Question about Android Gemini Tab
How do i do a factory reset on my Gemini D7
My tablet keeps restarting and gets no further than the start up screen before switching off and restarting? please help.
    Scholar:
  • 63 Answers
The Gemini tablet line performs factory resets and firmware updates with an SD card. Performing a factory reset requires writing files to an SD card with a computer, then starting up the tablet with the SD card present in it. Be aware that it will erase all data on the tablet, but with it in a boot loop, that may be a moot point.
Knowing the specific model number of your tablet is critical. Flashing the incorrect information can cause worse problems than you are encountering now. Rather than send you to the D7 GEM7007 page, I will give you the general page that leads to all the possible tablet results and directions. Look for the link that matches the Model Number, not just the name.
Factory Reset Original Firmware ROM Image Flashing Instructions
You will most likely need:
An SD card appropriate for the tablet (SD, MicroSD, Etc)
A reader for the card for your computer (Attached reader will handle SD and MicroSD)
The ability to get the Tablet to completely turn off to start the process.
The first two can be purchased. The last one is up to whether the tablet has a hardware fault. If the tablet has any kind of broken hardware inside it (wear and tear, aging, or damage) the process may not work. In the event of hardware failure, replacement under warranty or without warranty may be the best solution.
Posted on Apr 25, 2015
I need to know how to factory reset my tablet. Somehow the touch screen messed up and when I touch the screen it clicks a different spot then where I touched.
Maybe a reboot will fix the problem. Some, but not all, can be rebooted by holding the start button in for 10 seconds. Wait a further 30 seconds or so and restart as normal. Once fired up the problem may be resolved. Good luck.
Jul 25, 2015 | Tablets & eReaders
Loading issues please help xx
Hello chloe you ned to free some of the memory by closing all resent used apps and IF the tablet is unresponsive you may be requierd to perform a hard reset your tablet
Resetting your device to Factory Defaults If you need to reset your device to the factory default settings for any reason please follow the process below:
WARNING!!!
Please be aware any information currently on the device will be permanently erased by following this procedure.
  1. Go to applications screen and touch the settings button.
  2. Touch the Backup & reset option.
  3. Select Factory data reset.
  4. Leave the erase SD card option unticked & touch "Reset tablet".
  5. Touch "erase everything".
  6. The unit will now reset itself back to factory reset and any previous information/data will have been permanently erased.
Getting further help and support
Please see our support site below for further help and support with your device including how to install software updates if available and much more:
http://getsatisfaction.com/geminidevices
Manufakturer
http://www.geminidevices.com/7030.html
manual
http://www.geminidevices.com/manuals/GEM7030-Manual.pdf
Jan 05, 2015 | Android Gemini Tab
Keeps constantly restarting
Warning: All applications and personal files contained on the tablet will be erased. Only do this if you are unable to start your tablet.
  1. First, ensure the tablet has been switched off.
  2. Hold both the VOL+ and POWER buttons until the Gemini logo appears. Release both buttons.
  3. You should see a green robot on the screen with a red warning sign.
  4. Press & hold POWER then press VOL+ once, then release the POWER button. A menu will show on-screen.
  5. Using the VOL+ and VOL- keys you can move up and down to select the Factory reset option. Press POWER to select this option, then move down to YES and press POWER again.
  6. Once completed, press POWER to restart the unit.
Apr 13, 2014 | Tablets & eReaders
Forgot my screen lock pin
If you have forgotten the screen lock PIN, you will have to perform a factory reset on the device, which deletes all data including the PIN. This process differs between tablets and is not trivial. See their directions for your device at https://geminidevices.zendesk.com/entries/23857527-How-do-I-perform-a-factory-reset-on-my-tablet-
Mar 28, 2014 | Android Gemini Tab
Tablet is stuck on the screen that says android
You may have to reset the tablet to factory settings. This may be the only way. It will wipe all the data on it.
To factory reset:
1. Press and hold power plus volume up until an android menu appear 2. Use the volume keys to navigate and option key or power to select. 3. look for factory reset and wipe data 5. restart the device and it should be back to factory settings.
Feb 04, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
My tablet is stuck on a green screen with the green words android along with a flying green android
switch off tablet and keep pressing the power button a bit longer. Remove battery and replace it after 2 minutes. Switch on the tablet. Good luck
Dec 03, 2013 | Tablets & eReaders
My tablet keep on restarting. cannot go into the settings because it automatically restarts
You'll need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
This will reset you device to factory settings, however anything on your SD card will still remain.
At this point you will need to start fresh as if you just bought the device -- register with your email address, etc.
Oct 24, 2013 | Nextbook Premium 7 Capacitive Touch...
Acer iconia a500 tablet freezes at the boot screen and does not go any further
The following info from
http://community.acer.com/t5/Tablets/Iconia-A500-frozen-at-Acer-logo-boot-screen/td-p/7171/page/28
might be helpful:
"How do I perform a Factory Data Reset if my Acer ICONIA TAB A500 does not boot?The following steps will erase all of your personal information, all stored contacts and any programs you have installed on your tablet.
1.Power off the tablet.
2.Press and hold the Volume up button, which is located closest to the touch screen lock switch.
3.With the Volume up button held, press and hold the Power button for 3 seconds then release it. Continue holding the Volume up button.
4.Once the tablet vibrates, switch the touch screen lock switch on and off repeatedly while still holding the Volume up button.
5.Release the Volume up button and stop switching the touch screen lock switch once the "Erasing Userdata..." message appears in the upper left corner of the screen.
6.Once the factory reset has been completed your tablet will load to the Welcome screen. 7.Your Factory Data Reset has completed now follow the onscreen steps to setup your tablet."
Good Luck!
Oct 18, 2013 | Tablets & eReaders
Tablet froze and now doesnt restart
Leave your tablet charging for a hour minimum. The battery might be so dead it has no power to start up at all. You get in to recovery mode do restore to factory settings.
Jun 02, 2013 | Coby Kyros 716829701508 Tablet PC
Android Gemini Tab Logo
470 people viewed this question
Top Android Tablets & eReaders Experts
Yoav Shilon
Yoav Shilon
Phillip Whisenant
Phillip Whisenant
Are you an Android Tablet and eReader Expert? Answer questions, earn points and help others
