Question about Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher
I am trying to take the top off the dishwasher to remove the sides. Pressing the plastic clips at the rear does not move it at all.
I have a Bosch model number she43m02uc/50... I need to replace the buttons but cant figure out how to do it myself and disassemble the panel.
Hi.
To remove the control panel on the machine there are a total of 6 screws holding it on. Four screws across the top of the inside of the door and 2 more on the sides.
Once you have removed all the wire connecting plugs from the control unit you should lay the control panel on a towel face down to work on the four clips holding the metal frame onto the plastic control panel. Be careful not to break these clips as they are delicate. Don't force them to move more than they need to disengage. Once the steel frame is removed out of the plastic control panel you should have access to the plastic buttons to replace them.
Regards Sam
Sep 30, 2013 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
How to repair rear actuator for ford escape hatch
Bad lock actuator: (NOTE: If your hatch is locked)
First remove rear panel- pull the plastic panel at the top center, until (2)clips pop off, then pop (2) more clips at the mid-center. Stick your arm down until you reach the lock, with your fingers, feel for the squishy plastic( inside is the bar that goes up to unlock), it is attached to the lever to unlock. Pull up the lever until you can open the hatch. There are four more clips at the top sides and middle sides, and four plastic screws at the bottom which is only accessible when the hatch is opened.
The lock is only sold as an assembly at $100.
Part Number #9L8Z-7843150 B
Apr 11, 2013 | 2010 Ford Escape XLT
I have a kenwood KDW12ST3A dishwasher. i have lost the manual and the dishwasher is displaying code E4.What does this mean ??
HERE IS A LEAK AND IT IS BUILDING UP IN THE BOTTOM DRIP TRAY!. It is filling up the drip tray and tripping the micro switch. Remove the lid(2 screws at rear),givng access to screws on top of right side panel,remove right side panel, you will have to remove plastic cover on bottom front first to give access to screws on side panel. This gives access to the hoses and such, where the leak is most likely coming from. I would buy some inch and a half to 2 inch hose clips first, as the clips on the machine are not really reusable.The machine will have to be put on its left side, you may have to remove the bottom drip tray also, this holds the micro switch and the polystyrene float. You may have to run the machine to see where the leak is coming from, It is time consuming, but very "doable", remember electricity and water do not mix,unplug and make sure everything is dry, particularly yourself!.
Apr 26, 2011 | Dishwashers
How do you remove display panel from frigidaire affinity washer
Pull out the detergent drawer, pressing the catch button in the rear of the drawer. There are a couple phillips screws through the panel around the drawer. Take those out. The display panel (including the entire plastic piece) is attached by plastic clips. Unsnap them by applying firm, controlled pressure along the top and sides of the plastic panel. Should come right out for you.
Feb 20, 2011 | Frigidaire Affinity ATF7000ES Front Load...
I need to remove the furniture from an old tecnik DW 2677 dishwasher as I have a new one and want to replace the front. I cant see any screws or how to remove it
1 Open door and you will see 5 crosshead screw on each side, undo the top screws and lift up the plastic control panel to release it from the metal clips fixed to the back of the furniture door
2 Lift up the door to release the plastic clips (fixed to the back of the furniture door) from the keyway slot in the metal dw door
3 If its a 2677 that is the replacement the reverse the proceedure on the new one, there is no point cahnging the clips, if its not then
4 Swap over to new makes fixings and rehang the door
Jan 29, 2011 | Tecnik TDW2677 Built-in Dishwasher
Need proper steps for convertible top operation
The top can be used as a sunroof or taken off completely. For the sunroof, you only have to unclip the two clips by each sun visor, and fold the front bow back so it sits on top of the roll bar. There is a velcro strip that goes through a hole in the front bow, to keep it in place.
To totally take the top off, you again uncleip the 2 clips by the sun visor. When the front bow is moved partway back, the material on the front bow is loose. There are sliding clips on the front of the convertible top that are slid along the front bow, so that the material is removed from the bow itself. Along each of the doors is an elastic clip that needs to be removed. Now the front of the top is pretty loose. Around the rear windows is a metal bar, with fabric snapped around it. Undo the snaps. Then forcefully push the metal bar outwards. The material around the rear window area can then be removed from around the metal bar. At this point, you can probably unzip the rear window. There are 2 pieces of plastic that slide into plastic grooves at the very rear of each corner of the car, that hold the rear of the top down. You just pull the rear of the fabric away from the rear corner of the car. And that's it.
Dec 06, 2010 | 1994 Suzuki Sidekick
GE Dishwasher makes loud banging noise
Check the stainless steel cover on the bottom of the lower rack sprayer. If it has been bent downward on either end, it will hit the inside panel of the door near the bottom. It may score the panel as it hits on each rotation of the sprayer.
Just bend it back in position, carefully, with a pair of pliers. The technique required is similar to bending the pocket clip of a fountain pen back into the proper position after it has been sprung out too far. You might practice on a pen or mechanical pencil clip to see what I mean.
Apr 06, 2009 | GE Dishwashers
Replace the headlight bulb
Remove the plastic access panel by pressing down on the tab at the top of the penel and pulling the top of the panel towards the engine and off. Needle nose pliers may help with the next steps to remove the spring clips. There are 2 bulbs, the top large bulb is the low beam. To remove it, first remove the socket attached to it, then press the top of the metal spring clip towards the front of the car and towards the passenger side (look closely at the clip to see the latch holding it. The clip then swings back towards the engine. Remove the old bulb, install the new bulb, replace the spring clip, re-connect the socket. (Don't touch the bulb, if you do clean it off with a lint free cloth and alcohol). To replace the lower bulb (parking light), remove the socket, then release the lower end of the spring clip, look closely and you'll see the latch holding it. You have to press it towards the front of the car and swing it towards the passenger side. It will swing up and release the bulb. Replace with new bulb, replace spring clip, connect socket. Don't forget to replace the plastic cover panel by inserting the bottom tabs into the sockets and snapping it closed at the top by pressing it towards the front of the car.
May 15, 2008 | 1998 Mercedes-Benz C-Class
Dishwasher refusing to run or running occasionally
fault is a leak you are right. to take off top, at rear just under top there are two plastic clips. push these with screwdriver and top will then come off. leak is prob main pump
Dec 05, 2006 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher Logo
83 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
