Question about Craftsman Garden
I need a drawing for my idler belt that came off on my craftsman 917.273621
My idler belt came off and now the tractor won't move
    Genius:
  • 1,181 Answers
Need diagram installation. A drive belt.
If you have a Craftsman, under the seat is the model number. Go Here to get the operators manual. The manual will have all the belt diagrams. Water Filters Lawn Garden Appliance Parts
Oct 14, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Replace belts on 917-271821
The deck has an idler pulley that keeps tension on the belt. The idler pulley is mounted on a pivoting bracket, that has a spring which provides the tension. You have to move the bracket so as to take the tension off the belt, thereby allowing you to slip the belt off the other drive pulleys
Aug 15, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman riding mower 10hp engine runs but barely moves in any gear...
sounds like you have a bad drive belt or maybe a Idler or Idler spring broken or has came loose.
Oct 02, 2013 | Craftsman Garden
Craftsman lawn tractor will not move
There are a few things to look a. The belt, is it slipping or loose? Check and small idler pulleys from the drive belt to the engine. The large pully on the transmission is keyed to the shaft. If either the key is sheared or the shaft worn enough, the shaft will spin but not turn the pulley under load. Also note that the axles are keyed to the rear wheels. A sheared key there will cause it to not move also. You should see the axle turning freely inside the wheel if this is the case. Here is a parts diagram so you at lease have an idea of the areas to check.
Craftsman 917275810 diagram
Aug 22, 2012 | Craftsman Garden
I have a 42" Craftsman
HI IF YOUR BELT IS LOOSE THEN YES YOU NEED A NEW BELT
IT IS A V-BELT GROUND DRIVE-95 25
PART /160855
Sep 02, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Android -man, the number is 917270622. Rich
well,,, that's the first thing you have to do. put the break, put transaxle on neutral, lower the deck,lay down on floor and inspect the belt by turning with and and looking for chips on belt. also look at idler moving by hand to see if bearing on idler is good. then release the brake but lock wheels and check tension on belt.
Feb 05, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
14hp craftsman 42 in.deck. where to reattach engage/ disengage rod on the deck
This can be diffucult if u are not familliar with your tractor but the easiest way is to slip the drive belt off the front pto pulley so that you can move the tention idler by hand. Move the idler arm by hand while watcing the bellcrank that attaches the rod you are talking about. Now attach the rod into the bellcrank with a number 2 hpc clip This should do it. Hope this helps :)
Nov 30, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Can't get stick to move down to disengage, push with all my power
With the engine off, reach under your deck and pull on the belt. This will force the idler arm back into disengaged position so you can start it. You can probably free the mechanism up with penatrating oil by spraying the pivot point on the idler arm ( the bracket the idler is mounted to that moves back and forth) while alternatly engaging the lever and pulling the belt till it frees up and returns by itself.
May 25, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
37 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
