Question about Microwave Ovens
How to lubricate fan on this microwave. Other reasons for too slow cooking
OTR Samsung Microwave fan comes on with no reason. Any way to fix it?
Does this happen while you are cooking on the range burners under the control panel?? These type microwaves have a heat sensor built into them in the area of the control panel bottom. If the microwave control gets too hot from cooking on the stove below it the heat sensor will turn the fan on to keep the control panel from getting heat damage. The fan should go off after everything cools off.
Apr 13, 2015 | Samsung 1.8 Cu. Ft. Over-the-Range...
GE Spacemaker XL1800 Microwave
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
My microwave oven model 721.85033111 vent fan stays on
You probably have a bad fan thermostat. This thermostat is supposed to turn on the vent fan if the microwave oven gets too hot (caused by cooking too much or having too many burners turned on on the range beneath the microwave oven). It should shut off in about 15 minutes after your turn off the range burners. But if it comes on for no reason, or won't turn off, then You probably have a bad fan thermostat.
Aug 10, 2014 | Kenmore Microwave Ovens
When the Whirlpool microwave oven is on the loud fan noise is unbearable. It is not effected according to the power level, in fact when it stops cooking the noise remains until it automatically is switched...
The fan motor is going and it involves bad bearings or the lubrication in the motor has dried out. The fan is responsible for cooling the magnetron while it is running and is critical, I suggest replacing it as quickly as possible.
Mar 07, 2011 | Whirlpool MH7140XF Microwave Oven
GE JVM1430 over the range microwave/exhaust fan unit. The exhaust fan (not the microwave cooling fan) all of a sudden has its speed slowed down considerably. The unit vents out the back, not top. ...
Sounds like a strip down of the fan and lubricate the bearings with sewing machine or thin cycle oil will do the trick.
Hope that helps.
Jan 20, 2011 | Microwave Ovens
I purchased the microwave oven just over a year ago and now after the time is up on an item cooking the air vent turns on automatically. The only way I have been able to stop the air vent after that is to...
the fan is designed to run after the unit has cooked its new technoligy the reason it does this is to remove all the moister from the inside of the unit as built up moister use to cause rust to form in the base of the unit .. so its perfictly normal
however the fan should not run for more than 1 minute.
Jun 28, 2010 | GE Profile Spacemaker Over-the-Range...
Occasionally, the unit growls with a loud noise while operating. I stop it and when the frowling stops, I restart it and it works normally for a while. then it will do the same thing again. It cooks...
This is probably lack of lubrication of either the cooling fan or the turntable if it has one.
If the cooling fan fails totally, the magnetron will fail so service the unit immediately.
Jan 09, 2010 | Whirlpool MH3184XP Microwave Oven
Microwave still continues after cooking time is ended
It is the fan. Im guessing it only happens on combination cook and not when you are only using the microwave setting. It happens because the oven is hot and it helps to cool it quicker. It is normal. The microwaves are not working and neither is the oven-just the fan.
Mar 31, 2009 | Oster 0.7 Cu. Ft. Compact Microwave
GE Microwave won't heat or cook - one year old
More than likely the magnetron has failed. This could be for a number of reason. Do you use your microwave to heat wheat packs or warm plates? If so, you may have dried the magnetron out (they use the moisture in whatever you're cooking to heat it, and plates/wheat bags have no moisture).
I'd say a trip to your local Microwave repairer could be in order. It could also be the High Voltage Fuse which has failed. Either way a repairer will be able to tell you!
Mar 25, 2009 | GE Profile Spacemaker Over-the-Range...
The fan starts up and runs on its own and we are cooking
That is a normal safety feature.
That's only covered in a very subtle note in the hood fan section of your owner's manual:
NOTE:If the temperature gets too hot around the
microwave oven, the fan in the vent hood will
automatically turn on at the HIGH setting to cool the
oven. It may stay on up to an hour. When this
occurs, the fan can not be turned off.
If for some reason you don't have your owner's manual, you can download it here.
Enter your model number as MV1610ST with no spaces.
You will need the free DJVU viewer to view or print your manual.
Dec 14, 2008 | Goldstar MV-1615 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
