Question about Bosch Washing Machines
My Bosch classixx 6 is flashing 21 what does it mean
    New Friend:
I have tried to do 6 clock position then 7o clock and hold on spin button for 5 seconds then let go .. Turn back 12o clock .. Then turn on programme .. It's worked .. Washing some clothes then start again f21 came on after wash.. Spin won't go on .. .???
Posted on May 18, 2015
SOURCE: bosch washing machine error code
I've had the same problem, when we had a power cut I opened the door and after that I could only got F21 flashing! ,I googled for the answer and this WORKED:
Turn programme switch to 6 o clock,hold RPM button turn switch to spin, release RPM button
Posted on Apr 12, 2009
  • 662 Answers
SOURCE: key symbol showing
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
Posted on Jun 14, 2010
  • 662 Answers
SOURCE: Got the Bosch Classixx 6 Express 1400 washing machine cant
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently. Means the machine is locked, for children. I think if you do it again it locks.
Posted on Jun 17, 2010
richroth
  • 9472 Answers
SOURCE: bosch classixx 6 1400 machine
F21 relates to a motor or control board fault.
However, it is also caused by spikes in the mains and can be spurious.
To reset it.
Turn the appliance knob to the off or reset position, 12 o'clock.
Turn the knob to the 6 o'clock position.
Press and hold the spin button.
While holding it, turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds.
Release the button.
Turn the knob to off.
When your turn it back on it should have cleared the error code
Posted on Nov 27, 2010
patrick_b180
SOURCE: Bosch Classixx 6 1200 express has an error code F21 what is it
it is a motor or pcb fault this is a reset code as follows,
turn dial to off 12 0clock position then turn to 6 oclock,
press and hold the spin buttonat same time turn it to 7 oclock,continue to hold the spin buttonfor 5 seconds,release button,turn off.
next time you turn on the error code should have gone ,
if it does not work go through the proceedure again i had to try it 3 times but it does work
Posted on Jan 22, 2011
I have bosch classixx 6 washing machine with F22 code flashing ?
How to reset Bosch Classixx 1400 Express
hi,couldn't find too much detail about the fault , may be faulty brushes an commutato......the abovel ink gives details and how to reset after f22 message
good luck
r
Jul 09, 2015 | Bosch Washing Machines
How can i open the door of a bosch washing machine with F:21
Hey there, welcome to Fixya! The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
Jul 13, 2014 | Bosch Classixx WFO 2866 Front Load Washer
What do's f16 mean on the bosch classixx 6 1200 mean
F16 is a door fault, could be the door is not tightly closed before pressing start, the lock is faulty so the machine is not registering that it is closed or the wiring connection to the door lock is loose.
Apr 10, 2013 | Bosch Washing Machines
F21 flashing on my bosch classixx 6 1200 express
F21 is a motor fault and in some cases can also involve a module fault. It could be as simple as the brushes need replacing or the drum has been severely out of balance.
Mar 21, 2013 | Bosch Washing Machines
Got the Bosch Classixx 6 1400 Expresswashing
Pl rate me 'very helpful' for the free help, thanks!
May 14, 2010 | Bosch Classixx WFO 2466 Front Load Washer
Bosch classixx 1400 express key symbol
Apr 06, 2010 | Bosch Classixx WFL 2066 Front Load Washer
I have the same problem - Did you mange to sort it out?
Mar 23, 2010 | Bosch Classixx WFO 2466 Front Load Washer
Feb 22, 2010 | Bosch Classixx WFO 2466 Front Load Washer
Error code F 21
I have a Bosch Classixx 6 1200 express washing machine showing error code F21 on the display, what is it?
Apr 05, 2009 | Bosch Classixx WFO 2866 Front Load Washer
Bosch washing machine error code f-21 classixx
Aug 04, 2008 | Bosch Washing Machines
Washing Machines Logo
191 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
