Question about Fisher and Paykel Dishwashers
How do I remove door of fisher and paykel dishwasher
SOURCE: How can I fix my Fisher and Paykel DD 6031 Dishwasher? its leaking
I have Fisher & Paykle DW DD603-SS (5Y old)
The upper drawr started to leak H2O out and in to the bothom drawr???
What is the problem and also please what is the solution?
Thanks, JB
Posted on Mar 13, 2009
  • 784 Answers
SOURCE: I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
Posted on Dec 29, 2009
SOURCE: Change Fuse on Fisher Paykel Dishdrawer
I have a single drawer F&P dishwasher. This morning a safety switch trigged. This afternoon when I went to use the dishwasher found that it had no power. There are no lights and there was a smell of something burning. The power outlet has power. Can you help?
Posted on Feb 14, 2010
jyackle5
  • 8197 Answers
SOURCE: Fisher and Paykel dishwasher DD603 manual
You can get the manual below for free..
http://www.fisherpaykel.com/admin/pdfs/pdf_usecares/527971B_DD_user_guide_USw.pdf
Good Luck and please rate 4 thumbs for the free answer
Posted on May 15, 2010
  • 3247 Answers
SOURCE: How to remove the drawers of fisher paykel dishwasher dd603
Refer to page 7 step 2 for instruction on removing the drawer (tub).
http://www.fisherpaykel.com/admin/pdfs/pdf_installations/526607O_DD_Install_USw.pdf
I suppose you want to get to the flood switch at the base of the dishwasher and dry it out.
Make sure the mains power is turned off.
Posted on May 17, 2010
Fisher paykel dishwasher
It would be helpful if you can provide the model number of the fisher paykel dishwasher.
May 26, 2013 | Dishwashers
Rubber has come off the door of my DW60CDX2 dishwasher
If the dishwasher is new and under warranty you could ask the Fisher and Paykel customer service to fix it.
Otherwise you need to work out which seal is involved, the one at the bottom of the door (attached to the door) or the one around the cabinet where the door fits.
Refer this site for parts and also the assembly diagram.Hope this helps.
Aug 17, 2012 | Fisher and Paykel Dishwashers
What does F2 mean??
F2 means that your rotor isn't moving properly and will need to be replace or it needs to be removed and check for something blocking it. Below is a link to a video you can buy for only $3.99 that will show you how to take your dishwasher apart and repair your Fisher and Paykel unit.
http://www.appliancerepairlesson.com/shop/dishwasher-videos/fisher-paykel-dishwasher-repair/
Mar 24, 2011 | Fisher and Paykel 23 in. DD603H SS...
Door drops down no tension
what do you mean buy the door has no tension. looking at the model number it is the two drawer glide systm
Jun 03, 2010 | Fisher and Paykel DS602 Dishwasher
My fisher paykel DD S03SS dishwasher leaks from the top, & drain
The drawers should not leak unless there is a problem with the vacuum seal. Try cleaning the edges of the doors and operate. You should feel the vacuum is holding the doors. The seals could be faulty or vacuum system may be faulty.
About not draining completely - a possibility is the common drain hose after the U adapter being clogged. Remove the clamp and pass a flexible wire coat hanger towards the main drain pipe. If both drawers are not draining then it is unlikely the drain hose between the U clamp and the dishwasher is clogged. Also make sure the height of inlet water pipe and drain outlet is as specified in the installation manual
Nov 09, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel dishwasher model dd602 error code F4
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
May 25, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
What is F4 error on fisher paykel dishwasher?
Oct 29, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher paykel DD 603 SS double dish drawers
Post your email i will send you the manual on the breakdown of the unit
Jan 26, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
62 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
