, it could indicate a problem switching the fans back to normal and would just continue to spin fast. Try to contact your PC tech for further diagnostics on the laptops fan to indicate if the problem is with the fan or the mainboard as well.
Jan 02, 2008 | Iomega 33089 250 GB Hard Drive
Buzzing sound by bulb
be quite sure that it is not the fan physically touching the case; other than that, scope your B+ voltage to the ballast and be certain it is clean;  while it could be that or the lamp itself, it is most probably loose or misaligned case assembley
Oct 09, 2007 | RCA D44LPW134 44" HDTV
Televison & Video Logo
48 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
