Question about Samsung RF266ABRS Bottom Freezer Refrigerator French Door
Why would I be getting water build up to ice below the meat tray?
Water filter is changed as needed, no water in the door, just the ice maker in the bottom freezer. Took out a 3/8 slab of ice this morning
  • 5 Answers
I'm no expert but because of all the problems I've had with my SAMSUNG refer, I'm getting to be more of an expert than I want to be! My Samsung French Door, Bottom Freezer (Model RFG297AARS) was leaking into the refrigerator & pooling under the deli drawer.
Repair required removing all of the interior drawers & shelves and the interior back panel. There you will find the defrost heater. Behind the defrost heater is a metal plate as well as one on the back of the front interior cover which have troughs to direct the defrost water into the defrost drainage hole. Both plates' troughs were corroded and in need of replacement. The corroded edge allowed defrost water to miss going down the drain hole and instead, enter into the interior of the refrigerator. Once the panels are removed, make sure the drain hole is clear of any obstruction. Your can use a very flexible bottle or tubing brush being careful not to damage any surrounding parts or the drain hole. I ordered Samsung part #'s AP5577767, plate drain & AP5587916, evaporator plate and replaced both (In your case, order parts DA61-04148A &DA61-04701B) . I also bought cold weather foil tape at the hardware store to hold the plates in place and to seal around the edges of the metal plates. This repair is not a terribly difficult task but you have to empty out the entire contents of the refrigerator to access the back panel. Just be real careful not to bend or puncture the defrost heater's tubing. The work took about an hour & I used a large camping cooler and frozen ice packs to keep the perishables cold while doing the work.
Posted on May 02, 2015
  • Samsung Master
  • 15,557 Answers
The unit self defrosts and this creates water. There is a drain tube that is supposed to let the water go to the bottom of the outside underneath. If that tube is plugged or damaged the water runs down the inside and creates ice.
Posted on Apr 25, 2015
The ice maker is not working and the water dispenser is not working right. I've changed the filter,checked the water supply and reset ice maker and waited 24 hours. What's next?
First make sure you have water going to refrigerator Samsung water filter heads go bad and won't let water thru or it could be the fill valve it's right near the filter
May 30, 2016 | Samsung RF4287HARS French Door...
Ice maker doesn't make ice anymore. The water works and dispenser levers on the door work for both ice (use store bought ice dumped into tray) and water. I replaced the filter after it quit making ice. Not...
you've already done the first thing i suggest, and that is to change the water filter. But if you still cant get ice made, you have a problem with either your ice maker or your water valve, or an electrical issue in the ice maker system.
Apr 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water accumalating in the bottom of the fridge.
A common problem. All modern refrigerators have an automatic deicer. The heater kicks in, then MELTS the ice in build up in the freezer for a short period before freezing again. This water drains either in the fridge or out the back to the catch tray. Simply pull out the bottom drawers and clean the clogged drain hold where the water can drain and evaporate in the catch tray as it is designed to.
Mar 14, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker icing up
Sounds like you may have a couple of problems here. The frost build up could be from a bad door seal. Moist air can be drawn in and collect on the inside. As for the water temp, it sounds like the water line connected to the refrigerator could be tapped off a hot water line. It needs to be connected to a potible cold water line.
Aug 26, 2009 | Kenmore Freezers
Ive got a GE profile and my ice maker stopped working. I get water through the door so i took the ice maker line off to see if it was clogged or something. its weird no water comes out the ice maker side...
GE made different versions of the model listed above your post. If the Ice Tray is empty pour tap water into the tray and let it freeze. If it empties on its own, then I would tell you that the water control valve for the ice make is defective. For a few years the ice maker came with an electronic control board behind the front cover on ice maker. To make sure I will need you to look for the correct model number on locations pointed out below in photo. You also are welcome to get answers from me or our sites free. Enter your model number in the search feature and this will pull up the model with pictures and parts. Either way let me know what you find and if I can help you better, Thanks, Sea Breeze
appliancepartsse@yahoo.com click on link below
http://servicepartstec.blogspot.com/
We may need to test the water control valve on the back also, here
is a picture of the dual valve
May 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Kitchenaid Superba and when ever we turn on the ice maker. it says our filter needs to ebe changed. is that a problem? However before even when the filter was bad it still made ice. whats wrong?
Most refrigerators with filters will not work...with a bad filter...they will work initially ...for a while after the filter indicates it needs to be changed but over time the filter can become completely clogged...and no water will flow...also the impurities that were being filtered out...are now in the water and the ice and can accumulate in the ice tray...or at the spot where water is dispensed into the tray...with real hard water calcium can build up and inhibit water flow. I would definitely change the filter..... I had the same problem and the filter and the monitor for the filter are tied into the circuitry...so yes it can definitely stop the water flow.
I hope this helps....good luck...please rate me...The Fang
Mar 25, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not working
check to see if your on/ off switch is green on the im 1st. 2nd make sure that you have properly seeded the dispenser tray by using the cross method. the auger arm at the back of the tray turn vertical and the auger mtr gear in the rf turn horizonal then insert the tray in the machine
May 31, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker jambed-now no water
The ice maker must be re-primed with water to sense frozen ice in the tray, dump, and refill. Use a cup or glass to manually pour the water into the tray just below the top of the blades. It should freeze, dump, and refill.
May 15, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice maker problems
the heater on the ice maker has gone bad the easiest way to fix is to replace ice maker.the heater is on the bottom of the maker and heats tray up to harvest ice if it dont the ice will stick.But try taking maker out and cleaning it real good with a light spongee (Scrubee)
let it dry then spray some a light coat of pam (or similar) into ice bins and try that ahrd water will eat the coating off the bins
Dec 29, 2007 | Maytag MSD2434GE Side by Side Refrigerator
Samsung RF266ABRS Bottom Freezer Refrigerator French Door Logo
146 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
